Go Back   Ford Truck Enthusiasts Forums > Older, Classic and Antique Trucks > 1973 - 1979 F-100 And Larger F-Series Trucks
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
1973 - 1979 F-100 And Larger F-Series Trucks Discuss the Dentsides Ford Truck
Is F-150 Still King?
LinkBack Thread Tools
  #1 (permalink)
Old 07-19-2008, 01:02 AM
projectbad78's Avatar
projectbad78 is starting off with a positive reputation.
Please Help, Urgent
hi guys, im gettin up early in the morning to tackle my oil pump replacement......this is my first time and i dont know what the thing on the shaft is for..... i searched around and apparently it is the drive shaft collar....what does it do?....im going to try to do this with out pulling my dizzy....thanks guys
__________________
1978 F100 custom
351W
-offy intake
-'brock carb
C4
Sponsored Links
To remove this ad, register today!
  #2 (permalink)
Old 07-19-2008, 01:42 AM
OldMetal's Avatar
OldMetal is starting off with a positive reputation.
You kinda lost me there, if your talking about the little round piece of metal that slides on the shaft that turns the dist. it's job is to keep the shaft in the oil pump when you pull the dist out.
You should be able to do this without pulling the dist. just make sure the shaft is in place before you start cranking down any bolts.
__________________
77 F150 4X4
  #3 (permalink)
Old 07-19-2008, 05:22 AM
duste is starting off with a positive reputation.
Also be sure to prime the new oil pump before putting it on, this is done by placing the pump in a pan of oil and turning the pump till the oil flows through it . They normally do it on thier own when installed but they have also been known to air lock and not pump oil thus destroying the engine.
__________________
If it's a FORD, it's therapy. For anything else , it's called WORK.
76 F100 300 6
79 F150 302
79 F150 351M to a 429 (best sleeper ever)
79 F150 460 -current toy
2006 F150 XLT XTR S/ CREW
All 2X4's
  #4 (permalink)
Old 07-19-2008, 05:47 AM
hairyboxnoogle's Avatar
hairyboxnoogle is starting off with a positive reputation.
Well everything i know has been covered really... all i can say is best of luck, and this job is a P.I.A. Best done by removing the motor mounts, and using a cherry picker... some times you have to some times its just easier.
  #5 (permalink)
Old 07-19-2008, 12:59 PM
alright, thanks guys, got everything out, just need to put it back in now.......could you explain a little more on the position of the small round thing....it goes near the top by the block?
__________________
1978 F100 custom
351W
-offy intake
-'brock carb
C4
  #6 (permalink)
Old 07-19-2008, 02:20 PM
daddy172005's Avatar
daddy172005 is starting off with a positive reputation.
Yes the clip goes towards the top of the block. I would replace the shaft if the clip moves easily. I had a problem a while back with my 302 where when I pulled the distributor out and the shaft fell in the oil pan. I didn't know what had happened at the time but realized it when I had no oil pressure. If the clip isn't snug threre is a good chance that it will slide down and take a chance of this happening. If you buy a new one the clip will already be in the right place where all you will need to do is stick it in there. This is just a suggestion to save you some trouble down the road. Better to spend a few bucks now than have something as simple as that get you down the road. I think I paid $5.04 for mine at NAPA.
__________________
Mason
74 F100 302
  #7 (permalink)
Old 07-19-2008, 03:13 PM
yeah, i bought a new shaft with it already on there but i didnt know what it was for....thanks. when i took apart my old screen the old one was in there (wonder how that happened)
__________________
1978 F100 custom
351W
-offy intake
-'brock carb
C4
  #8 (permalink)
Old 07-19-2008, 03:57 PM
Thunderjet4x4 is starting off with a positive reputation.
That little clip goes on one way. Make sure it is positioned towards the block, and in such a way that when the dist. is pulled the clip will "grab" onto the shaft and do its job.
I took a broken dist. and gutted the advance out, removed the gear and cut a hole in the side so I could hook up a 1/2" drill to prime the engine. I was tired when I first tried it, couldn't get any pressure and it kept making a "baaloop" sound-then I realized the drill needs to turn counter clockwise! Made good pressure then!
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Ford-Trucks.com and Internet Brands, Inc. are not affiliated with the Ford Motor Company.
