Go Back   Ford Truck Enthusiasts Forums > Diesel > 2011 6.7L Ford Diesel
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
2011 6.7L Ford Diesel Discuss the upcoming Ford Powerstroke 6.7L diesel engine
Is F-150 Still King?
  #46 (permalink)
Old 09-06-2008, 03:02 AM
shelbymustang shelbymustang is offline
shelbymustang is starting off with a positive reputation.
that must be some wild intake then
  #47 (permalink)
Old 09-07-2008, 02:05 PM
2003 6.0's Avatar
2003 6.0 2003 6.0 is offline
2003 6.0 is starting off with a positive reputation.
Quote:
Originally Posted by naseflorio View Post
I hope it sucks balls. My 08' will be worth something then.
I really hope your kidding
  #48 (permalink)
Old 09-19-2008, 07:03 PM
bayouboy bayouboy is offline
bayouboy is starting off with a positive reputation.
I read some details in Four Wheeler magazine that said the 6.7 will be rated at 390hp and 720lb ft of torque. I hope this accurate.
__________________
Wifes Truck 2006 F150 Screw, 5.4L 6" Fabtech, 35" Toyo, 20" Wheels
Company Truck 2007 F250 XL Work Truck 5.4L
My Work Truck 08 F250 6.4, enough said.
Familly Hauler 05 Excusion 6.0 4x4
  #49 (permalink)
Old 09-19-2008, 09:48 PM
UGA33's Avatar
UGA33 UGA33 is online now
East Bound & Down!
2006 Ford F-250
UGA33 has a good reputation on FTE. UGA33 has a good reputation on FTE.
Thats what i have read to, but then I read in the new Cummins (I mean Diesel) Power magazine that the 2010 D/Max will be over 400 horses!
__________________
2006 F-250 Lariat FX4 CC/SB
*6L Power Stroke-SCT X3
*MBRP Exhaust-Autometer Gauges
*Coolant Filter-High Idle Mod-Leveling Kit
  #50 (permalink)
Old 09-19-2008, 09:55 PM
PowerStrokeHD PowerStrokeHD is offline
PowerStrokeHD has a great reputation on FTE. PowerStrokeHD has a great reputation on FTE. PowerStrokeHD has a great reputation on FTE. PowerStrokeHD has a great reputation on FTE.
Quote:
Those numbers may end up turning out to be a little on the conservative side...
__________________
'04 F-250 Harley-Davidson 6.0L CC SB
  #51 (permalink)
Old 09-19-2008, 11:27 PM
AndysFords AndysFords is offline
AndysFords is starting off with a positive reputation.
Aluminum heads, new designs, less emissions, more horsepower, more mpg??? What do they want out of these engines. You can't have it all. These companies are putting too much strain on these new engines, you can't get but so much out of them, something is going to tear up. IMHO, I don't think these engines are going to worth a quarter, especially not when they first come out. I know for sure that I don't want one.
__________________
1997 F250 Crew Cab 4x4
1988 F350 7.3 Crew Cab 4x4 Dually C6
1984 F250 2 wheel drive 6.9 Extended cab 4 spd manual.
(3) 1986 F350 6.9 Diesel
1983 F350 Diesel (3) 1976 F250 390 4x4
  #52 (permalink)
Old 09-19-2008, 11:56 PM
rollerstud98 rollerstud98 is offline
rollerstud98 is starting off with a positive reputation.
I wouldn't have any problems getting the first one off the assembly line myself. I love knew products and especially diesel engines. My early 6.0 is still fantastic after 210k km's.
  #53 (permalink)
Old 09-20-2008, 02:02 AM
Diesel nut's Avatar
Diesel nut Diesel nut is offline
Diesel nut is gaining momentum as a positive member of FTE.
I agree with Andy, the manufacturers are asking way to much out of these engines. 400 hp is rediculous for a pickup. It just costs too much money to build the rest of the drive to handle it and that cost is passed on to me and you. I think 250-300 hp is still plenty. If you really need that much power then buy a semi.
__________________
'01 F550 4wd psd, '99 F150 Lariat 4x4 3.55 LS extcab shortie auto, Hedman shorties, true dual straights. This is what happens when you let an old fart run the grain cart.
  #54 (permalink)
Old 09-20-2008, 08:37 AM
tex25025's Avatar
tex25025 tex25025 is offline
tex25025 has a great reputation on FTE. tex25025 has a great reputation on FTE. tex25025 has a great reputation on FTE. tex25025 has a great reputation on FTE. tex25025 has a great reputation on FTE.
Quote:
In all honesty it depends on what your towing and where you towing it that helps determine if the hp/tq numbers for what you listed are enough to handle it. Now yes the surrounding truck also has to be able to handle it, but just because 250-300 hp is good enough to handle Iowa terrain while towing doesn't really mean that it could handle everywhere's terrain. Just like a four banger might do wonderful in some locations, but crappy in others because of the terrain.
