Lightning, Harley-Davidson F-150, Roush F-150 & Saleen F-150 SVT Ford F150 Lightning, Roush, Saleen and other performance F150's
160 thermostat
Old 07-21-2008, 03:44 PM
youngssvt's Avatar
youngssvt
youngssvt is offline
160 thermostat
what do u guys think about the 160 thermostat
Old 07-21-2008, 03:56 PM
66f25red's Avatar
66f25red
66f25red is offline
It may cause operatonal problems with the engine sensors and systems, since they are calibrated to existing setup. May also reduce fuel mileage and cause accelerated internal engine wear and contribute to degradation of engine lubrication oil. Modern engines are designed to use temps of around 100c + with high pressure in the cooling system to raise boiling point of coolant. I would not do it.
Old 07-21-2008, 09:14 PM
Blurry94's Avatar
Blurry94
Blurry94 is offline
The ECU wont go into cold mode and it'll cause some minor fueling issues; it may stay in open loop. Basically, the only thing you may encounter is poor fuel milage. There is no notable power gains with this on a stock motor with some bolt-ons.
Old 08-08-2008, 10:18 PM
pkracing03's Avatar
pkracing03
pkracing03 is offline
i would use a 180 if adding more boost but the stock one you wont have any problems with
Old 08-09-2008, 12:03 AM
Stewart_H's Avatar
Stewart_H
Stewart_H is offline
180 is stock on the Gen 2 Lightnings.
What Matt said.
Basically, most highly modified guys do it as a preventive measure to help, no matter how small a diff it may be, lower the chances of detonation.
You need to have it addressed in your custom tune so it won't cause problems on cold mornings.
Stewart
Old 08-09-2008, 05:09 PM
pkracing03's Avatar
pkracing03
i thought its was 190 stock
JGreen236
04-14-2020 07:52 AM
Vashon Islander
09-04-2014 10:56 AM
Desarata
06-16-2013 12:09 AM
rklueber
Modular V10 (6.8l)
05-11-2004 07:47 PM
mrbeefcake
1983 - 2012 Ranger & B-Series
03-13-2003 09:15 AM
Quick Reply: 160 thermostat
