Go Back   Ford Truck Enthusiasts Forums > Older, Classic & Antique Trucks > 1987 - 1996 F150 & Larger F-Series Trucks
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
1987 - 1996 F150 & Larger F-Series Trucks 1987 - 1996 Ford F-150, F-250, F-350 and larger pickups - including the 1997 heavy-duty F250/F350+ trucksSPONSORED BY:
  #1 (permalink)
Old 07-24-2008, 10:08 AM
cjben cjben is offline
1995 Ford F-150
cjben has a brilliant futurecjben has a brilliant futurecjben has a brilliant futurecjben has a brilliant futurecjben has a brilliant futurecjben has a brilliant futurecjben has a brilliant futurecjben has a brilliant futurecjben has a brilliant futurecjben has a brilliant futurecjben has a brilliant future
ignition module location?
I tried a search,but got confused. I am looking for the ignition module on my 1995 f150 5.0. Is it the box below the power distribution box with the plug in and a lot of wires coming out of it? when I searched, I read where it was on the distributor and took special tools to remove. there is nothing on my distributor. Also,would one like this work ACCEL 35371 - ACCEL Ignition Control Modules - summitracing.com or is this the one that mounts to the distributor. thanks!!
__________________
I'LL KEEP MY GOD,MY GUNS MY FREEDOM AND MY MONEY YOU KEEP "THE CHANGE"!!
1995 f150 xlt extended cab flareside 5.0 33" tires 3" body lift
  #2 (permalink)
Old 07-24-2008, 10:12 AM
quaddriver quaddriver is offline
Garage is empty, add now
quaddriver has a good reputation on FTE.quaddriver has a good reputation on FTE.quaddriver has a good reputation on FTE.
does you distributor use the TFI module? if so look for a thin (1/2 inch) 4 inch long, inch and a half tall thingy with a plug in the 5 oclockish position
that be her and it takes a little tool (that you can replicate using the NAPA bit set kit) to get it off - the only caveat is that the distributor needs out of the engine. oh, and its light gray in color
__________________
QuadDriver...
Go Fast, run over sh......stuff
  #3 (permalink)
Old 07-24-2008, 10:31 AM
NumberDummy's Avatar
NumberDummy NumberDummy is offline
Ford Parts Guru
2013 Ford Escape
NumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputation
The 1990/2002 Ford Light Truck Parts Catalog Parts sez: 1992/96 F150 5.0 = remote mounted ignition module.
Parts catalog illustration shows it to be mounted to the rear of the left hood hinge on the left fender inner apron.
5U2Z12A297B (replaced E8DZ-12A297-A) .. Ignition Module (Motorcraft DY1075)
MSRP: $156.76 / FTEpartsguy.com price: $84.65
__________________
Bill // Retired Ford Parts Manager // SoCal Chapter member // Part Number Research: 1928/2001 FoMoCo vehicles.
2013 Escape SE FWD 2.0L Eco-Boost.
  #4 (permalink)
Old 07-24-2008, 10:39 AM
Conanski's Avatar
Conanski Conanski is offline
1990 Ford F-150
Conanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud of
The TFI module is mounted in a heatsink on the fender on all F150s after 1991. If yours is faulty the only part worth replacing this with is a another Ford part, none of the aftermarket modules last.
__________________
Paul (Conan) O'Brien
1990 5.0HO AOD XLT X-Cab F150 3.55LS, 1990 2.3L 5-sp Ranger 3.08, 2004 3.0L 5-sp X-cab Ranger Edge 4.10, 2004 2.5L 5-spd Subaru Legacy
1996 Kawasaki ZX11D, 2004 Honda 599, 2008 Kawasaki KLR650
  #5 (permalink)
Old 08-22-2008, 12:55 PM
PerfDistIgnition PerfDistIgnition is offline
FTE Sponsor
PerfDistIgnition is starting off with a positive reputation.
Quote:
See Part No. X000555 at:
84-96 F-150 Ignition
__________________
FTE Sponsor
Performance Distributors
www.PerformanceDistributors.com
  #6 (permalink)
Old 08-23-2008, 03:58 AM
1995 Ford F-150
thanks,but I went with motorcraft
__________________
  #7 (permalink)
Old 09-29-2011, 02:23 PM
ewelling's Avatar
ewelling ewelling is offline
1995 Ford F-150
ewelling is starting off with a positive reputation.
Where I found my ignition module/control unit
I have a 95 F-150 4.9L with intermittent starting issues, always after sitting for at least 8 hours. The starter turns over strong, but it just won't start sometimes, like today. After it starts, it runs great and never stalls. My local Advance Auto parts guy said they can test the Ignition Module if I bring it in.
I found mine attached to the driver side sheet metal, in a heat sink bracket with aluminum cooling fins, just below where the hood hinge attaches to the sheet metal. It's held on by two hex head screws.
Tags
1995, 1996, 350, 5u2z12a297b, 97, control, f250, ford, ignition, location, module, motorcraft, part, ranger, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
