Need a little help relocating the PCV pipe going into 5.0 upper intake
Old 07-20-2008, 08:28 PM
shuttlevalve's Avatar
shuttlevalve
shuttlevalve is offline
I have heard that the 5.0 in the trucks have a nasty problem of sucking all the PCV oil vaper into the #8 cylinder causing detonation problems ETC. i saw a artical once on the subject but i cant seem to find it. i got the intake off and just need to know were the best to pop a new hole in the intake.
Old 07-20-2008, 08:41 PM
danr1's Avatar
danr1
danr1 is offline
The best solution I read was putting a oil separator in the line. Then from time to time drain the bowl, after a short time you'll know how often to do it.
Old 07-20-2008, 09:53 PM
EPNCSU2006's Avatar
EPNCSU2006
EPNCSU2006 is offline
On my truck, I hooked the PCV valve to where the brake booster line normally connects, then connected the brake booster to the vacuum port on the rear of the manifold. It's been a couple years now, and no problems.
Old 07-21-2008, 07:25 PM
brown 4x4's Avatar
brown 4x4
brown 4x4 is offline
I too remember reading about it, but don't know for sure where. One other option is to find a newer style (my 95's have it) upper intake where Ford routed it correctly.
Old 07-21-2008, 11:18 PM
quaddriver's Avatar
quaddriver
quaddriver is offline
well if you are sucking oil vapor like that, then you have ring problems.
however.....the Ford engines with the 1-5-4-etc timing have the exact same firing order as the chevy small block.
meaning instead of crossfiring 5-7 in a chevy, you have 7-8 crossfire in the ford. This was TSB'd about 18 years ago - route the #8 plug wire out of the harness, back along the intake, then over the solenoid pack and report back.
Old 07-22-2008, 04:43 AM
EPNCSU2006's Avatar
EPNCSU2006
It was also reported that the PCV dumping into the #8 cylinder can cause premature engine failure. At least one manufacturer of rebuilt engines requires PCV relocation for the warranty to be valid. The 7-8 crossfire is certainly an issue, but so is the PCV location.
Old 07-22-2008, 03:54 PM
shuttlevalve
[QUOTE=quaddriver;6372968]well if you are sucking oil vapor like that, then you have ring problems.
I rebuilt the engine 15,000 miles ago. It pulls nearly 20 inches of vaccum at idle and i have no oil in the airbox. Just to see what would happen i stuck a vaccum gauge on the end of the pipe going to the air box from the oil filler neck and it was pulling 15 inches of vaccum. If anything it sucking so hard its pulling oil into the upper plentum.
Old 07-22-2008, 03:56 PM
shuttlevalve
it reminds me i just put in a new PCV valve today maybe it was goofed up
Old 07-22-2008, 05:30 PM
Jason Lewis's Avatar
Jason Lewis
Jason Lewis is offline
Its a pain to replace one
I replaced mine for the second time at 120,000 the valve looked brand new (clean) that made me feal good!
Old 07-22-2008, 05:55 PM
mhg's Avatar
mhg
mhg is offline
go to Ford Fuel Injection
look in the down load files for he pcv relocate article
one4house
1997 - 2003 F150
31
09-14-2023 11:25 AM
jdq
2009 - 2014 F150
02-27-2017 08:53 AM
harley3348
15
12-13-2015 06:37 PM
annaleigh
11-20-2015 10:30 PM
chuck7300
09-06-2008 02:38 PM
Quick Reply: Need a little help relocating the PCV pipe going into 5.0 upper intake
