HOWTO - Changing the colors of the gauge faces & backlighting of gauge clusters - Ford Truck Enthusiasts Forums
Old 07-17-2008, 09:18 PM
Sycostang67's Avatar
Sycostang67 Sycostang67 is offline
Sycostang67 has a very good reputation on FTE.Sycostang67 has a very good reputation on FTE.Sycostang67 has a very good reputation on FTE.
Moderator's Note - Descriptions of painted gauge faces, needles and changes in backlighting are discussed in-depth here.
WAS: My attempt at white gauges
ct 17-jan-11
I got bored and had an extra speedometer laying around, so I decided to white it out. I used appliance epoxy to paint it white and then just used some permanent markers for the numbers and the needle. I think it turned out pretty good. Now I'll do the whole cluster.
Last edited by ctubutis; 01-17-2011 at 10:25 PM. Reason: Title change, description added at top (for inclusion in subforums)
Old 07-17-2008, 09:30 PM
86bigred's Avatar
86bigred 86bigred is offline
86bigred is gaining momentum as a positive member of FTE.
looks good,gives me ideas.post more picks when complete.
Old 07-17-2008, 09:51 PM
Dustin1690 Dustin1690 is offline
Dustin1690 is gaining momentum as a positive member of FTE.Dustin1690 is gaining momentum as a positive member of FTE.
Yeah it turned out great
Old 07-17-2008, 10:15 PM
86F150302's Avatar
86F150302 86F150302 is offline
86F150302 has a very good reputation on FTE.86F150302 has a very good reputation on FTE.86F150302 has a very good reputation on FTE.
sweet, Now I want to do mine!
Old 07-17-2008, 11:16 PM
I will try and do the whole cluster on saturday. I went to the J-yard today and got another tach and circuit paper since mine is acting weird and I also got some new woodgrain trim panels.
Old 07-17-2008, 11:51 PM
Zip's Avatar
Zip Zip is offline
Posting Legend
Zip has a superb reputationZip has a superb reputationZip has a superb reputationZip has a superb reputationZip has a superb reputationZip has a superb reputationZip has a superb reputationZip has a superb reputationZip has a superb reputationZip has a superb reputationZip has a superb reputation
That looks good.
Old 07-18-2008, 03:33 PM
Eddiec1564 Eddiec1564 is offline
Eddiec1564 has a very good reputation on FTE.Eddiec1564 has a very good reputation on FTE.Eddiec1564 has a very good reputation on FTE.Eddiec1564 has a very good reputation on FTE.
How did you get the needle off with out dammage? Will this improve the poor lighting at night these clusters are known for?
Old 07-18-2008, 10:06 PM
Coneynew's Avatar
Coneynew Coneynew is offline
Coneynew is starting off with a positive reputation.
Nice work! I did find a site that makes them for almost any year F-series: It gives you a good pic of all the guages in white and then at night w/ green LED bulbs.
Welcome to whitegauges.net
Another place even makes the white face HVAC panel in white:
http://www.streetracerparts.com/Ford...srp-0627-2.htm
Old 07-19-2008, 12:56 AM
86F150302's Avatar
Motorcycle Parts & Accessories : Glow Gauges, Illumiglo Gauges, Clear LED Taillights with Integrated Turn Signals, Fender Eliminators
Wow I want those LED bulds
Old 07-19-2008, 02:42 AM
nates-new-old-f150's Avatar
nates-new-old-f150 nates-new-old-f150 is offline
nates-new-old-f150 is starting off with a positive reputation.
cool your hands are much steadier than mine lol
Old 07-19-2008, 03:28 PM
Quote:
I didn't remove the needle, I just painted it white with the rest of the gauge and then went over the needle with the orange.
One thing you can do to improve the dash lighting is remove the blue plastic covers over the bulbs. If you still want the green color, you can get the bulbs in green or blue at most parts stores. It will still be brighter with without those color caps. I removed the covers on my truck and my Capri, big improvement.
Old 07-19-2008, 06:08 PM
Here's my progress so far. I got everything taken apart and got the guages cleaned and painted with the rustoleum appliance epoxy. I figure it's a durable surface and it's easy to clean next time I need to dust my gauges.
I also decided to paint the inside of the case and the warning lights/indicators silver to hopefully make it a little brighter at night.
I need to let the epoxy cure for 24 hours so I will try and finish up before I go to work tomorrow, but it just depends on when I get up.
Old 07-19-2008, 06:14 PM
khadma's Avatar
khadma khadma is offline
Carpenter Local 745
khadma has much to be proud ofkhadma has much to be proud ofkhadma has much to be proud ofkhadma has much to be proud ofkhadma has much to be proud ofkhadma has much to be proud ofkhadma has much to be proud ofkhadma has much to be proud ofkhadma has much to be proud of
Props to you for helping the planet stay just a bit greener!
J yard recycling is a good thing.
Rep points to you for this great project!
Old 07-20-2008, 06:45 PM
Thanks Darren. Funny thing is I went to the J-yard looking for capri parts and came home with a bunch of truck parts and nothing for the capri. I was like a kid in a candy store.
I got the gauges all finished up and mounted back in the case. I need to repaint the silver edges on my new trim panel and then I can throw everything back in the truck.
Old 07-20-2008, 06:57 PM
SuperSnake's Avatar
SuperSnake SuperSnake is offline
SuperSnake is a splendid one to beholdSuperSnake is a splendid one to beholdSuperSnake is a splendid one to beholdSuperSnake is a splendid one to beholdSuperSnake is a splendid one to beholdSuperSnake is a splendid one to beholdSuperSnake is a splendid one to beholdSuperSnake is a splendid one to behold
Can a dash cluster kike yours with a tach be swapped in for a non-tach unit?
My attempt at white gauges Sycostang67 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 200 07-11-2016 08:39 PM
Just put LEDS in the dash! Sycostang67 1987 - 1996 F150 & Larger F-Series Trucks 243 05-21-2015 04:34 PM
Different color instrument cluster lights f350rebel7788 1994.5 - 1997 7.3L Power Stroke Diesel 3 04-03-2012 11:45 PM
2004 Odometer/Temp LCD Backlight wtourvil 2004 - 2008 F150 25 02-28-2012 08:43 AM
Dash Cluster and Climate Control Backlighting speedyejl 1997-2006 Expedition & Navigator 3 11-25-2011 09:25 PM
Go Back   Ford Truck Enthusiasts Forums > >
Tags
1997, 2006, backlight, boys, bulb, condom, explorer, f250, ford, forums, gauges, instrument, location, pep, relay, white
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
