Not only that, but, I was building something and when I went to put everything together, nothing lined up exact. Checked my Home Depot triangle square against my ancient copper 3 foot roofing square and found it was off by a few degrees and not a true < 90 degrees. Wonder how many homes went up crooked by people not double checking those HD squares. A lot easier to correct wood joints then welded joints though
Thers an easy fix for a 2' steel square thats out. Draw a 4' foot straight line, lay sqaure on one half of line draw the 90 deg. line then flip sqaure to the other half of the 4' line draw another 90deg. line with the other one so you can determine which way it leans in or leans out. Then to fix the problem you use a big center punch and punch the bottom corner of the sqaure on the top edge to make it lean in a C hair or you center punch the bottom outside corner to make it lean out, just stretches the metal a lil'
So heres the front end donor. Also got my traction bars and expecting my highsteer arms soon. Also got a good deal on an open box display detroit locker for the rear. $375
Prozon Im using a 92' 5.9 Cummins Turbo Diesel. Factory intercooled version.
Dave i was gonna rock there but rock is so friggin expensive. Anyhow the house im buyin has a 20'x40' play room for me so the crew will be in there in the spring.
