Have you registered for your free membership? If not, click here now to register!
Join Our Site - Its free, quick and easy!
Click Here to join.   Click Here for more information
Users Chatting None
Go Back   Ford Truck Enthusiasts Forums > Diesel > 1999 - 2003 7.3L Power Stroke Diesel
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
1999 - 2003 7.3L Power Stroke Diesel Sponsored By:
Is F-150 Still King?
LinkBack Thread Tools
  #1 (permalink)
Old 07-21-2008, 11:17 PM
white Buffalo's Avatar
Buy American!
white Buffalo is gaining momentum as a positive member of FTE.white Buffalo is gaining momentum as a positive member of FTE.
Oil analysis after towing 4,000 miles
Here is my most recent oil analysis after towing our 10,000 lb 31' fifth wheel camper almost 4,000 miles and total driving miles on the oil at 5,934 miles. We towed from Oklahoma-Gatlinburg TN and back, then from Oklahoma to West Whitlock State Park, SD.
I was very happy about the results - especially after adding in the new single shot injectors and having a heavy foot.......
I know, some care about Used Oil Analysis results (UOA) and some don't. For me I'm anal and like to know.......
The 6637 filter did as well as the Ford AIS I had on previously. Silicon at a low 5.
__________________
Rich
2003 F250, T Wildman Tunes, Jon Faubion HD tranny, Swamps 175/146 SS Inj, Van turbo-WW, DI Intercooler, MBRP, 6637, ISSPRO & DiPricol gauges, CCV mod, AIH delete, 6.0 trans cooler, Schaeffer's 15W-40, oilguard bypass, ITP intank & pre-pump, ITP reg return, FStone airbags, Bilsteins,cryoed rotors, hawk pads, Mag-Hytec diff cover. 350hp/692tq
Sponsored Links
To remove this ad, register today!
  #2 (permalink)
Old 07-21-2008, 11:28 PM
PaysonPSD's Avatar
Support FTE
PaysonPSD has a great reputation on FTE.PaysonPSD has a great reputation on FTE.PaysonPSD has a great reputation on FTE.PaysonPSD has a great reputation on FTE.
Rich,
I do care about UOA. I guess I'm anal too. Thanks for sharing. I just took out my AIS and put in a 6637. Nice to see that silicon level is low.
__________________
There is a fine line between a hobby and mental illness. PAA Member 444
MORE - Military Online RElay
  #3 (permalink)
Old 07-21-2008, 11:47 PM
jtharvey's Avatar
Destroking it
jtharvey has a very good reputation on FTE.jtharvey has a very good reputation on FTE.jtharvey has a very good reputation on FTE.jtharvey has a very good reputation on FTE.
Dang Rich, that looks good. Especially consider there's 4000 miles of towing on that oil, and I know from what you told me that some of that towing was pretty tough with the headwinds you were facing.
__________________
Jeremy
2000 F-350 CCLB SRW 4x4, Dropping in a CR 5.9
Check out my progress, here --> Cummins Conversion Update Thread
Conversion Progress Pics:
See My Webshots Albums for more.
  #4 (permalink)
Old 07-21-2008, 11:51 PM
orng1 is starting off with a positive reputation.
I've been kind of nervous after my last few tows. I wanted tol change the oil because I know that the stress of towing does cause havoc on engine. But like you when I check the oil it looks clean as the day I changed it. I've only got 2k miles on it but 1k has been towing.
  #5 (permalink)
Old 07-22-2008, 12:00 AM
big poppa pump's Avatar
Wished it was mine!!!
big poppa pump has a great reputation on FTE.big poppa pump has a great reputation on FTE.big poppa pump has a great reputation on FTE.big poppa pump has a great reputation on FTE.big poppa pump has a great reputation on FTE.
Looks like some good numbers there. Said to increase to 8,000 intervals on 15-40. Thats reg delo oil not synthetic right Rich?
__________________
Mike 2003 f-250 XLT CC 7.3 SRW, SB, auto, 4x4 373 gears S-B cold air intake w snorkel, WW, CCV, SC programmer, Isspro 3 pillar, foil delete, mbrp 4 in duals, stock 16s 285 Yoko,s A-T, Bilsteins, Zoodad, ARE cap, Running lights, CrimeStopper Alarm w remote start, Cobra 29 cb peaked,tuned with dual firesticks. PAA MEMBER 26# 100,000 mile club.
