Go Back   Ford Truck Enthusiasts Forums > Diesel > Bio-diesel, Propane & Alternative Diesel Engine Fuels
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
Bio-diesel, Propane & Alternative Diesel Engine Fuels SPONSORED BY:
  #1 (permalink)
Old 07-23-2008, 06:14 PM
tex25025's Avatar
tex25025 tex25025 is offline
Garage is empty, add now
tex25025 has much to be proud oftex25025 has much to be proud oftex25025 has much to be proud oftex25025 has much to be proud oftex25025 has much to be proud oftex25025 has much to be proud oftex25025 has much to be proud oftex25025 has much to be proud of
Going B-20(all they have here, would go higher)
Due to the fact that my truck is starting to idle rougher since all the stations around here have now got ULSD, I've decided to go with B20 to help do away with the rough shaking idle(bad thing is it's at the already expensive stations so even though B20 is cheaper compared to their no. 2 diesel, it's about the same as the other stations that are cheaper). Now here comes the question, I know about every 2 to 3 fillups, I should change the fuel filter, however, one of my 2 fuel filters is a FASS filter, so how often should that one be changed out? Should I maintain the double life span of it's changes so after every 4-6 fill ups swap out the FASS fuel filter or should I still do the 2-3 fillup scenerio?
__________________
'06 6.0L Turbo Diesel King Ranch DRW
2010 Platinum F-150
  #2 (permalink)
Old 07-24-2008, 06:39 AM
Pocket's Avatar
Pocket Pocket is offline
Pocket has much to be proud ofPocket has much to be proud ofPocket has much to be proud ofPocket has much to be proud ofPocket has much to be proud ofPocket has much to be proud ofPocket has much to be proud ofPocket has much to be proud ofPocket has much to be proud ofPocket has much to be proud of
It's only the first several tanks that you have to watch the filters carefully. After that, your filter changes should go back to the normal maintenance schedule.
However, ULSD doesn't leave as many deposits behind as LSD did. Plus your truck is still fairly new, so you probably have very few deposits in the fuel system, if any. Probably not going to be much for bio to clean out.
__________________
Curtis
2002 F-250 PSD
Gambling with 250/200's on PMR's
478hp/851tq on Haller's dyno - 7/28/12
Your connection to the Colorado diesel community.
  #3 (permalink)
Old 07-24-2008, 11:59 PM
CheaperJeeper's Avatar
CheaperJeeper CheaperJeeper is offline
CheaperJeeper is gaining momentum as a positive member of FTE.
I wish I could readily get B20. The best I can do is B5 at the local Safeway. They started out selling B20, but due to all the warranty issues for the newer rigs (anything over B5 can void some or all of their fuel injection system warranties) they dialed it back to B5....
BTW, back when I could get B20 I burned it in both my trucks (both 86 models) - one of them for close to a year - and never had to do a single extra filter change....
__________________
84 Jeep Cherokee Chief 2-door 4WD - 4.3 Olds V6 diesel, 4.56 gears. Turbo coming soon.
84 Mercedes 300CD Turbo. Bone stock daily driver
86 F250 Super Cab 4x6 (dually), 7.3 Banks TURBO, SMF & ZF5-47, 4.10 gears, 3" Banks straight-pipe exhaust. Mileage unknown
  #4 (permalink)
Old 07-26-2008, 12:16 AM
adambomb's Avatar
adambomb adambomb is offline
2005 Ford F-350
adambomb has a good reputation on FTE.adambomb has a good reputation on FTE.
TEX-
the reason the fuel filters plug after using biodiesel is because it acts as a cleaning agent and will fully clean your tank and fuel system. how many miles are on your truck? if you have low miles and have used additives and good clean diesel i don't think there will be much stuff for the biodiesel to clean out. also you are only using b20 so it will not clean as much and as fast as b100. keep an eye on fuel pressure gauge and that should give you a insite on if your filters are clogging.
__________________
2011 Escape Limited v6 (Loaded) ESP 7yr/65k and Full Ford Maintenance Plan
2005 F350 6.0 (modded) ~450rwhp/900+ft/lb tq
1999 F350 7.3 (normal mods + 13" King Suspension on 40's)
1998 F150 (basic mods + 7" Suspension on 35's/Prerunner fiberglass and skidplace)
1994 Bronco (normal mods + 9" Coil Suspension on 35's)
  #5 (permalink)
Old 07-26-2008, 06:30 AM
tex25025's Avatar
I know the reasoning behind the fuel changes and that they are in the initial usage of biodiesel. I was concerned with how the FASS fuel filters handle it versus the stock filture. On regular diesel, FASS filters will last about twice the time that stock ones will, so I was wondering if that would carry over to biodiesel or not for the initial usage.
__________________
2010 Platinum F-150
  #6 (permalink)
Old 07-26-2008, 07:54 AM
adambomb's Avatar
2005 Ford F-350
i talked to FASS when i first got my fuel system and they said that their set up was 100% biodiesel compatible. i forgot to ask about the filters though...
__________________
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
