Just got my truck back from the dealer. They did a bunch of work for problems with cooling and power loss. They changed the oil cooler and did some other things. They performed TSB 08-11-03B Does anyone know what this is? I can't find a listing. Also what is ICP pressure and is 500psi right? Mostly just curious, I haven't had a chance to talk to the tech again.
081103B:
2004-2007 Super Duty, 2004-2005 Excursion 6.0L: Includes Time To Remove and Leak Check EGR Cooler off Engine, Test Oil Cooler Using Radkitplus, Replace EGR Cooler And/Or Oil Cooler if Required, Time to Flush and Fill Cooling System, Change Engine Oil and Filter.
ICP Injection Control Pressure
__________________ Mark
06 F250 CC SB ESOF FX4 Lariat 3.73LS 275/65R20
DieselSite Coolant Filter; High Idle Mod
Zoodad/Air Fury grill; Accufab Elbow; CCV filter
Fumoto; HFCM Plug; Harpooned fuel tank
JimmiJammers; Ravelco; DashDaq & britebox on deck
Line-X, CPOhighway Prod. tool box, tracrac
Fox Weatherboots; Wet Okole Seat Covers
Stanadyne Perf. & B2 for lubricity
