quick help please : 1990 F250 5.8 belt routing
Old 07-23-2008, 10:41 AM
DJdemon6696's Avatar
DJdemon6696
DJdemon6696 is offline
any one can tell me or show me a diagram how the belt runs in the accesories
Old 07-23-2008, 11:48 AM
McLeod's Avatar
McLeod
McLeod is online now
There should be a diagram on a sticker under the hood.
Old 07-23-2008, 04:30 PM
F150xlt's Avatar
F150xlt
F150xlt is offline
A/T in the diagram is the belt tensioner.
Old 07-24-2008, 10:10 AM
alxsnmr's Avatar
alxsnmr
alxsnmr is offline
Should be the same as my bronco with the belt runing the parameter but the spine of it looping around water pump to the ribs around the crankshaft. Simply put, ribs to to the pulley grooves, around the parameter, flat side to the flat pulleys so that those pulleys are to the outside of the belt. The Water pump is outside the run from the crank to the power steering pump. The tensioner is outside the run from the altenator to the a/c compressor, or A/C delete pulley.
Old 07-24-2008, 11:01 AM
kaug23's Avatar
kaug23
kaug23 is offline
While you have the belt off, check the tensioner pulley for any signs of noise or looseness. Mine was tight but when I spun it, it felt like there wasn't any grease left in it. A new one was only about 20 bucks at Ford, and the noise I always thought came from the alternator was instantly gone. Just remember, the bolt holding it on is LEFT handed thread.
1badCTS
22
01-21-2021 04:15 PM
Keg1973
04-13-2015 07:11 PM
grasfarmr73
11-14-2014 01:05 PM
Vashon Islander
08-23-2014 09:01 AM
tomn
09-15-2001 06:27 AM
Quick Reply: quick help please : 1990 F250 5.8 belt routing
