2007 - 2014 Expedition & Navigator 2007, 2008, 2009, 2010, 2011, 2012, 2013 and 2014 Ford Expedition and Lincoln Navigator
Aux reverse light suggestions?
Old 06-25-2008, 12:30 AM
hjsimpson's Avatar
hjsimpson
hjsimpson is offline
I have an 07 Black XLT and I am looking for a quality clean looking aux reverse lighting.
Any suggestions?
I was looking at the White night kit but i dont know how I feel about the looks, any on have any pics?
w w w (dot) whitenight (dot) com
Has anyone tried a flush mount installation?
Is there anyone that has used an OEM type switch/button to control their aux reverse lights?
thanks!
Old 06-25-2008, 12:41 AM
khadma's Avatar
khadma
khadma is offline
Carpenter Local 745
wait right here.
Old 06-25-2008, 12:52 AM
khadma's Avatar
khadma
khadma is offline
Carpenter Local 745
Here is a great thread.
Most of the installation information is in the first post.
I did a similar installation on my 07 Explorer, except for using the upfitter switches.
My relay is tapped in to the reverse lights. This way only one wire is needed from the front of the truck to the rear.
Lights go on when truck is put into reverse.
https://www.ford-trucks.com/forums/5...with-pics.html
Old 06-25-2008, 10:07 AM
SG1NUT's Avatar
SG1NUT
SG1NUT is offline
I used $20 driving lights from Autozone. I welded them to the hitch receiver.
Old 06-25-2008, 10:11 AM
mjdoyle's Avatar
mjdoyle
mjdoyle is offline
I'll second that suggestion. The "stealth" looking lights are the same lights that I put on my Expedition, and I love the way they look. I will try to get a photo tonight and post it for you, but I highly recommend them. I wired mine into my 7-pin so that I can disconnect them when I am pulling my TT. 55w lights hitting a white trailer sure causes quite a reflection!
-Mike
2000 Mercury Mountaineer
2008 Ford Expedition EL XLT
2001 Keystone Bobcat 280BH
Old 06-25-2008, 06:56 PM
chuck s's Avatar
chuck s
chuck s is offline
I put backup lights on my camper that run off the center pole of the RV connector, but the truck's lights are blinding against the white trailer body and defeat some of the advantage. Taping over them works, but I'd rather have a switch on them I could access.
Any suggestions?
-- Chuck
Old 06-25-2008, 09:12 PM
mjdoyle's Avatar
mjdoyle
mjdoyle is offline
Ok, I did get a chance to snap some photos when I got home tonight. Sorry for the poor quality, the mosquitos are extremely bad here in WI after all of the rain we have had.
Lights off. Hard to see in the photo, but that is what makes them "stealth"
Lights on.
Chuck S, If I am understanding you correctly, you installed lights on your trailer, but have a hard time seeing what is being lit up by those lights because of the truck lights reflecting off of the white shell of the camper. The wiring for the reverse lights is easily accessible on the drivers side by removing the fuel pump relay access door. This is actually where I tapped in to power my reverse camera. I'm not sure if the wiring to both sides is accessible from here, but I would highly doubt it. Alternatively, you could replace the spade fuse in the fuse box (passenger side just in front of the door) with a fused wire/switch that you could relocate to be somewhere under the dash. My only concern with that would be if there is anything else that is run off of that same circuit, but my guess is that you would only need to kill the circuit when you are backing up with the trailer connected. That being the case, I would consider using a momentary off switch instead of a toggle, that way you don't forget to leave it on... or off.. as the case may be.
Old 06-26-2008, 06:54 AM
TexasGuy001's Avatar
TexasGuy001
TexasGuy001 is offline
I have some like SGINUT has but they are designed to be back up lights. The lense is a utility style lense that disperses the light instead of making a beam. They are available at Autozone etc for about 29 bucks. I think PepBoys also has them. They are made by Pilot and Navigator (same package). They come with brackets to mount them to a reciever hitch. On my truck they turned out nice and are sort of hidden behind the bumper. For some reason they are more expensive from JCW.
Here is what it looks like. On my truck they dont show up as much, but this will give you an idea.
Pilot Navigator Backup Light Kit : JC Whitney: Auto Parts & Accessories
The second ebay link is for an LED light bar. If this suits your style it has tail/brake/reverse so its 3 function. This might look good. I don't particularly care for it on the older trucks like mine though.
eBay Motors: LITEGLOW 48 in TAILGLOW REAR TRUCK LIGHT W BACKUP (item 330136999347 end time Jul-13-08 14:57:45 PDT)
Old 06-26-2008, 11:13 AM
berry1234's Avatar
berry1234
berry1234 is offline
Anyone use those LED replacement back up bulbs? Do they work better than stock?
Old 06-26-2008, 11:19 AM
kw5413's Avatar
kw5413
kw5413 is offline
I like the idea of using the trailer plug to power the lights. If I have time I think I might install some this weekend. Seems like no fuss no muss using this approach.
Old 06-26-2008, 11:54 AM
TexasGuy001
A friend of mine has those that plug in to the reciever hitch. I think most if not all of them allow a hitch to be installed while they are in use. The ones he has are nice.
Old 06-26-2008, 01:00 PM
kw5413's Avatar
kw5413
kw5413 is offline
Actually, now that I think of it, I have a White Knight rig in my garage. I placed it on my 2002 F-150 & 2004 F-250. I love 'em. Attached thru the receiver hitch.
They wouldn't fit on my '07 Suburban so I put them up. Out of sight, out of mind. I guess I'll dig 'em up tomorrow and see if they fit right on the EL.
BTW, if anyone wants to see how the White Knights looked on my F-250...check out my gallery.
Old 06-28-2008, 10:51 PM
hjsimpson's Avatar
hjsimpson
Thanks khadma...
That looks like what I have been searching for. I went to my local autozone to check them out and they are tiny.
Would you or anyone have any suggestions on a factory looking switch?
Since I have three blanks on the upper left side of the center console that is my primary location.
My secondary would be between the Aux input port and the cigarette lighter.
I would like to have the switch to do the following:
1. manual on
2. on with reverse
3. manual off
Thanks for the help!!
Old 08-28-2008, 10:26 PM
hjsimpson's Avatar
hjsimpson
Well I finally got a chance to get my aux reverse lights installed.
Thought I would share some pics and get some feedback.
I have the switched mounted just above the emergency brake release and is wired this way;
Up - manually on
Center - off
Down - on with reverse
As you can see, I left some room to mount another switch which will eventually be for a set of driving lights mounted in the lower valance.
I still need to take some night pics and post them as well.
Old 08-30-2008, 06:33 AM
SemperFiDevilDog's Avatar
SemperFiDevilDog
SemperFiDevilDog is offline
Nice job...
nicechad2
16
12-03-2018 12:49 PM
TheNewman
2015 - 2020 F150
03-20-2017 12:36 PM
Murphy IRE
1999 to 2016 Super Duty
09-20-2016 07:32 AM
jerseymike
05-05-2016 05:21 PM
dougsbart
08-26-2009 12:51 PM
Quick Reply: Aux reverse light suggestions?
