Change starter motor on 2000 Expy - probs.
Maybe I can add a bit about taking out that top bolt. Had the starter die on my 2000 after this morning's snow storm and had to change it in a parking lot laying on the ice. Use a 20" extension (or 2-10") a deep socket and a universal joint and reach in through the wheelwell. I took off the tire and it was almost easy. If the light's good you can actually see the sucker. You can also get a good 1/3 turn using the extension. Someone at Ford's laughing about this one.
And yes, in putting the top bolt back in, I lost it in the snow. Instantly disappeared. Sunk in like a rock in a creek. So I'm driving around with just two bolts. Ordered a pack of three replacements (N808980) from Ford for $13.03. Now I can lose two more.
I need a better hobby.
I had to do this job on my 98 Expy and I pretty much knew what I was in for as I had done it several times on Mark VIIIs. The Expy was a piece of cake compared to the Mark even though the Mark has 10MM heads on the bolts. Its not a job for the mechanically challenged though, for sure. The top bolt isn't too hard for me as I use a bit of paper towel (or equiv.) and shove the bolt head into the socket firmly, that keeps it from dropping out of the socket during installation. After the bolt is tight you just have to wriggle the socket and extension until its free and remove the tools, if you're not careful the socket will stay on the bolt head and be waiting for you the next time you need to remove the starter.
You need one of these.
Craftsman 9/16 x 5/8 in. Wrench, 12 pt. Obstruction - Model 04376 at Sears.com
The box ends are thinner than a standard wrench and should allow you to get it in there. What you might have to do is remove any and all other mounting bolts first, then pull the starter away as you're removing this last bolt in order to keep the bolt from binding against the housing.
Just replaced the starter after it died on me at a cracker barrel. The top bolt snapped off inside the trans case. I too just installed with the two lower ones. There was no way I was going to drill out the case just no room for drill (90 deg )and a bit. Made sure to use antisez on bolts.
e william
80
04-15-2015 05:44 PM
kraylake
11-20-2013 08:13 AM
