car engine into truck, cam change question
My son and I are mid way through an engine swap. His 4.6L engine bagged the bottom end. We are transplanting a used "car engine". Now I have read the 4.6 triton in the trucks has a different cam set up with a grind to produce more torque. More torque is desireable. Therefore would it be a simple swap while the engines are both on stands to pull the truck cams and slip them in to the car heads? Should the cams be taken to a engine rebuilder and serviced? Or would the differnece be noticed? Meaning is it worthe the hassle or just leave them alone. Would he be gaining a whole gob of power with truck cams?
Rebuilding the Ford 4.6L SOHC Engine, Doug Anderson, Engine Builder, April 2002
There is a cam chart about 3/4 of the way down that may help depending on what year engines you are working with.
JL
351Cleveland C4
05-13-2014 09:32 AM
LightningClint
01-12-2011 10:25 PM
