Easy ways to to get horse power gains
I have a 2003 HD supercharged i put a new cold air intake (C&L)in, inlet pipe(C&L) , throttle body(big oval) , and upper intake (C&L)in with a diablo preditor tuner. i would like to put a lightening pulley and belt in to give me the extra 40hp and 25torque because i was told that was the only engine power difference between the trucks. im looking for any suggestions for power upgrades nothing like nos but things like exhausts, fuel injectors, etc. also if anyone knows of any good shops around st. louis that would be helpful.
We all know we're NEVER stop modifying our trucks, so no budget can contain the continual modding brought about by that pesky bug!
Drop the carrier bearing...go with a one piece driveshaft!
Stewart
RPM outlet has way, way, WAY too many complaints about their business practice, their ripping people off practice, their unethical behavoir practice, to even consider telling someone to check them out.
Heck, LightningRodder forum has an announcment at the top of the Gen 2 forum page WARNING people not to do business with RPM Outlet. Mainly for the newbs who don't know better, but it's still a big warning none-the-less.
SVT Performance made a public posting that RPM Outlet was being dropped as a Supporting Vendor because of their BS way of doing business and ripping people off.
Stewart
if you live in st louis find stegmeier they do porting and polishing of the intake sys and your superchager they also dyno tune lightings which is the best way to tune your truck. buying a ready made tune is not the way to go. you need a sct hand held tuner most of the dyno speed shops use theur soft ware.
installed the following onmy lighting.
1. air raide cold intake.
2. changed mass air sensor
3. c&l plunim
4. accufB throttle body.
5. matco idler kit
6. matco 6# lower pulley.
7. entire intake sys sent to stegmier in st louis for porting and polishing,including the sc.
8. bassani cat back exaust sys w/two cqts only.
9 t 6 cold plugs.
10. transmiison valve body from chickenears.com
11. dyno tuned at a ford speed shop with a in floor dyno using a act excal 2 hand held and act software on the computer they use which includes fuel/air readings.
all of this is bolt on end result my 02 lighting has 422hp at the rear wheels.
3. c&l plunim
5. matco idler kit
9 t 6 cold plugs.
