You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join our community today!
I have a 2003 HD supercharged i put a new cold air intake (C&L)in, inlet pipe(C&L) , throttle body(big oval) , and upper intake (C&L)in with a diablo preditor tuner. i would like to put a lightening pulley and belt in to give me the extra 40hp and 25torque because i was told that was the only engine power difference between the trucks. im looking for any suggestions for power upgrades nothing like nos but things like exhausts, fuel injectors, etc. also if anyone knows of any good shops around st. louis that would be helpful.
Budget im unsure on but not looking to exceed $2000 as of right now i just bought a new pulley which is next to go on i do need to replace the spark plugs and carrier barring.
i would look at rpmoutlet or lightning force performance. you can get a package deal for a good price and most of the stuff you can do yourself. what size pulley do you have?
ya i heard about that on rpmoutlet but i have order some stuff threw them and i didnt have any problems
Yep, there are a few of you kind of people around. But like a solar eclipse, they are rare.
RPM outlet has way, way, WAY too many complaints about their business practice, their ripping people off practice, their unethical behavoir practice, to even consider telling someone to check them out.
Heck, LightningRodder forum has an announcment at the top of the Gen 2 forum page WARNING people not to do business with RPM Outlet. Mainly for the newbs who don't know better, but it's still a big warning none-the-less.
SVT Performance made a public posting that RPM Outlet was being dropped as a Supporting Vendor because of their BS way of doing business and ripping people off.
DO NOT USE RPM OUTLET!
Stewart
__________________ The Brotherhood of FTE <-click the link 1999 F150 Lightning: WMS built block, 6lb lower, Monsterbox, Truetrac, CF driveshaft 1999 PSD F250 SC 4x4: 38R, Stage 2's, T-500, JW trans, Live Tuned, lotsa Riffraff stuff 2000 PSD Excursion 4x4: 38R, JW trans, F5, MBRP, AFE, OBA and Pre-Pump, V & B codes Never Fry Bacon NAKED!
if you live in st louis find stegmeier they do porting and polishing of the intake sys and your superchager they also dyno tune lightings which is the best way to tune your truck. buying a ready made tune is not the way to go. you need a sct hand held tuner most of the dyno speed shops use theur soft ware.
__________________
ckirwan514 96 white sport 351 sold. got a 2002 lighting now and love it
i should also mention that i still have a diablo sport but i am getting a sct xl as i am moving to the portland area an d it is easer to find a dyno tuner with sct soft ware.as far as hp goes i have 422 hp at the rear wheels done with all bolt mods and a dyno tuner.
__________________
installed the following onmy lighting.
1. air raide cold intake.
2. changed mass air sensor
3. c&l plunim
4. accufB throttle body.
5. matco idler kit
6. matco 6# lower pulley.
7. entire intake sys sent to stegmier in st louis for porting and polishing,including the sc.
8. bassani cat back exaust sys w/two cqts only.
9 t 6 cold plugs.
10. transmiison valve body from chickenears.com
11. dyno tuned at a ford speed shop with a in floor dyno using a act excal 2 hand held and act software on the computer they use which includes fuel/air readings.
all of this is bolt on end result my 02 lighting has 422hp at the rear wheels.
__________________
