Fuel pump replacement on 99 navigator - Ford Truck Enthusiasts Forums
1997-2006 Expedition & Navigator 1997 - 2002 and 2003 - 2006 Ford Expedition and Lincoln Navigator Discussion
Old 07-19-2008, 12:05 PM
Jeffrey04 Jeffrey04 is offline
Jeffrey04 is starting off with a positive reputation.
I could use some help on the "how to" of the fuel pump replacement on my 99 Navigator...thanks.
Old 07-21-2008, 08:02 AM
gibsonj gibsonj is offline
gibsonj is starting off with a positive reputation.
Are you real sure it's the FP? A lot of trouble and work to drop the tank if it happens to be a bad relay.
Old 07-26-2008, 02:00 AM
Not sure, my second opinion says the codes are showing bad O2 sensor on bank 1 and bank 2. It's hard to start when it's cold (having to pump it 2-3 times) and if it idles below 1000 RPM the idle is real rough and will only stablize if I manually raise the RPM's up to or a little over 1000.
Old 07-26-2008, 11:05 AM
alloro alloro is offline
alloro is a splendid one to beholdalloro is a splendid one to beholdalloro is a splendid one to beholdalloro is a splendid one to beholdalloro is a splendid one to beholdalloro is a splendid one to beholdalloro is a splendid one to beholdalloro is a splendid one to behold
1. If the codes are pointing to a bad O2 sensors then why in the world would you change the fuel pump? If the pump is in any way suspect, the first thing to do is take a pressure reading at the fuel rail.
2. You don't pump or even touch the pedal on fuel injected vehicles, only carbureted ones.
3. How long since it's had a tune-up, air filter, plugs, etc.?
99 Nav. steering noise deezdrama Brakes, Steering, Suspension, Tires, & Wheels 0 08-27-2016 11:10 AM
Weak LLS Compressor????? mudder1_2000 1997-2006 Expedition & Navigator 25 05-10-2011 02:24 AM
2000 Navi Navigation Upgrade ? Reefmonster 1997-2006 Expedition & Navigator 4 01-13-2010 01:09 AM
99 navigator NAVI-G New Member Introductions 1 11-14-2006 05:08 AM
where to find the reset button for the fuel pump cbr900bikes 1997-2006 Expedition & Navigator 3 01-25-2004 09:24 PM
Tags
99, ford, forum, fuel, instruction, navigator, pump, replacement, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
