Transmission Cooler Lines Leaking - Ford Truck Enthusiasts Forums
Ranger & B-Series All Ford Ranger and Mazda B-Series models
Old 07-25-2008, 04:30 AM
BlackNGoldRules BlackNGoldRules is offline
BlackNGoldRules is starting off with a positive reputation.
I finally was able to replace my old leaky radiator yesterday with the new one that I got. Well, I no longer have a radiator fluid leak to worry about, but now my tranny cooler lines seem to have a slight leak right at the fittings. I tightened them down as much as I could and I still seem to be leaking just a little tranny fluid. Do you guys have any suggestions on what I may have done wrong when screwing them in to the new radiator? I actually had to leave the old fitting on the top line because I just couldn't get the line to screw off of the fitting. It just kept spinning when it got to the very end of the threads. The bottom one has the new fitting on it. Neither was leaking on my old radiator and now they have a slight leak on the new one. Any suggestions would be appreciated. Thanks.
Old 07-26-2008, 01:49 AM
Solved the problem. I ended up using both of the fittings off of my old radiator and put them on the new one exactly as they were on the old one. Worked like a charm. Now they are no longer leaking for some reason. I decided to take the washers that came with the new radiator off of the fittings. There were no washers on my old radiator so I figured I wouldn't need them. It was leaking with the washers and now isn't without the washers. Go figure. Anyway, problem solved for now.
Old 07-26-2008, 10:30 PM
MazdaRangerGuyInSTL MazdaRangerGuyInSTL is offline
MazdaRangerGuyInSTL is starting off with a positive reputation.
Yeah I've had to do that several times with new radiators... for some reason the new fittings don't seem to want to seal up properly.
Replaced radiator, now transmission fluid leaks where line slides into radiator Airdriver 6.0L Power Stroke Diesel 0 12-29-2016 09:59 AM
Transmission Line fitting leak? Building_Fords 1987 - 1996 F150 & Larger F-Series Trucks 1 10-19-2016 08:35 AM
Transmission cooler lines...help please! Aggie.2012 2004 - 2008 F150 2 11-01-2011 07:57 PM
Torque # for fittings, radiator/tranny lines k2vailkid 1999 - 2003 7.3L Power Stroke Diesel 6 04-23-2008 03:13 AM
Trans cooler adapters leaking on new radiator, teflon tape OK to try? gatesj Clutch, Transmission, Differential, Axle & Transfer Case 7 01-26-2006 05:36 PM
Tags
cooler, ford, leaking, line, ranger, transmission
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
