Loud Noise @ Idle, Sounds Like Injectors? - Ford Truck Enthusiasts Forums
Old 07-18-2008, 05:37 PM
flcracker9 flcracker9 is offline
flcracker9 is starting off with a positive reputation.
Just this afternoon, my 7.3 (2003, 125k miles) started making a horrible noise when there is no load on the engine. I first noticed it when I let off the pedal to stop at a light. It gets better once the engine catches up at a full stop in gear. I put it in neutral and it sounded horrible again. The noise goes away when I accelerate, and I can't really hear while crusing, but as soon as I let off the pedal, it starts again. I got home and opened the hood at idle, and it almost sounds like the injectors?. If I give it throttle, it goes away, and comes back at idle. I do have an oil leak where the hpop bolts to the block, it's been leaking for 3 months. Could it be the hpop?. Any suggestions?
Old 07-18-2008, 07:24 PM
F350-6's Avatar
F350-6 F350-6 is offline
F350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputation
What exactly does it sound like? You mentioned it sounds like injectors. Like a rod knock? How loud? Are you sure the sound goes away on acceleration and isn't just muffled?
Can you tell which side of the engine it's coming from? You might think about disconnecting the UVCH wiring from each side one at a time to see which side gets rid of your noise. That would at least give you a place to start.
Old 07-18-2008, 07:29 PM
Kwikkordead's Avatar
Kwikkordead Kwikkordead is offline
Kwikkordead has a superb reputationKwikkordead has a superb reputationKwikkordead has a superb reputationKwikkordead has a superb reputationKwikkordead has a superb reputationKwikkordead has a superb reputationKwikkordead has a superb reputationKwikkordead has a superb reputationKwikkordead has a superb reputationKwikkordead has a superb reputationKwikkordead has a superb reputation
Broken flex plate.
Old 07-18-2008, 10:52 PM
hucka1a's Avatar
hucka1a hucka1a is offline
hucka1a is a name known to allhucka1a is a name known to allhucka1a is a name known to allhucka1a is a name known to allhucka1a is a name known to allhucka1a is a name known to all
This sounds like the same noise I've had going on, I thought mine was more of an exhaust leak. Flex plate? I hadn't though of that. How would you go about checking/changing the flex plate?
Old 07-18-2008, 11:04 PM
schlepprock250's Avatar
schlepprock250 schlepprock250 is offline
Guns Dont Kill People..
schlepprock250 is a splendid one to beholdschlepprock250 is a splendid one to beholdschlepprock250 is a splendid one to beholdschlepprock250 is a splendid one to beholdschlepprock250 is a splendid one to beholdschlepprock250 is a splendid one to behold
Quote:
Originally Posted by Kwikkordead View Post
Broken flex plate.
Hey quick...whats a flex plate and wheres it located...(I know I know...Im still learning), lol
Thx Schlepprock
Old 07-19-2008, 06:56 AM
Definately not the flex plate. The noise is coming from the left (driver's) side of the engine, somewhere around the middle to top side of the engine block. the noise definately goes away at the slightest increase in RPM, but it's loud at idle. Increase the idle 100-200 RPMs, and it sounds normal. It sounds to me like the injectors clacking louder, but it's hard to tell. I'm going to check the exhaust manifold today, and make sure it's tight, and doesn't have a break in it. Other than that, I'm stumped?
Old 07-19-2008, 07:03 AM
ron's power stroke's Avatar
ron's power stroke ron's power stroke is offline
ron's power stroke has much to be proud ofron's power stroke has much to be proud ofron's power stroke has much to be proud ofron's power stroke has much to be proud ofron's power stroke has much to be proud ofron's power stroke has much to be proud ofron's power stroke has much to be proud ofron's power stroke has much to be proud ofron's power stroke has much to be proud ofron's power stroke has much to be proud of
flex plate is what the TC bolts to....look thought the driver side wheel well around the exhaust mainfold for soot or on a cold motor start her up and feel around the manifold for exhast blowing out......maybe a small exhaust leak...
