Rear end "popping/clicking" Solved....Long Rant... - Ford Truck Enthusiasts Forums
Old 07-19-2008, 01:38 PM
jstutz101 jstutz101 is offline
jstutz101 is starting off with a positive reputation.
If your having trouble with your Ford Explorer this will make you feel better...
We bought our 2002 Explorer three years ago. It has had a random "clicking" sound coming from the rear end since day one. Plan on going on a family road trip so I decided we needed new tires (69,000 miles). After dropping off the car the mechanic calls and asks "are you getting new tires because they are worn or noisy?" I tell him both then he gives me the news of a bad front wheel bearing. After reading the posts here I am not surprised. So on top of the $600 for tires we are now going to spend $380 for the new front drivers side bearing replacement.
Anxious to drive the car I hit the highway to "hear" how quiet it is. Amazingly enough the front end is dead quiet. Steering wheel is smooth as silk, it has never been this good. That front bearing has been bad from day one, I just thought it was the way the car was. THEN I notice a "ruh ruh ruh ruh ruh" coming from the rear end. Not a real obvious or loud noise, but after you tune into it you can't miss it. Then also the notorious popping sound when coming up to a stop light and driving parking lot speeds.
I call the mechanic back and ask about fixing the rear end noise. He says he dosent have the tools for the rear and suggested a local transmission shop. Take it there and tell them my story. He asks me what year and model and says right away "we have had a lot of differential bearing trouble with '02 Explorers." Ends up they had to replace the three bearings in the differential and since it was there I had them replace the two wheel bearings. Total for that work is $1205. The mechanic showed me the old bearings, I didn't think they looked that bad. He showed me the pit marks and worn spots, some even had a few small "pieces" missing. After bad mouthing Ford for there bearing troubles he informed me that there really are only a couple bearing manufacturers out there so it really isn't all Ford's fault. He said he gets plenty of Chevy and Dodge vehicles too. Not sure why the Japanese bearing last so long, but I am pretty sure my next car will be a Toyota.
My wife just called me from the car and can't believe how quiet the car is. It hasent made any clicking noises since so I am sure that had to do with differential.
So bottom line is I bought new tires for $2000. I think I would have been better off renting a car for the family trip!!!
Thanks for listening to my rant...
PS. While was writing this my wife just called from the car. She went over a rough set of RR tracks and now there is a loud banging coming from the rear diiferential. UUUUHHHHGGGGG! Obvioiusly not the cars fault, still not good. We dropped the car back off at the shop and now have had to rent a car. The new bottom line is I paid $2200 to rent a car and get new tires on a car that dosen't work! I think it is time for a BEER!
Old 07-19-2008, 07:22 PM
twisted limb twisted limb is offline
twisted limb is starting off with a positive reputation.
Well-welcome to the world of the 02' Explorer.We replaced one front bearing at 58k I replaced the left myself at about 90k.Had the dealer do the rears within the last year.We are at 148k now.Also, this week just had front pinion seal replaced due to a bad leak.The rear dif. on ours has hummed or whined since it had low mileage and the kits out there for the problem do not really help from what I'm told.Rear axle seals alos went bad before 30k.Good luck
Old 07-20-2008, 01:16 PM
pbjohns pbjohns is offline
pbjohns is starting off with a positive reputation.
My 02, has had the rear end noise for along time, with the history of repair jobs, i have decided to live with the sound and keep the cash in my pocket, just turn up the tunes and rock out.
Old 07-20-2008, 06:15 PM
steve(ill)'s Avatar
steve(ill) steve(ill) is offline
steve(ill) has a great reputation on FTE.steve(ill) has a great reputation on FTE.steve(ill) has a great reputation on FTE.steve(ill) has a great reputation on FTE.
most bearing wear is caused by cantamination, not bad bearings. flushing out the factory fill at 30k miles and putting in new oil can help. that being said, i think most of the Explorer "noises" in the back end are not bearing noise, but gear mesh noise. Adding a good 75 w 140 full synthetick gear lube and a 7 oz tube of friction modifier can make a big difference in the gear noises. If it was bearing noise, it would not be constant for 2-3 years, it would get worse.
Old 07-20-2008, 06:21 PM
dkf's Avatar
dkf dkf is offline
dkf is a splendid one to beholddkf is a splendid one to beholddkf is a splendid one to beholddkf is a splendid one to beholddkf is a splendid one to beholddkf is a splendid one to beholddkf is a splendid one to beholddkf is a splendid one to behold
Had a clicking noise coming from the rear of the 03' Explorer. It turns out the crappy brake shoes that go inside the emergency brake drum came apart and were bouncing around inside the rotor. The e-brake held decent but the pads just came apart. They are held together minimally. Just a heads up for someone if they hear a weird noise.
Old 07-23-2008, 07:58 AM
Quote:
Wish I would have known that a week ago! When I stopped by the shop the mechanic was still putting the car back together so I got to watch. I noticed the parking brake shoes we missing. I asked about it and he said not to use the parking brake or have the shoes replaced. Since we never use the parking brake anyway I'm not too concerned, but I bet the break lining has been bouncing around in there for a couple of years.
Thanks for the info...
"04 Expd. 4x4 Gear noise still present after repairs? Cornell1 Expedition & Navigator 8 03-30-2014 02:27 PM
Grinding Sound jdburger1 Explorer, Sport Trac, Mountaineer & Aviator 5 05-10-2010 12:46 PM
UGH trouble... driveshaft popped out after 4wd differential change 89nolaf250 Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 47 03-08-2010 01:41 PM
1999 F53 motorhome idle surge intruder34 Modular V10 (6.8l) 13 09-12-2008 04:39 PM
cracked front differential grandaddy's66 1997 - 2003 F150 22 12-15-2007 05:46 PM
Tags
1997, 2003, 2005, axle, clicking, end, explorer, f150, ford, make, mountaineer, noise, noises, popping, random, rear
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
