Wiring Harness Diagram - Ford Truck Enthusiasts Forums
Old 07-26-2008, 03:59 PM
DeerTrack DeerTrack is offline
DeerTrack is starting off with a positive reputation.
I'm putting a wiring harness from a 1990 f150 into a 1987 F150. There's 2 reasons for this. Th '7 engine harness looks like an explosion in a spagetti factory. The othr reason is I replaced the C6 with a AOD/AOT transmission. The problem is connecting all the undercarriage wires to this harness. Apparently I'll be doing some dice and splice. Does anyone know where I might find wiring diagrams for the 87 and the 90 online? Any help would be appreciated.
Old 07-26-2008, 04:55 PM
gweeds's Avatar
gweeds gweeds is offline
gweeds is gaining momentum as a positive member of FTE.
You need to get a repair manual for your vehicle... Has all the wiring diagrams, vacuum diagrams, etc...
Engine wiring diagram? marky55 Lightning, Harley-Davidson F-150, Roush F-150 & Saleen F-150 7 04-07-2009 03:21 PM
Wiring Harness Diagram DeerTrack Electrical Systems/Wiring 3 08-06-2008 05:22 PM
Alternator / Volt reg wiring diagram vliposky 1967 - 1972 F-100 & Larger F-Series Trucks 2 11-19-2005 04:44 PM
Wiring Harness Diagram sharpshooter 1961 - 1966 F-100 & Larger F-Series Trucks 1 07-18-2003 08:19 PM
wiring harness diagram 1978 f150 waltnbecky Electrical Systems/Wiring 2 05-24-2002 12:24 AM
Tags
150, 1987, 1990, 1996, 302, 50, diagram, f150, ford, harness, pickup, truck, wire, wireing, wiring
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
