07-21-2008, 04:17 PM
If your not gonna tow, the 4.6 is fine. As far as MPG, there isn't a big difference between the 4.6 and the 5.4. Expect about 15MPG for mixed driving, you might get close to 20 MPG on the hiway, if you're easy on the gas pedal. The known problems would be the sparkplug blow out, and the cruise control. Check to see if the cruise control recall has been done. If not, the dealer should take care of it. The sparkplug problem is not really that common, but it can happen. Stick to the OEM sparkplugs and torque them properly and it should be fine. I would be more interested in the maintaince records if they are available, that should give you a better idea of the condition. You can alway do a carfax to check for any hidden accident damage.
__________________
2002 F-150 Supercab 5.4 Triton V8
Arizona Biege
