2004 F-150 four wheel drive problems - Ford Truck Enthusiasts Forums
Old 07-23-2008, 08:03 PM
Carbarator_man Carbarator_man is offline
Carbarator_man is starting off with a positive reputation.
When I put it in four wheel drive the drive shaft turns and the hubs don't lock in. The indicator comes on and nothing happens. Any ideas?
Old 07-23-2008, 11:21 PM
Chrome FX4's Avatar
Chrome FX4 Chrome FX4 is offline
Chrome FX4 is starting off with a positive reputation.
My 04' had the same problem. The IWE's are bad. I guess it is a know problem. When I brought mine in they switched them out with an updated part. If you do a search you will see a lot of threads on this topic.
Old 07-23-2008, 11:29 PM
Tylus's Avatar
Tylus Tylus is offline
Nuclear Machinist Mate
Tylus has a superb reputationTylus has a superb reputationTylus has a superb reputationTylus has a superb reputationTylus has a superb reputationTylus has a superb reputationTylus has a superb reputationTylus has a superb reputationTylus has a superb reputationTylus has a superb reputationTylus has a superb reputation
when the IWE goes bad...or the vacuum pump fails
the front hubs fail engaged. so if it was an IWE problem, you would be in 4x4
check your fuses. I'm betting the relay that tells the IWE to break vacuum isn't working. You can also try taking the vacuum lines loose at the IWE themselves. if the hubs engage and 4x4 works, you know it's an electrical issue somewhere...most likely at the t-case
Old 07-24-2008, 02:49 PM
Twinsdad98 Twinsdad98 is offline
Twinsdad98 is starting off with a positive reputation.
I wonder if the 09s will be any better!!!
Old 07-24-2008, 09:14 PM
Tylus's Avatar
doubt it...system works pretty good with just a few hiccups here/there
remember those auto 4x4 hubs that were used from 92-96 F/E series? they had some issues also, but worked 99% of the time like our IWE do
body swap Michael L 1997 - 2003 F150 8 05-16-2016 09:31 PM
4by4 not working Shannon pierce 1999 - 2003 7.3L Power Stroke Diesel 2 06-29-2015 10:16 PM
nervous 79 guy 1973 - 1979 F-100 & Larger F-Series Trucks 9 08-27-2011 11:50 PM
Anywhere to go four wheeling in Nashville legally? freekyFX4 Tennessee Chapter 1 01-14-2011 01:41 PM
Crew Cab Frame CrewCabCOE 1973 - 1979 F-100 & Larger F-Series Trucks 5 01-10-2005 05:35 PM
Tags
2004, drive, f150, f150fourwheeldrive, ford, problems, wheel
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
