Go Back   Ford Truck Enthusiasts Forums > Diesel > 2011 6.7L Ford Diesel
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
2011 6.7L Ford Diesel Discuss the upcoming Ford Powerstroke 6.7L diesel engine
Is F-150 Still King?
  #61 (permalink)
Old 10-05-2008, 03:03 AM
cartmanea cartmanea is offline
cartmanea has a good reputation on FTE. cartmanea has a good reputation on FTE. cartmanea has a good reputation on FTE.
Quote:
Originally Posted by DJR96 View Post
Intake manifolds could be fed from two exits from the intercooler, one each side. That would simplify that.
Yeah, I suppose if they changed the tanks to be on the top and bottom like a radiator you could have one outlet on each side.
__________________
2003 F250 FX4 Sport, 6.0L Diesel, TorqShift Auto
- 4" Donahoe Racing springs, Bilstein shocks,
4.30 Yukon gears, Detroit TrueTrac
- 18x10 Diamo 17 Karats, Cooper STT 35x12.50,
Off Road Tech winch bumper
- SCT Xcal2 with Spartan tunes, ISSPRO EV2 Gauges (Pyro, Fuel PSI, Boost)
  #62 (permalink)
Old 11-29-2008, 10:12 PM
2 stroke man's Avatar
2 stroke man 2 stroke man is offline
2 stroke man is starting off with a positive reputation.
you gotta be kidding me. all this high-tech crap sucks, and comes with an extremely high price tag. why dont ford wise-up and get something like the freaking DT466 in those puppies? it is a simpler, inline with big power, and super reliable, and already meeting EPA standards. i LOVE both my 7.3's but its time they ditch the V-blocks. no longer economical.
and the aluminum heads-be prepaired for the saga like with the duracracks. head gaskets at 100,000 miles
__________________
GOT MY CAT!
2002 Powerstroke 7.3
1997 Powerstroke 7.3
1990 F700 Dump truck ford 6.6 diesel with garret turbo
  #63 (permalink)
Old 11-30-2008, 11:04 AM
rob_nc rob_nc is offline
rob_nc is gaining momentum as a positive member of FTE.
What the hell have you been smokin? The Dt466E is too BIG to fit under the hood of a light duty p/u. Also, it doesn't yet meet EPA2010.
  #64 (permalink)
Old 11-30-2008, 07:37 PM
i know it would take some work. but all i meant was something along those lines to get us back to more basic good old reliable and not so high tech engines. i want someything like my 7.3 that has plenty of power and is still moderately simple that will still be working years away. look at my old 7.3 for instance. i gross 28,000-33,000 on a regulat basis, and at 11 years old and 190,000+ miles shes still goin strong. these newer trucks arent economical nor logical for a workin man
__________________
GOT MY CAT!
  #65 (permalink)
Old 12-01-2008, 02:06 AM
rollerstud98 rollerstud98 is offline
rollerstud98 is starting off with a positive reputation.
Rantings of a man who can't afford new technology.
  #66 (permalink)
Old 12-01-2008, 12:15 PM
tjthegreat tjthegreat is offline
tjthegreat is starting off with a positive reputation.
i do like the power number,but it still sounds expensive as hell
__________________
92 F-150 300I6/M5OD/3.08/64k
77 F-150 302/V8/3.55/224k
88 Chevy2500/350/4.11/179k
98 F-150 4.6/3.55/112k(sold)
  #67 (permalink)
Old 12-01-2008, 09:08 PM
Lead Head Lead Head is offline
Lead Head has a good reputation on FTE. Lead Head has a good reputation on FTE. Lead Head has a good reputation on FTE.
Except now they are called the MaxxForce DT engines, there is nothing simple at all about them. Sequential VGT Turbos, High Pressure Common Rail injection, DPF, EGR, etc, etc..! I also doubt all this "high-tech crap" will raise the price of the engines much. Consider this - The old-school simple P7100 inline injection pump on the Dodge cummins will set you back about $1150 for a new one. While the "high-tech crap" CP3 high pressure fuel pump for the newer common rail diesels is about $749.
V engines are no less economical then Inlines.
__________________
- Ian
1987 Ford Ranger XLT 4x4 2.9
Needs a lot of work, including some rot on the body, but shes getting there.
  #68 (permalink)
Old 12-01-2008, 09:50 PM
Well, actually there is more loss associated with the increased number of moving parts in a V8 as opposed to an I6, but the difference is really negligible.
__________________
  #69 (permalink)
Old 12-01-2008, 11:22 PM
origcharger origcharger is offline
origcharger is gaining momentum as a positive member of FTE. origcharger is gaining momentum as a positive member of FTE.
Todays MaxxForce DT does not have sequential turbos or high pressure common rail injection.........
__________________
2004 E-450 6.0 137,500 miles
7,500 mile, 15 quart oil changes, 5W-40 Rotella.
UOAs consist of checking for metal on drain plug magnet. All stock, no mods. Dyed fuel with no additives. Never been reflashed.
Total parts replaced;
one EGR valve.
  #70 (permalink)
Old 12-02-2008, 06:51 AM
Quote:
Thought it did? Must have been one of their other engines then? Edit: Looks like it is the Maxxforce 11 and up series that has common rail and sequential turbos. My point is still valid however, even more so since the HEUI systems is *technically* more complex then common rail, and that even Class 8 engines still have the "high-tech crap" that the Current 6.4 has and new 6.7 will probably have.
__________________
- Ian
  #71 (permalink)
Old 12-02-2008, 09:20 AM
LSchicago2 LSchicago2 is offline
LSchicago2 is starting off with a positive reputation.
Ford should buy Chrysler and scrap most of it. Put the Cummins in the Super Duty, and call it a day.
  #72 (permalink)
Old 12-02-2008, 11:58 AM
hell id be happy with cat
__________________
  #73 (permalink)
Old 12-02-2008, 01:17 PM
mizzitch mizzitch is offline
mizzitch is starting off with a positive reputation.
Ford should build a V10 diesel like the VW Toureg, except bigger displacement.
  #74 (permalink)
Old 12-02-2008, 03:01 PM
No, they should build an I6.
__________________
  #75 (permalink)
Old 12-02-2008, 04:04 PM
Quote:
Why should they?
__________________
- Ian
Tags
1997lincoln , 67 , change , cummins , diesel , ford , gasket , head , markviii , problems , scorpion , scrorpion , solved , specs , vs
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
