Go Back   Ford Truck Enthusiasts Forums > Diesel > 2011 6.7L Ford Diesel
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
2011 6.7L Ford Diesel Discuss the upcoming Ford Powerstroke 6.7L diesel engine
Is F-150 Still King?
  #31 (permalink)
Old 07-30-2008, 02:30 PM
a-rod's Avatar
a-rod a-rod is offline
a-rod is gaining momentum as a positive member of FTE. a-rod is gaining momentum as a positive member of FTE.
The only thing I dont like about this is that its being built in Mexico..
__________________
Adam - - Collision/Refinishing Tech
2002 7.3 POWERSTROKE
100,000 miles
Straight Pipe, 6637, HPX line, pryo gauge, Foil Delete, WW, 6.0 IC + TC. Superchips Tuner.
F-350 Rear Blocks, Leveling kit
  #32 (permalink)
Old 07-30-2008, 02:56 PM
secondarychaos's Avatar
secondarychaos secondarychaos is offline
secondarychaos is starting off with a positive reputation.
Quote:
X2... it's really a shame.
I personally like the HP that the new trucks are coming with, so if you ask me, they should build the MPG and longevity around that. It can be done, we all know that.
__________________
96 powerstroke
Tuned by Power hungry
  #33 (permalink)
Old 08-01-2008, 01:06 AM
woodsman1991 woodsman1991 is offline
woodsman1991 is starting off with a positive reputation.
Too bad they can't just say, "Screw you Mr. EPA. We're making fuel efficient, extraordinarily powerful trucks. F you!"
  #34 (permalink)
Old 08-01-2008, 11:08 AM
SUPERDUTY_untouchabl's Avatar
SUPERDUTY_untouchabl SUPERDUTY_untouchabl is offline
SUPERDUTY_untouchabl is gaining momentum as a positive member of FTE.
If they did do that they would go bankrupt from all the fines...
__________________
-Josh
04 F150 4.6l Gryphon Powered 2wd reg cab XL 3:55 LS SISO Flowmaster S40 NCD Customs 2.5" Leveling Kit Burner High Power Fog Lights 285/70/17 BFG A/T KO's
  #35 (permalink)
Old 08-01-2008, 02:27 PM
Sadly.
  #36 (permalink)
Old 08-05-2008, 07:44 PM
RISUPERCREWMAN RISUPERCREWMAN is offline
2007 Ford F-150
RISUPERCREWMAN is starting off with a positive reputation.
I would like the sound of "Ford Scorpion SuperDuty"!...............
  #37 (permalink)
Old 08-05-2008, 08:44 PM
UGA33's Avatar
UGA33 UGA33 is offline
East Bound & Down!
2006 Ford F-250
UGA33 has a good reputation on FTE. UGA33 has a good reputation on FTE.
I saw the spy photos of the 4.4L going in the F150 and it had the Powerstroke badge on top of the fan shroud. Still dont mean they are gonna use it, but heck who knows. I kinda hope they keep it myself
__________________
2006 F-250 Lariat FX4 CC/SB
*6L Power Stroke-SCT X3
*MBRP Exhaust-Autometer Gauges
*Coolant Filter-High Idle Mod-Leveling Kit
  #38 (permalink)
Old 08-06-2008, 06:49 AM
tex25025's Avatar
tex25025 tex25025 is offline
tex25025 has a great reputation on FTE. tex25025 has a great reputation on FTE. tex25025 has a great reputation on FTE. tex25025 has a great reputation on FTE. tex25025 has a great reputation on FTE.
Quote:
Originally Posted by F350-6 View Post
Now if we can just get Ford to quite playing the HP game and focus on longevity and fuel economy we'll be back to what made the diesel what it was.
I do miss the 86 Ford diesels. That was the first vehicle I learned off of and the first one that I legally drove(and illegally when I was learning to drive on the back roads of Kleberg county) thru high school. Jar you to death, but it got wonderful mileage and it would haul anything that you wanted it to, but you just wouldn't get that very fast.
__________________
'06 6.0L Turbo Diesel King Ranch DRW 4.30 Gears
Spartan Stage 1 Towing Injectors
Spartan 64mm Non-VGT Turbo
Fluidampner
Headstuds
Beta Spartan Phalanx
Fuel Regulated Return
FASS 150/180
Suncoast Heavy Duty Torqshift Rebuild
5" Straight-Piped MBRP Exhaust
Tranny, EGT, Boost, and Fuel PSI C2 Gauges
Water Temp, Oil PSI, Volts Antique Beige Gauges
  #39 (permalink)
Old 08-18-2008, 08:21 PM
duramaximizer duramaximizer is offline
duramaximizer is new and has a neutral reputation at this point.
I wonder just how much Ford and Gm are working together behind the scenes?
I haven't heard much about the 2010 duramax lately....I think the new aluminum head designs are going to be awesome.
  #40 (permalink)
Old 09-04-2008, 09:19 AM
northern 7.3 northern 7.3 is offline
Temporarily Deactivated
northern 7.3 is starting off with a positive reputation.
Quote:
Originally Posted by parkland View Post
Super duty i think is fords name ; powerstroke is owned by international.
are you sure about that? i've never seen powerstroke on anything international. only T444E or VT365...etc
  #41 (permalink)
Old 09-04-2008, 10:21 AM
tex25025's Avatar
Ford owns the powerstroke name, not international.
__________________
Fluidampner
Headstuds
FASS 150/180
  #42 (permalink)
Old 09-04-2008, 01:16 PM
JIM_C's Avatar
JIM_C JIM_C is offline
JIM_C is gaining momentum as a positive member of FTE.
Quote:
Correct - Ford owns a trademark registration for "Power Stroke" (two words) in International Class 012 describing engines for land vehicles.
__________________
2003 F250 CC LB 4x4, 6.0 with auto
  #43 (permalink)
Old 09-04-2008, 11:55 PM
naseflorio naseflorio is offline
naseflorio is starting off with a positive reputation.
I hope it sucks balls. My 08' will be worth something then.
  #44 (permalink)
Old 09-05-2008, 12:16 AM
shelbymustang shelbymustang is offline
shelbymustang is starting off with a positive reputation.
were they going to do someting like make so the intake was on the out side and the ex. was in the middle to line up with the turboes better
  #45 (permalink)
Old 09-05-2008, 10:29 AM
cartmanea cartmanea is offline
cartmanea has a good reputation on FTE. cartmanea has a good reputation on FTE. cartmanea has a good reputation on FTE.
Yes, the heads are flipped around with exhaust manifolds on the inside and turbos in the engine valley. Pretty cool idea.
__________________
2003 F250 FX4 Sport, 6.0L Diesel, TorqShift Auto
- 4" Donahoe Racing springs, Bilstein shocks,
4.30 Yukon gears, Detroit TrueTrac
- 18x10 Diamo 17 Karats, Cooper STT 35x12.50,
Off Road Tech winch bumper
- SCT Xcal2 with Spartan tunes, ISSPRO EV2 Gauges (Pyro, Fuel PSI, Boost)
Tags
1997lincoln , 67 , change , cummins , diesel , ford , gasket , head , markviii , problems , scorpion , scrorpion , solved , specs , vs
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
