Go Back   Ford Truck Enthusiasts Forums > Diesel > 2011 6.7L Ford Diesel
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
2011 6.7L Ford Diesel Discuss the upcoming Ford Powerstroke 6.7L diesel engine
Is F-150 Still King?
  #76 (permalink)
Old 12-02-2008, 04:51 PM
JIM_C's Avatar
JIM_C JIM_C is offline
JIM_C is gaining momentum as a positive member of FTE.
They need better emissions technology. The emissions junk is what breaks and that screws up other expensive parts (except maybe for clogged oil coolers leading to EGR cooler failure). If it's expensive, but works, that's cheaper than several warranty claims for less expensive crap that breaks AND lost market share of piffed off owners who buy something else.
__________________
2003 F250 CC LB 4x4, 6.0 with auto
  #77 (permalink)
Old 12-02-2008, 05:57 PM
cartmanea cartmanea is offline
cartmanea has a good reputation on FTE. cartmanea has a good reputation on FTE. cartmanea has a good reputation on FTE.
Lower RPM power band, simpler design (which tends to be more reliable). A V10 diesel would be great if they were designing a race truck, but they need to design a truck to work like most people who buy these trucks need. Really what they should do is contract engines from Cummins, problem solved.
__________________
2003 F250 FX4 Sport, 6.0L Diesel, TorqShift Auto
- 4" Donahoe Racing springs, Bilstein shocks,
4.30 Yukon gears, Detroit TrueTrac
- 18x10 Diamo 17 Karats, Cooper STT 35x12.50,
Off Road Tech winch bumper
- SCT Xcal2 with Spartan tunes, ISSPRO EV2 Gauges (Pyro, Fuel PSI, Boost)
  #78 (permalink)
Old 12-02-2008, 06:43 PM
origcharger origcharger is online now
origcharger is gaining momentum as a positive member of FTE. origcharger is gaining momentum as a positive member of FTE.
They should build 2 inline 4s sharing a common crankcase.
__________________
2004 E-450 6.0 139,000 miles
7,500 mile, 15 quart oil changes, 5W-40 Rotella.
UOAs consist of checking for metal on drain plug magnet. All stock, no mods. Dyed fuel with no additives. Never been reflashed.
Total parts replaced;
one EGR valve.
  #79 (permalink)
Old 12-02-2008, 07:09 PM
Lead Head Lead Head is offline
Lead Head has a good reputation on FTE. Lead Head has a good reputation on FTE. Lead Head has a good reputation on FTE.
Quote:
Thats bullcrap, you should know that. The *ONLY* thing that makes most inline 6s have more low end torque is that most of them have a longer stroke then bore. You make a long stroke V8 with a smaller bore, and it will too have gobs of low end. International's version of the 6.4 makes its peak torque of 620 ft-lbs@1400 RPM. The amount of cylinders and how they are arranged means nothing. Freight trains often use V16 and V12 diesels, so going by your logic they should be 6000 RPM screamers right? No. They make peak HORSEPOWER at around 850 RPM
__________________
- Ian
1987 Ford Ranger XLT 4x4 2.9
Needs a lot of work, including some rot on the body, but shes getting there.
  #80 (permalink)
Old 12-02-2008, 08:29 PM
Quote:
Thats not even a fair example, those engines have HUGE displacement. Given the same displacement, more cylinders means less low end. Designers generally keep the bore and stroke relatively square, so in a standard engine design, fewer cylinders means a longer stroke.
__________________
  #81 (permalink)
Old 12-02-2008, 08:39 PM
tjthegreat tjthegreat is offline
tjthegreat is starting off with a positive reputation.
less cylinders less problems
__________________
92 F-150 300I6/M5OD/3.08/64k
77 F-150 302/V8/3.55/224k
88 Chevy2500/350/4.11/179k
98 F-150 4.6/3.55/112k(sold)
  #82 (permalink)
Old 12-02-2008, 09:05 PM
Glad you skipped right over the part about the International MaxxForce (6.4) making 620 ft-lbs @ 1400 RPM. The 6.7 Cummins, which has a displacement advantage generates 650 ft-lbs of torque @ 1500 RPM.
