1997-2006 Expedition & Navigator 1997 - 2002 and 2003 - 2006 Ford Expedition and Lincoln Navigator Discussion
Fuel pump replacement on 99 navigator
Old 07-19-2008, 12:05 PM
Jeffrey04's Avatar
Jeffrey04
Jeffrey04 is offline
I could use some help on the "how to" of the fuel pump replacement on my 99 Navigator...thanks.
Old 07-21-2008, 08:02 AM
gibsonj's Avatar
gibsonj
gibsonj is offline
Are you real sure it's the FP? A lot of trouble and work to drop the tank if it happens to be a bad relay.
Old 07-26-2008, 02:00 AM
Jeffrey04's Avatar
Jeffrey04
Not sure, my second opinion says the codes are showing bad O2 sensor on bank 1 and bank 2. It's hard to start when it's cold (having to pump it 2-3 times) and if it idles below 1000 RPM the idle is real rough and will only stablize if I manually raise the RPM's up to or a little over 1000.
Old 07-26-2008, 11:05 AM
alloro's Avatar
alloro
alloro is offline
Received 4,194 Likes on 2,430 Posts
1. If the codes are pointing to a bad O2 sensors then why in the world would you change the fuel pump? If the pump is in any way suspect, the first thing to do is take a pressure reading at the fuel rail.
2. You don't pump or even touch the pedal on fuel injected vehicles, only carbureted ones.
3. How long since it's had a tune-up, air filter, plugs, etc.?
deezdrama
08-27-2016 11:10 AM
mudder1_2000
25
05-10-2011 02:24 AM
Reefmonster
01-13-2010 01:09 AM
NAVI-G
New Member Introductions
11-14-2006 05:08 AM
cbr900bikes
01-25-2004 09:24 PM
Quick Reply: Fuel pump replacement on 99 navigator
