Climate Control problem... - Ford Truck Enthusiasts Forums
1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Old 07-22-2008, 12:30 PM
wheelz3333 wheelz3333 is offline
wheelz3333 is starting off with a positive reputation.
I have been intermittently having the issue where upon startup the climate control does not startup. I have read the forums and if I turn the lights on and off it reactivates it OK. Can anyone tell me specically what is causing this so I can get it fixed properly as I don't want to keep turning the lights off and on to correct this. Thanks, Rob.
Old 07-22-2008, 12:46 PM
Powerstroke_wannabe Powerstroke_wannabe is offline
Powerstroke_wannabe has a great reputation on FTE.Powerstroke_wannabe has a great reputation on FTE.Powerstroke_wannabe has a great reputation on FTE.Powerstroke_wannabe has a great reputation on FTE.Powerstroke_wannabe has a great reputation on FTE.
Interesting that you posted this today. I had this happen to me for the first time ever yesterday. Start up and climate control is dead. Turn off truck and restart and climate control is OK. I was about to get really ticked because of all days for it to happen was the hottest day of the Summer thus far. I wasn't looking forward to the ride home without AC. As a result, I'm definitely interested in hearing the answer to the cause of this problem and potential fix short of replacing the climate control controller.
Old 07-22-2008, 02:02 PM
BowTieHatr BowTieHatr is offline
BowTieHatr has a very good reputation on FTE.BowTieHatr has a very good reputation on FTE.BowTieHatr has a very good reputation on FTE.
do you guys have ATC?
Old 07-22-2008, 09:16 PM
Quote:
Excuse my ignorance, but what is ATC? If you mean auto temp control, yes.
Old 07-23-2008, 07:49 AM
the control heads did have a problem with a internal relay sticking and supposedly they have been redesigned. i have replaced many of these heads due to the inop issue. the price has come down alot as well.
Old 07-23-2008, 12:40 PM
Are they hard to replace?
Old 07-23-2008, 07:34 PM
fordboy2's Avatar
fordboy2 fordboy2 is offline
fordboy2 is gaining momentum as a positive member of FTE.
So the only option is to replace? Mine did this once back in june and has been fine ever since. What is the price as I may just pick one up to have on hand for when mine decides to finish taking a dump, dont want to be stuck for a long period of time waiting for the darn part.
Old 07-24-2008, 07:41 AM
not hard at all. the instrument finish bezel pops off and depending on options you have multiple connectors to unplug. then 4 screws and 2 connectors.
you will have to check your local dealer for the price as i have noticed prices change in location.
Old 07-26-2008, 06:19 PM
Beerstalker's Avatar
Beerstalker Beerstalker is offline
Beerstalker has a very good reputation on FTE.Beerstalker has a very good reputation on FTE.Beerstalker has a very good reputation on FTE.
Somewhat common problem like BowtieHatr says. Only fix is to replace it. I highly suggest getting it done under warranty if you can. The unit is not cheap ($300+), so I'm not sure if you're going to want to pick one up as a spare.
Climate control quits after startup Alex_B 1997 - 2003 F150 6 01-14-2016 05:23 PM
2011 f250 climate control flakey dwh039 1999 to 2016 Super Duty 1 07-05-2015 01:46 PM
Climate control nikvil 1997-2006 Expedition & Navigator 2 12-21-2014 10:47 AM
Climate Control Head problem action_deez 1999 to 2016 Super Duty 0 11-14-2014 08:08 PM
Climate Control "Eddie_B_Bauer" Cooling, Heating, Ventilation & A/C 7 03-22-2004 10:43 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
