F150 dragging front brakes - Ford Truck Enthusiasts Forums
Old 07-24-2008, 12:21 PM
kais kais is offline
kais is starting off with a positive reputation.
Oh most knowledgable Ford folks, on a 1998 F150 2 wheel drive 4.6 250k, the front brakes will drag under a specific set of circumstances; only in prolonged stop and go traffic with hot ambient temps. Rotors, calipers, rear shoes, drums, fluid, bearings, seals have all been replaced. This occurs only a couple of times a year, otherwise the brakes work perfectly. It starts out as a slight shimmy that worsens until you can smell the pads cooking and the wheels are hotter than hell. The truck will hardly move at times. The rears are normal. After the truck cools for hours, no symptoms. Any thoughts or experiences? Thanks.
Old 07-24-2008, 01:40 PM
KingRanchMan02's Avatar
KingRanchMan02 KingRanchMan02 is offline
KingRanchMan02 is gaining momentum as a positive member of FTE.KingRanchMan02 is gaining momentum as a positive member of FTE.
Replace the rubber hoses between the frame and the calipers at the front wheels. The hoses deteriorate and swell up. This causes the hose to act like a one way valve that keeps the front calipers applied. Good luck!
Old 08-16-2008, 09:09 PM
Thanks, KRM02 your solution is much appreciated.
Old 08-17-2008, 10:06 AM
randy6800 randy6800 is offline
randy6800 is starting off with a positive reputation.
I had the same problem on my older f-150, i replaced the pads, calapier, still same problem. i replaced the brake hose and it fixed it.
Old 08-17-2008, 10:10 AM
DMch's Avatar
DMch DMch is offline
DMch is starting off with a positive reputation.
I had this happen on a 1998 2x4 with 388000km on the front left. A mechanic told me the clamp holding the brake hose will rust so much on the inside it clamps off the hose. Hydraulic pressure forces the fluid through the hose when braking but is restricted when released. I cleaned the rust out of the clamp and the brake works fine.
Old 08-17-2008, 06:54 PM
Moore FOMOCO Moore FOMOCO is offline
Moore FOMOCO is starting off with a positive reputation.
If all that doesn't work, I would think about piston )-ring swelled up or rolled/worn. Pop the piston out (with air) and emery cloth (inside Caliper) and a new O-ring should do it.
Old 07-04-2014, 12:15 PM
kuhndog kuhndog is offline
kuhndog is starting off with a positive reputation.
Yep just had this. It was the hose. Wheel locked so I opened the bleeder. fluid came out and wheel was free. Replaced the rubber hose and works perfect now.
Old 07-04-2014, 12:30 PM
cb_13's Avatar
cb_13 cb_13 is offline
cb_13 has a good reputation on FTE.cb_13 has a good reputation on FTE.cb_13 has a good reputation on FTE.
I always recommend replacing the hose when replacing a caliper. For the same reasons as have already been posted above.
2014 F350XL Right Front Brake Running Hot RRRAVEN 1999 to 2016 Super Duty 16 12-07-2016 10:01 PM
2000 F350 Superduty front brakes dragging RJB71 1999 to 2016 Super Duty 15 10-09-2014 12:29 PM
Rear Brakes Dragging lonewolf121 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 13 02-16-2012 09:02 AM
front brakes dragging ' F350 58k rick52 1999 to 2016 Super Duty 7 10-25-2011 08:42 PM
(Intermittent) Smouldering dragging brakes! J1MMY Brakes, Steering, Suspension, Tires, & Wheels 16 09-22-2008 04:50 PM
Tags
2004, brakes, dragging, f150, front
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
