Transmission Bang Shifting - Overdrive Off Light Flashes
Old 07-31-2008, 04:17 PM
dkf's Avatar
dkf
dkf is offline
Every time an OD light on an Explorer we had was flashing, the trans needed a complete rebuild. The banging is limp mode. BTW, explorer auto transmissions are not great, regardless of year.
Old 07-31-2008, 04:42 PM
danr1's Avatar
danr1
danr1 is offline
<i>and they cant pull a check engine code on my car anyways because its a 95' </i>
If its a "95" then it should be OBD1, you can read the codes yourself with a paper clip or any suitable piece of wire.
Ford Fuel Injection How To Run a Self-Test
Find the EEC test port and then follow the instructions. Have a pencil and paper ready. Make a mark each time the light flashes in groups. ///=3, /////=5, and so on. Your marks would look like this for code 145 / //// ///// on the paper.
The codes will repeat, it may take you a few times to make sure you have it right.
If it has a electrical problem, a solenoid problem the KOEO test will show that, the continuous memory test should also have some information for you. Regardless of the CEL being on or not.
If it is OBD2 then you need a reader, or a buddy with one. If you lived close I'd be happy to pull the codes for you with my laptop. But you don't, so find someone that is close that will. Maybe another poster?
Keep driving it and you will be walking, "guessing" Throwing money at it, money you don't have from the sound of it is not going to correct the problem.
Old 07-31-2008, 05:14 PM
dkf's Avatar
dkf
dkf is offline
A mechanic will have a code reader that can read both OBD1 and OBD2 with the same scanner or you can self test. I didn't have an OBD1 capable reader so I took the 95' to the mechanic, he read the codes with his OBD2 reader right in front of me.
Old 07-23-2013, 06:25 PM
galaflor's Avatar
galaflor
galaflor is offline
Unhappy Clicking noise when shifting gear on 2002 Ford Explorer XLT V8
Just had the transmission serviced and they put in a new torque converter. Car beens driving great for a couple of days and now I hear a clicking sound when hitting break, changing gears to go forward or backwards and hear some type of a stump noise. Motor oil and filter changed and transmission fluid added which was low and flushed. Anyone knows what this is? Thanks
Old 06-30-2016, 07:37 AM
Caleb F.'s Avatar
Caleb F.
Caleb F. is offline
Explorer tranny
What is happening is the computer sees the 3rd gear ratio code and puts itself into LIMP MODE. This is what causes the 1st to 2nd bang shifting. I have a 95 explorer with the same problem. You can keep driving it but take it slow at the 1st to 2nd shift and DO NOT PULL A TRAILER. THESE TRANSMISSIONS ARE NOT DESIGNED TO PULL TRAILERS. IT WILL ONLY RUIN YOUR TRANNY FASTER.
Old 07-01-2018, 09:12 PM
jennobronco's Avatar
jennobronco
jennobronco is offline
overdrive off light just started flashing and its bucking like an actual bronco like jumping gears HELP I am in long Island ford554
Old 07-02-2018, 08:19 AM
Mark Kovalsky's Avatar
Mark Kovalsky
Mark Kovalsky is offline
Received 1,570 Likes on 1,049 Posts
You should fix it.
The first step is to read the codes.
campbell99
1999 to 2016 Super Duty
99
10-28-2023 08:42 AM
tommyl
10-27-2017 09:11 AM
mchild
09-11-2017 10:15 AM
1993ranger
07-21-2016 09:32 AM
mototrig
18
03-22-2016 08:22 AM
Quick Reply: Transmission Bang Shifting - Overdrive Off Light Flashes
