Time to Rebuild?
Time to Rebuild?
I have a 1999, F150 4x4 with 180,000 miles. Over the last 3 months it has been burning 1 qt of oil for every 500 miles. I have done all of the regular maints and more then the book calls for. Most of the miles are highway miles, and the oil has never gone past a half qt low. Is it time for a rebuild?
Thxs
Thxs
Ok Thank you I will try it. I will probably go ahead and clean the throttle body and see if everything gets better. If I need to move toward the rebuild should I look at the valve seals first? Maybe I need to do a leak down and compression check? I really would like to avoid the rebuild so maybe the valve seals are going.
Eddie
Eddie