  #6 (permalink)
Old 07-22-2008, 12:06 AM
Buy American!
Schaeffer's series 7000 15W-40 synthetic blend.
Schaeffer's Synthetic Motor Oils for Diesel Engines
__________________
Rich
  #7 (permalink)
Old 07-22-2008, 12:34 AM
I wished we had the Shaeffer,s around here, i been looking for it to no avail. I'll check out your link and see who has it. I run the Rotella full syn. and change at 10,000 and been wanting to get a report on mine, thanks...
__________________
  #8 (permalink)
Old 07-22-2008, 07:51 AM
Buy American!
The best bet is to call the 1-800# and ask for the closest sales rep in your area. If you look on their web site they only list the retail stores. A sales rep will save you 20%...runs about $16 a gallon.
If you are running 10K between oil changes you need to run a UOA in my opinion. The HEUI inj system is tough on oil and can shear the viscosity quicker than a common rail engine. IMO I'd be comfortable running 7K on a syn oil without an oil analysis, but only after establishing some UOA historical results on that specific oil.
__________________
Rich
  #9 (permalink)
Old 07-24-2008, 12:00 AM
toyota hauler's Avatar
toyota hauler is starting off with a positive reputation.
Quote:
In Pa, you def have Walmarts, right?
Just go with Shell Rotella 5W-40 Synthetic in the gallon jugs, that is what i have been running for some time and getting very good oil analysis from Blackstone labs in WI
you could always go to Napa and get Royal purple or try Amsoil, there are many dealers all over the US
good luck!
__________________
2002 F-350 Lariat
7.3 inside
  #10 (permalink)
Old 07-24-2008, 12:15 AM
UP_There's Avatar
Hunter & Gatherer
UP_There has a great reputation on FTE.UP_There has a great reputation on FTE.UP_There has a great reputation on FTE.UP_There has a great reputation on FTE.UP_There has a great reputation on FTE.
good luck!
He does use Rotella syn
Mike...that's a lonnnng ways to go with no analysis! Not saying the oil isn't good enough to do it, but ya gotta check out what's happening with it bro! I'm doin 8,000 miles with Rotella syn with Blackstone telling me to run 9,000. The safe side is worth it to me!
__________________
Travis PAA Member #5.0
2000 F250 4x4 PSD with THE DP-TUNER
"Assorted Goodiez" with LOTS more to come.
Wicked wheel on the way
"Regular Apes have Superchips in their Banana's, RAPED Apes have DP's in theirs"
Roadside Help Network
PMS Starter kit!
  #11 (permalink)
Old 07-24-2008, 04:41 AM
ron's power stroke's Avatar
FORD the rock crusher
ron's power stroke has a great reputation on FTE.ron's power stroke has a great reputation on FTE.ron's power stroke has a great reputation on FTE.ron's power stroke has a great reputation on FTE.ron's power stroke has a great reputation on FTE.ron's power stroke has a great reputation on FTE.
delo 400. less then 10 bucks a gal...stock filtering..i run 3000 miles before it start to darken up and never have the romps in the winter....blackstone said looking really nice at 7000 go to 8500....
__________________
Early 99 7.3 F350 4x4, auto, 99.5 turbo with WW,AFE stage2 5" strait pipe DP Tuner ,17* HPOP sent out to be modified
www.7point3.com
exploded view of a 7,3
mod's & fixes
  #12 (permalink)
Old 07-24-2008, 06:37 AM
Kwikkordead's Avatar
Daddy what's a sparkplug?
Kwikkordead is a splendid one to beholdKwikkordead is a splendid one to beholdKwikkordead is a splendid one to beholdKwikkordead is a splendid one to beholdKwikkordead is a splendid one to beholdKwikkordead is a splendid one to beholdKwikkordead is a splendid one to behold
That report looks great.
__________________
Dan _ + † +
5" Exhaust
1999 F-550 4x4 ZF-6 Tow Rig
1999 VW Jetta TDI
1996 Audi A4 2.8 V6 Quattro
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Terms of Use - Privacy Policy - JOBS
Ford-Trucks.com and Internet Brands, Inc. is not affiliated with the Ford Motor Company.
© 1997-2007 Internet Brands, Inc., Please see our Terms of Use / Privacy Policy