I'm pretty sure I know the point that you trying to make but it's not that simple as that unfortunately.
__________________
'06 6.0L Turbo Diesel King Ranch DRW 4.30 Gears
Spartan Stage 1 Towing Injectors
Spartan 64mm Non-VGT Turbo
Fluidampner
Headstuds
Beta Spartan Phalanx
Fuel Regulated Return
FASS 150/180
Suncoast Heavy Duty Torqshift Rebuild
5" Straight-Piped MBRP Exhaust
Tranny, EGT, Boost, and Fuel PSI C2 Gauges
Water Temp, Oil PSI, Volts Antique Beige Gauges
  #55 (permalink)
Old 09-21-2008, 11:36 AM
2003 6.0's Avatar
Quote:
Nice to hear about another great 6.0
  #56 (permalink)
Old 09-21-2008, 12:30 PM
JMac444 JMac444 is offline
JMac444 is starting off with a positive reputation.
Agreed only so much you can tow with these trucks regardless of the power. Its cool you have 600hp doesnt mean you can tow 80000lbs and control it. All i know is 20 years from now the ol 7.3L will still be makin noise under the hood.
__________________
2002 F-350 SD EC/SB SRW Lariat 7.3L 4r100 4x4
07 Heated and Lighted Chrome Mirrors
08 Tailgate, Lights, Diff Cover
4" MBRP T-304 Turbo Back
Isspro Boost and EGT Gauges
  #57 (permalink)
Old 09-26-2008, 05:37 PM
Big Bad Big Bad is offline
Big Bad is gaining momentum as a positive member of FTE. Big Bad is gaining momentum as a positive member of FTE.
I wonder how accurate that article is?
I heard there was a "no pushrods" internal policy at Ford for new engines.
Hmm...
  #58 (permalink)
Old 09-27-2008, 01:40 PM
J.T. Guitar J.T. Guitar is offline
J.T. Guitar is starting off with a positive reputation.
Color me skeptical... I'm glad I have a 2009 American made Navistar 6.4 on it's way to me right now.
There's a reason the big three have always gone outside for diesels.
__________________
Socialism is a philosophy of failure, the creed of ignorance, and the gospel of envy, its inherent virtue is the equal sharing of misery. Winston Churchill
  #59 (permalink)
Old 09-27-2008, 02:11 PM
IB Adrian's Avatar
IB Adrian IB Adrian is offline
Administrator
2005 Ford Falcon
My Garage
IB Adrian has a superb reputation IB Adrian has a superb reputation IB Adrian has a superb reputation IB Adrian has a superb reputation IB Adrian has a superb reputation IB Adrian has a superb reputation IB Adrian has a superb reputation IB Adrian has a superb reputation IB Adrian has a superb reputation IB Adrian has a superb reputation IB Adrian has a superb reputation
Quote:
Originally Posted by clux View Post
This makes so much sense for a turbocharged engine. I'm trying to visualize what the engine will look like, you think there will be intake runners to each cylinder or some type of manifold on each side?
The industrial diesels I have had to work on - all have this design.
For packaging reasons, its much neater, you have have the turbo's sitting in the valley between the two banks, close to the exhaust ports.
Especially given where the Powerstrokes have always had their turbo's it makes a lot more sense.
This is one of the Cummins generators that I was referring too - (obviously the packaging won't be so neat - they will still need an intercooler on a PSD!)
__________________
Adrian
FTE Guidelines
Quote:
Originally Posted by WhëëlMå1
... he is a mouthy broad.
  #60 (permalink)
Old 10-04-2008, 08:34 PM
DJR96's Avatar
DJR96 DJR96 is offline
DJR96 is starting off with a positive reputation.
Wink
Valley exiting exhaust makes a lot of sense. Much shorter path to turbo. Less heat loss under bonnet. Less heat into firewall. Possibly shorter overall engine length. I wonder if the turbo will be a dual entry unit like some of the old Cat 3208's. Would be logical.
Intake manifolds could be fed from two exits from the intercooler, one each side. That would simplify that.
__________________
Cheers, Dave. RCV Supertourer 6.0 V8 TDi.
Project build:-
http://www.4wdmonthly.com.au/forum/s...ad.php?t=36370
Donations:-https://www.paypal.com/cgi-bin/websc...ton_id=5829239
Tags
1997lincoln , 67 , change , cummins , diesel , ford , gasket , head , markviii , problems , scorpion , scrorpion , solved , specs , vs
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
This forum is owned and operated by Internet Brands, Inc., a Delaware corporation. It is not authorized or endorsed by the Ford Motor Company and is not affiliated with the Ford Motor Company or its related companies in any way. Ford® is a registered trademark of the Ford Motor Company.
