recall 08T01 - all 2008 ford diesels - Page 5 - Ford Truck Enthusiasts Forums
6.4L Power Stroke Diesel Engine fitted to 2008 - 2010 F250, F350 and F450 pickup trucks and F350 + Cab Chassis
  #61
Old 08-04-2008, 08:18 AM
caprang's Avatar
caprang caprang is offline
caprang is gaining momentum as a positive member of FTE.
Has anyone checked on the price of the kit, or the instructions to install? I agree with biz4two about getting this done on my own dime to avoid having problems 400 miles from home. If its an easy install I will do it myself rather than have the dealer do it.
  #62
Old 08-04-2008, 08:26 AM
caprang's Avatar
WOW, all this fuss and I just found out the kit cost $8.26.
The job only calls for .3 labor hours so this seems like a no-brainer!! Anyone out there have a copy of the instructions? Any special tools needed or anything like that?
Less than $10 and a half hour of time to make my radiator worry free? Count me in.
  #63
Old 08-04-2008, 11:54 AM
yukondiesel yukondiesel is offline
yukondiesel is starting off with a positive reputation.
Quote:
Originally Posted by jasfaa View Post
You need to read the TSB. Vloney, is this true? Please correct me if the TSB states differently, you are the only one I trust here. The TSB stated differently than what yukondiesel posted so I am to the point that i don't care anymore. Yukon diesel needed 10 characters. i guess he or she was slow.......... I needed ten periods. I am so sick of this thread. I now know why Vloney is mad. Just trying to help and newbies keep throwing BS out there.
I humbly stand corrected. The information I got was that a senior tech was correcting ALL the trucks on the dealer's lot and I misinterpreted that to mean all trucks. Slow? maybe...falliblle? surely.. well intentioned..certainly.
S O R R Y!!
joe
  #64
Old 08-04-2008, 12:51 PM
Bowstring Bowstring is offline
Bowstring is starting off with a positive reputation.
Just got off the phone with service dept where I bought my truck, they said after checking about installing the venturi kit even at my expense they can't do it until Ford releases them for sale. I guess I tryed to save them having to maybe install a radiator at more $$$$. so be it!!!
  #65
Old 08-07-2008, 01:46 PM
pilotshot pilotshot is offline
pilotshot is starting off with a positive reputation.
Quote:
Bowstring:
I had the venturi gasket kit installed this morning on my job 1 #1 2008 PSD. Ford of Canada would not pay for it but would be at my expense. Since I do a lot of trailer towing I didn't want a radiator breakdown on the road so I paid for the kit and installation.
The venturi kit is 8C3Z 88379 B and the Canadian list is $5.50 and net cost is $4.40. The Service instruction 08T01 states .3 hour to install for unsold Ford PSD's in their lots. My charge was .5 hour of labor. Go figure. I had the technician inspect the radiator for leaks at the tank ends during the venturi installation. He advised me that the rad had no signs of leaks.
  #66
Old 08-09-2008, 04:14 PM
dt75flh's Avatar
dt75flh dt75flh is offline
dt75flh is starting off with a positive reputation.
I had my radiator replaced at 11k miles (job 1 ).....while on my summer vacation we went 4k miles pulling a trailer....60 miles outside of elko on I80 my radiator went out again....same place on the passenger side ...tk now has 22k miles on it...they installed another radiator with the venturi kit...no problems going another 1500 miles towing my trailer but well see if it helps in the long run
  #67
Old 08-25-2008, 07:08 PM
2x6 bulldog's Avatar
2x6 bulldog 2x6 bulldog is offline
2x6 bulldog is starting off with a positive reputation.
I dropped my truck off at the dealer last week with a leaking radiator and to get a reflash. They were fixing all the unsold truck radiators on the lot. They were replacing the radiator and putting in the venturi kit.
  #68
Old 08-25-2008, 07:47 PM
Serg450's Avatar
Serg450 Serg450 is offline
Serg450 has a very good reputation on FTE.Serg450 has a very good reputation on FTE.Serg450 has a very good reputation on FTE.
Venturi kit ??
  #69
Old 08-25-2008, 09:42 PM
The venturi kit is some type of Tee in the degas line that prevents too much pressure in the radiators causing them to leak. This is Fords determination of the cause of the radiator failure. That's all I know.
  #70
Old 08-26-2008, 02:30 PM
Akara1 Akara1 is offline
Akara1 is starting off with a positive reputation.
Took my truck (job 1) in for service about 2 weeks ago, and my SA noticed that my radiator was leaking when I got there. Perfect timing I guess. They put in a new radiator and the venturi kit. Hopefully this doesn't happen again, especially on a long haul with the boat.
  #71
Old 08-27-2008, 06:33 AM
stroke this stroke this is offline
stroke this is new and has a neutral reputation at this point.
Can we change the name of this thread?
  #72
Old 08-27-2008, 10:27 PM
biz4two's Avatar
biz4two biz4two is offline
biz4two has a great reputation on FTE.biz4two has a great reputation on FTE.biz4two has a great reputation on FTE.biz4two has a great reputation on FTE.
Arrow
Quote:
Why? What do you think it should be called?
biz
  #73
Old 08-28-2008, 10:59 AM
66stang351 66stang351 is offline
66stang351 is starting off with a positive reputation.
Quote:
biz
Well, I believe it has been established that the subect Ford Special Service Instruction is not a recall nor does it apply to all 2008 Ford Diesels. Because of that the subjetc of the thread is very misleading. Maybe something along the lines of "Ford SSI 08T01 - Possible radiator issues on some 6.4 diesels"
  #74
Old 08-28-2008, 11:17 AM
Serg450's Avatar
Just my babe out of the shop yesturday, new rad and venturi kit installed. I'm good to go, I hope.
  #75
Old 08-28-2008, 11:33 AM
caprang's Avatar
Quote:
Originally Posted by 66stang351 View Post
Well, I believe it has been established that the subect Ford Special Service Instruction is not a recall nor does it apply to all 2008 Ford Diesels. "
It covers vehicles built from Job #1 through May 15, 2008. I know that isnt ALL 2008 diesels but its gotta be pretty close since they cut production off in June/July.
I dont see how this Tee can hurt anything. I did it myself in 10 minutes.
http://www.ford-trucks.com/forums/77...tallation.html
Does anyone know why 5/15/08 is the cut off? Did Ford start installing these Tee's at the factory after 5/15?
2008-10 recall for steering senix 1999 to 2016 Super Duty 2 02-27-2015 07:28 AM
Recall alert for steering senix 6.4L Power Stroke Diesel 3 02-26-2015 08:20 AM
2008 Escape Electronic Steering Issue!!!!!! eternal_177 Escape & Escape Hybrid 0 08-10-2014 10:37 AM
Recall on 2008-2011 claycomotrucks1991 Escape & Escape Hybrid 1 05-30-2014 11:00 AM
Tags
08, 08t01, 2008, 64, failure, fixed, ford, multi, radiator, recall, start, tee, truck, trucks, unsold, venturi, wrong
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
  • Ask a Question
    Get answers from community experts
What's your question?
Send