Old 07-19-2008, 07:08 AM
danskool's Avatar
danskool danskool is offline
Go Bills !
danskool is a splendid one to beholddanskool is a splendid one to beholddanskool is a splendid one to beholddanskool is a splendid one to beholddanskool is a splendid one to beholddanskool is a splendid one to beholddanskool is a splendid one to behold
Flex plate is also called. FLY WHEEL. The big toothed gear the starter ingauges. With a Automatic , It attached the Crank Shaft to the Torque Converter.
From my understanding you can not see if is it cracked from the access cover. You have to drop tranny and look around were the FP bolts to the crankshaft.
A couple of old pictures i took with my cell phone a while back. Flex plate is the flywheel with the big grear running around the OD.
Old 07-19-2008, 07:16 AM
Quote:
I agree, it doesn't sound like a flex plate. But sound can travel.
It wouldn't be a broken exhaust, it would get louder if you put a load on the engine.
If I were in your position, I would be pulling the valve cover off, then running it to see what's up.
Old 07-19-2008, 07:39 AM
Markadeck's Avatar
Markadeck Markadeck is offline
Gone, but not forgotten
Markadeck has a brilliant futureMarkadeck has a brilliant futureMarkadeck has a brilliant futureMarkadeck has a brilliant futureMarkadeck has a brilliant futureMarkadeck has a brilliant futureMarkadeck has a brilliant futureMarkadeck has a brilliant futureMarkadeck has a brilliant futureMarkadeck has a brilliant futureMarkadeck has a brilliant future
And this does not bug the Hell out of you?
Old 07-19-2008, 07:43 AM
danskool's Avatar
Go Bills !
Excact symptom i have. Cell phone clips, can listen with "quicktime player" http://www.geocities.com/dirtsplat/k...timeplayer.zip
I discovered it was defenitly #8 injector by pulling the wire.
Old 07-19-2008, 09:13 AM
I have more of a ticking,rocker arm kinda sound, you can hear it from the driers side, but you can REALLY hear it from the passenger side.
Shlepprock
Old 07-19-2008, 09:34 AM
danskool's Avatar
Go Bills !
How bad it that oil leak? I think i would go after that first.
Old 07-19-2008, 09:37 AM
Markadeck's Avatar
Quote:
Would the leak have anything to do with oil pressure getting to the injectors. Hmmm, HPOP oil leak, injector noise, double Hmmmmm.
Old 07-19-2008, 02:07 PM
Quote:
Yes it bugs the hell out of me, but not as much as the $1145.00 estimate I got to fix it!. That was the cheapest of 3 estimates. I've checked the o-ring seals on the HPOP, and the plug, and that's not where it's leaking. All 3 shops (1 was a Ford dealer) say the pump needs to be replaced?. I lose a quart every 2 weeks. For $1145.00, I can put a lot of quarts of oil in!.
Anyways, I took a piece of re-bar, and used it as a stethoscope, and I narrowed it down to being the water pump bearing. I then removed the serpentine belt, started the motor, and no more noise!. At least it's an easy fix.
Thanks to those who replied
Front engine grinding at idle Kamstutz 1999 - 2003 7.3L Power Stroke Diesel 7 06-11-2016 07:01 PM
Loud Idle quiets with RPM 1978Crew 1999 - 2003 7.3L Power Stroke Diesel 6 11-03-2015 03:47 AM
E99 smoking, low power, strange noises SaintITC 1999 - 2003 7.3L Power Stroke Diesel 25 02-09-2015 08:17 AM
Injector noise?? mackl1 6.0L Power Stroke Diesel 15 10-29-2012 06:35 PM
Horrible Noise when oil filler cap off drivespline Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 13 05-18-2010 01:38 AM
Tags
1999, 2003, 73, 73l, diesel, engine, f350, flywheel, ford, idle, injectors, loud, make, making, noise, powerstroke
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
