F150 and straight pipe exhaust - Ford Truck Enthusiasts Forums
Old 07-22-2008, 07:36 AM
MichiganHunter MichiganHunter is offline
MichiganHunter is starting off with a positive reputation.
I was wondering if anyone here has maintained there factory cat and just got rid of there stock muffler and put a pice of pipe in place of it? If so how did it sound and did it improve anything?
Old 07-22-2008, 05:19 PM
06 f150 straight pipe
Hmmm, must not be nobody doing this?
Old 07-22-2008, 05:32 PM
DANA60 DANA60 is offline
DANA60 is starting off with a positive reputation.
i had my 4.6 straight pipe for a while. It was just cut off after the cat underneath. It was somewhat loud but not very loud.
Old 07-22-2008, 06:06 PM
rebelyell618's Avatar
rebelyell618 rebelyell618 is offline
rebelyell618 is starting off with a positive reputation.
i dont have an f150 but in these exhust cases where a sound is needed look no further than youtube... lol.. just searching for straight pipe it returned 82 vids so hopefully youll find a similar truck to yours on there.
YouTube - Broadcast Yourself.
this is one way i found the sound i was looking for in an exhaust since everyone is different in what they want. so hope this helps ya
Old 07-22-2008, 06:12 PM
efx4's Avatar
efx4 efx4 is offline
efx4 is gaining momentum as a positive member of FTE.efx4 is gaining momentum as a positive member of FTE.
Before I welded in my new exhaust a couple years ago on my '05 w/ the 5.4, I removed the factory after cat exhaust and ran it that way for about a month. It sounded pretty much like duel exhaust but somewhat raspier. The four cats and the 90 degree bend in one of the factory pipes restrict the exhaust to the point that the exhaust will never be loud without replacing the complete system.
Old 07-23-2008, 09:49 AM
06 and straight pipe exhaust!
Ok thanks for the info, I did go to youtube and found a truck like mine that got rid of the muffler and had a pice of pipe in place of it, Now the ? is, "will this cause any poor performance when trailering or everyday driving" Thanks..
Old 07-23-2008, 11:12 AM
Quote:
you shouldn't lose anything on performance wise just by removing a muffler. I believe since you will still have the factory that will keep the same back pressure that you currently have with the factory setup. the only difference is it will be louder.
Old 07-23-2008, 01:08 PM
matab14's Avatar
matab14 matab14 is offline
matab14 is starting off with a positive reputation.
I have this done on my truck and love it! haha.....It's loud though! Sometimes gets a lil too loud but I dont romp on it alot so it aint that bad. I have the y pipe and dual tips as well.....but just run cats and it sounds good IMO....
Old 07-23-2008, 08:38 PM
F250FarmBoy's Avatar
F250FarmBoy F250FarmBoy is offline
F250FarmBoy is starting off with a positive reputation.
I unbolted mine in front of the muffler and put a glasspack in its place, even welded a tab and used the old mounting hole. Its quiet with a little rumble at start-up and idle, and its not too loud even when down-shifting or passing.
1,000 miles later, no codes and I got 17 mpg last fill-up.
Old 07-24-2008, 07:28 AM
96sherm's Avatar
96sherm 96sherm is offline
96sherm has a spectacular reputation.96sherm has a spectacular reputation.96sherm has a spectacular reputation.96sherm has a spectacular reputation.96sherm has a spectacular reputation.96sherm has a spectacular reputation.96sherm has a spectacular reputation.96sherm has a spectacular reputation.96sherm has a spectacular reputation.96sherm has a spectacular reputation.96sherm has a spectacular reputation.
Quote:
you won't throw codes by removing the muffler. there's no sensors after it. i had a straight pipe with flowmaster super44 on my '02 s'crew. gets quite obnoxious at 18-2500rpms. i had some codes from running catless so i put the MIL eliminators on there, but i don't see them on ebay anymore.
Old 07-25-2008, 11:13 AM
OK so I was on my way this morning to ge that 55 gallon drum cut off and have a piece of pipe installed in place of it, when the guy at speedy muffler said that it may cause a problem and throw the check engine light to come on, he siad there would be no back pressure on the system. So i told him no thanks and left........ WILL THIS HAPPEN?Hope someone can let m eknow, I would like to get the muffler cut off ASAP. Thanks
Old 07-25-2008, 11:43 AM
get you a different muffler shop!!!!!
you will still have the back pressure do to the factory cats still being on the truck.
it will not throw a light since there are zero sensors after the muffler to throw a code. plus there is nothing bad with removing a muffler the only thing a muffler is for is reduction of sound nothing else.
so go find another shop and get that muffler pulled off. lol
Old 07-26-2008, 08:31 AM
Panzerbrumbar Panzerbrumbar is offline
Panzerbrumbar is starting off with a positive reputation.
I just had them weld in a section of pipe in place of the muffler and had them make a turn down right behind the rear axle. I choose this setup because it seems like every pickup around where I live has pipes dangling because of a cheap install and there is nothing more unsightly the big chrome tips that are half rusted plus when I am hooking up a trailer I hate exhaust in my face so I did not want it straight out the back. It is not loud at all to me compared to most pickups I have heard. It does sound nice and a much cheaper alternative to a cat back system.
Old 07-27-2008, 06:36 PM
Frd67cobra's Avatar
Frd67cobra Frd67cobra is offline
Frd67cobra is starting off with a positive reputation.
Don't know your laws up there, but here in Florida no muffler is a sure ticket getter, besides a major annoyance to other drivers sitting next to you at a traffic light having to listen to the racket. How about not putting the truck community in a bad light, and instead get off the wallet and buy a quality performance muffler that will give you the sound you want, be legal, and not irritate other motorists. Just a thought....
Old 07-27-2008, 10:31 PM
96sherm's Avatar
if you still have the 4 cats, no muffler isn't obnoxious...
Ugly Tail Pipes Paule253 1999 to 2016 Super Duty 6 01-29-2017 09:31 PM
Exhaust pipe diameter? zenmaster 1967 - 1972 F-100 & Larger F-Series Trucks 18 05-16-2015 10:59 PM
X pipe into dual muffs? SuperDuty93 1973 - 1979 F-100 & Larger F-Series Trucks 23 02-24-2013 07:44 PM
2000 V10 Y-Pipe ascheperle Modular V10 (6.8l) 3 12-23-2005 08:09 AM
Equalizer Pipe William Exhaust Systems 0 01-29-2003 11:28 AM
Tags
150, 2007, 4x4, 54, 85, buy, exhaust, f150, ford, pipe, pipes, put, staright, straight, systems
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
