Trailer hitch fit ??????????? - Ford Truck Enthusiasts Forums
Old 07-21-2008, 09:33 AM
Bursch Bursch is offline
Bursch is starting off with a positive reputation.
Will a Reese trailer hitch from a 1989 f150 fit on a 1993 f150?
Old 07-21-2008, 09:45 AM
Conanski's Avatar
Conanski Conanski is online now
Conanski has a brilliant futureConanski has a brilliant futureConanski has a brilliant futureConanski has a brilliant futureConanski has a brilliant futureConanski has a brilliant futureConanski has a brilliant futureConanski has a brilliant futureConanski has a brilliant futureConanski has a brilliant futureConanski has a brilliant future
It's the same truck except for the front end sheet metal.
Old 07-21-2008, 10:02 AM
Thanks for the info.
Old 07-21-2008, 11:28 PM
quaddriver quaddriver is offline
quaddriver has a very good reputation on FTE.quaddriver has a very good reputation on FTE.quaddriver has a very good reputation on FTE.
Quote:
yes, 80-96 all the same and I hear the frame width is the same on the highboys as well.
Old 07-22-2008, 02:21 AM
TOM-PLAY_95_EXPRESS TOM-PLAY_95_EXPRESS is offline
TOM-PLAY_95_EXPRESS is starting off with a positive reputation.
i Just put a resse hitch on my '95 F-150 and i can hardly tell its there . i will say if your hitch is adjustable like mine i'll give you a far warning to be prepared to drill some 1/2 inch holes, have a 19mm around, and Finally don't loose your religion when you think the hitch won't clear the spare tire bracket on the passenger side. Just push the hitch back a little bit and your good. Goodluck on your project
Old 07-23-2008, 05:35 PM
I got it put in. I had to remove the bumper and drill the holes. It did take a while but I was not giving up. Thanks for all the help guys.
reciever hitch JUSTICE1736 1973 - 1979 F-100 & Larger F-Series Trucks 4 07-24-2015 05:19 PM
Hitch for my '76 F150 Supercab kadrocker 1973 - 1979 F-100 & Larger F-Series Trucks 4 05-02-2015 09:49 AM
Trailer Hitch? DSE350 1968-2013 Full Size Vans 7 04-06-2015 01:48 AM
Hitch Receiver stydel311 1987 - 1996 F150 & Larger F-Series Trucks 7 12-20-2013 11:52 AM
88 & 93 frame question (trailer hitch) F-150 89fourx4 1987 - 1996 F150 & Larger F-Series Trucks 7 05-14-2009 04:07 PM
Tags
1990, 1993, 2002, 2006, 93, 96, expedition, f150, f250, fit, ford, frame, hitch, on, reese, tow, trucks, width
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
