Have you registered for your free membership? If not, click here now to register!
Join Our Site - Its free, quick and easy!
Click Here to join.   Click Here for more information
Users Chatting None
Go Back   Ford Truck Enthusiasts Forums > Diesel > 2003 - 2007 6.0L Power Stroke Diesel
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
2003 - 2007 6.0L Power Stroke Diesel Sponsored By:
Is F-150 Still King?
LinkBack Thread Tools
  #1 (permalink)
Old 07-20-2008, 04:16 PM
mustangracer2 is starting off with a positive reputation.
Neebie needs help
Last night I was towing home from the drag races and my 2006 6.0 Diesel acted up. Everything was fine. I stopped at a stop light and when I took off. It had no power, was making a poping sound, like it was running out of fuel. The turbo was making a bunch of noise. I pulled off and shut it off. After restarting it was not as bad so I thought I would try to drive it home. 4-5 Miles down the road it started running fine. I dont know much about Diesels but it sounded like the waste gate (if it has one) was stuck open or something. The truck is not driven very often and has under 20K miles.
Any help would be appriciated.
Thanks
Sponsored Links
To remove this ad, register today!
  #2 (permalink)
Old 07-20-2008, 04:24 PM
06silvercrew's Avatar
06silvercrew is starting off with a positive reputation.
Any service engine light or anything? Your truck doesnt have a wastegate, its a VNT turbo. First thing that came to mind was an CAC (intercooler) pipe came off but I doubt it if it started running fine again.
__________________
'06 F250 PSD, CC,SB,4x4,torqshift, SCT X3, 4'' turbo back, AFE stg II intake, Zoodad, '08 mirrors, viper Alarm, Rough Country 8'' Lift, MT MTZ 36-15.50-20, 20X10 Motometals.
'03 GT 302'', vortech YSI, powerglide, 698rwhp, 5.90's with the A/C on
  #3 (permalink)
Old 07-20-2008, 05:52 PM
No check engine light.
  #4 (permalink)
Old 07-20-2008, 08:43 PM
Keeseter CO is starting off with a positive reputation.
Similar experience.
So my 2004 had a similar experience, however not towing so the factors are a bit different. The problem did not go away, once it started it stayed. Warranty replacement of the turbo. I was told that the variable vanes in the turbo were "stuck". Based on the fact i had no boost, a ton of black smoke and the truck didn't have enough power to go faster than 65 . . . i could see how that might've been the case.
Either way, get it in. If it never happens again, then so be it, but i don't like to take my chances with a truck that costs that much.
__________________
2004 F250 PSD auto CC 4x4 shortbox.
2002 Suzuki GSXR 600
2000 Yamaha YZF-R1
  #5 (permalink)
Old 07-20-2008, 08:51 PM
bismic's Avatar
bismic has a very good reputation on FTE.bismic has a very good reputation on FTE.bismic has a very good reputation on FTE.
The popping noise sounds like what many folks here call the turbo "fart". Some say it is common, but it probably comes from the turbo inlet guide vanes sticking. The turbo needs to be cleaned and possibly replaced. To keep the turbo / EGR system from sticking (or at least to give it a good shot to not happen again), I posted on turbo coking an hour or so ago.
__________________
Mark
06 F250 CC SB ESOF FX4 Lariat 3.73LS 275/65R20
DieselSite Coolant Filter; High Idle Mod
Zoodad/Air Fury grill; Accufab Elbow; CCV filter
Fumoto; HFCM Plug; Harpooned fuel tank
JimmiJammers; Ravelco; DashDaq & britebox on deck
Line-X, CPOhighway Prod. tool box, tracrac
Fox Weatherboots; Wet Okole Seat Covers
Stanadyne Perf. & B2 for lubricity
  #6 (permalink)
Old 07-20-2008, 08:59 PM
Maxium4x4's Avatar
Maxium4x4 has a great reputation on FTE.Maxium4x4 has a great reputation on FTE.Maxium4x4 has a great reputation on FTE.Maxium4x4 has a great reputation on FTE.Maxium4x4 has a great reputation on FTE.Maxium4x4 has a great reputation on FTE.
The EGR could be stuck or the turbo not working properly. How many miles on the truck?
__________________
Read First FTE Guidelines
ULSD Click Here
2003 F-350 Reg Cab 6.0L-Custom Programming
424.59HP-669.67 Torque
  #7 (permalink)
Old 07-21-2008, 05:15 PM
It has 18,500 miles. Will a turbo go bad that quickly?
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Terms of Use - Privacy Policy - JOBS
Ford-Trucks.com and Internet Brands, Inc. is not affiliated with the Ford Motor Company.
© 1997-2007 Internet Brands, Inc., Please see our Terms of Use / Privacy Policy
