Wrench warning light - Ford Truck Enthusiasts Forums
Old 07-26-2008, 08:16 PM
STX04 STX04 is offline
STX04 is starting off with a positive reputation.
So i just got my truck back from the shop to get my secondary ignition system worked on. Today, i got in my truck and my wrench light came on. I thought it was odd, so the next time i started my truck up it went away, and i ahve been driving all day and it has not come on again. any ideas what the problem might be?
Old 07-28-2008, 09:04 AM
slf06150 slf06150 is offline
slf06150 is starting off with a positive reputation.
Back in August my wrench light would come on then I would lose the drive by wire. The truck would idle but when hitting the accelerating nothing would happen. Shutoff/restart would correct it. This started occurring 2-3 times a week and I kept restarting. Then in January it happened; when I restarted the truck the emissions light came on and neither light would go out. I took it to the dealership and they replaced the throttle body and reflashed the PCM. Then a few months later my PCM failed completely and Ford replaced that as well.
I would take it back to the shop (dealership)? and have them check it out.
Old 07-28-2008, 09:54 AM
bridge's Avatar
bridge bridge is online now
bridge has a great reputation on FTE.bridge has a great reputation on FTE.bridge has a great reputation on FTE.bridge has a great reputation on FTE.bridge has a great reputation on FTE.
Quote:
When they work on the truck at the dealer some of the procedures will throw a code and cause that light to come on. They will usually clear any remaining codes prior to releasing the vehicle back to you. It sounds like you had an ignition code that cleared itself.
MY FIRST AND PROBABLY LAST FORD! ryanbodden2014 6.4L Power Stroke Diesel 36 01-30-2015 06:24 PM
The "wrench" Vinford 6.4L Power Stroke Diesel 27 07-14-2014 10:57 AM
torque wrench for the 18mm bolt Jerry Chaney 1999 - 2003 7.3L Power Stroke Diesel 9 01-25-2014 09:58 PM
wrench light 05 f 250 bcollison98 6.0L Power Stroke Diesel 5 07-21-2013 06:53 AM
wrench light yuccaview 1968-2013 Full Size Vans 3 07-29-2012 06:01 PM
Tags
05, 2004, 2005, 2006, 2009, emissions, explorer, f150, f250, ford, light, powerstroke, truck, warning, wrench
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
