07-20-2008, 09:01 PM
77 F150 Radius Bushings, Other ??'s
I have finally gotten around to messin with my 1977 f150 again. It was a rough two years because my Big brother passed away in 2006 and he helped me build this truck and taught me everything I know about Mechanics in General. I do not have the benefit of his experience at hand anymore so I am turning to you.
I want to freshen up my rebuilt 400 (has about 40K since rebuild). I also want to replace the radius arm bushings (the dangerous way? ie easiest).
1. Whats the easiest way to replace the radius arm bushings? My brother and I did these like 10 years ago and he said it was a dangerous method. I think we unbolted the arms and used a jack and it pulled the arm out and allowed us to slip in some bushings. Can you enlighten me on this method and/or point me to a link?
2. I am going to replace the cam (I loved the edl. performer I used to have but I cracked it in half at 75mph). Do you have to remove the condensor to do a cam change? I didnt have AC at the time my brother did this for me, so we removed radiator etc. Can I get by without removing the condensor? I really like having AC.
3. Is there a straight forward write up on replacing cam? He was very meticulous when we did this especially when it concerned timing etc, and re-inserting the distributor
4. Aussie heads: I am eyeing some aussie heads for the same engine. I want to know if I can use my valvetrain hardware and swap over to these bare aussie heads. The heads I have on now are more recent than the engine and have good valves, springs etc (less than 20K). Can I switch all this over to the Aussie heads and go? They are the 2V close chamber heads I am looking at.
Thanks guys. I have spent 6-8 hours sifting through all sorts of trheads on a lot of topics and I wanted to condense my issues into one thread.
__________________
 1977 Ford F150 XLT Ranger 2wd 400
350,000+ Miles on truck
Newly Remodeled!!