So the 6.4 has less displacement, more cylinders but just as much low end. Now the tune for ford makes significantly more HP and 20 ft-lbs more torque, but at 2000 RPM. Of course this does not tell the whole story because I do not have a Power curve of the Ford 6.4.
__________________
- Ian
  #83 (permalink)
Old 12-02-2008, 11:34 PM
Different cams different fueling tables. Don't just show one example and ASSume they all fit that trend.
__________________
  #84 (permalink)
Old 12-03-2008, 09:13 AM
mizzitch mizzitch is offline
mizzitch is starting off with a positive reputation.
The typical v10 makes more torque at lower rpm than an equivalent v8. Given the choice I would prefer the 72 degree firing of a v10 over the 90 deg of a V8.
  #85 (permalink)
Old 12-03-2008, 03:12 PM
Ford V10, same stroke and bore as the 5.4, Makes peak torque 500 RPM lower then the 5.4, makes peak HP 250 RPM lower. Same thing with the old Dodge Ram V10, essentially a 360 with two more cylinders tacked on, made peak torque over 1000 RPM lower then the 360. Back in the late 80 dodge had a 2.2L 4 cyl turbo that made peak torque @ 2400 RPM. The Audi R10 TDI 5.5 Liter V12 Turbo-Diesel RACE CAR generates 811 lb-ft of torque just above idle! Configurations of the cylinder means nothing in terms of power band.
__________________
- Ian
  #86 (permalink)
Old 12-18-2008, 10:04 PM
kotarbi kotarbi is offline
kotarbi is starting off with a positive reputation.
No aluminum heads please
The problem with aluminum heads is that its a disimilar metal from the block so the expansion rate is different. After thousands of cooling and heat cycles with the aluminum expanding and contracting faster than the block it can lead to earlier failures than what the typical diesel owner is used to. My local machine shop sees more of these failures with the Duramax than the other brands. I've seen this problem with gas engines also. It's not as bad as it used to be due to better gasket material but it's still a problem. I'm all for a simpler inline design. Less moving parts. I would think it would be cheaper to build? Easier to service. I love my Cummins but wish everyday I could drop my engine in a new Ford. There is just not enough piece of mind for me to buy a new Ford Diesel. I'm not made of money so I have to buy whats the most economical for me.
  #87 (permalink)
Old 01-02-2009, 10:11 PM
duramaximizer duramaximizer is offline
duramaximizer is new and has a neutral reputation at this point.
Sorry, dude I call BS.
Unless your local machine shop is haisley (or a performance machine shop), I bet your local ford dealer does twice as many head gaskets on ford diesels than any machine shop does on a duramax.
  #88 (permalink)
Old 01-04-2009, 05:49 AM
150ford 150ford is offline
150ford is gaining momentum as a positive member of FTE. 150ford is gaining momentum as a positive member of FTE.
I call BS on that as well duramaximizer. Unless you have actual numbers nobody really know for sure. Duramaxes are far from perfect like any other truck.
__________________
BUILT FORD TOUGH
  #89 (permalink)
Old 03-09-2009, 10:05 PM
HoseDog HoseDog is offline
HoseDog is starting off with a positive reputation.
Quote:
Originally Posted by PowerStrokeHD View Post
The hood does come over the top of the grill. The grill is not attached to the hood like the current 08's...
They still haven't inverted the headlight assy. Looks like it's nappin'.
__________________
HoseDog
'95 F-250 PSD 4x4, Reg cab - Still Stock (so far), Still Happy
  #90 (permalink)
Old 03-16-2009, 04:26 PM
poppie poppie is offline
poppie is starting off with a positive reputation.
-----------------Here's the issue with the 6.0,may be the same with the 6.4,stay with this video past the valve talk and get too the head bolt's , , this say's a lot about IHC.
__________________
2002 F350 4 door Dually XLT lariat PSD Crew Cab 4R100 4.10 VDH4 Prepump, In-Tank, Crossover,Tymar air intake, Edge Evolution, Magellan 6000T GPS, White Night backup light's, DPPI Guages, Walker "Big Truck" Muffler, b&w turn over hitch, 2007 expy Eddie Bauer,redfire&tan,power fold rear seat's.
My truck and 5er.
Tags
1997lincoln , 67 , change , cummins , diesel , ford , gasket , head , markviii , problems , scorpion , scrorpion , solved , specs , vs
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
