Have you registered for your free membership? If not, click here now to register!
Join Our Site - Its free, quick and easy!
Click Here to join.   Click Here for more information
Users Chatting None
Go Back   Ford Truck Enthusiasts Forums > Older, Classic and Antique Trucks > 1973 - 1979 F-100 And Larger F-Series Trucks
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
1973 - 1979 F-100 And Larger F-Series Trucks Discuss the Dentsides Ford Truck
Is F-150 Still King?
LinkBack Thread Tools
  #1 (permalink)
Old 07-17-2008, 09:14 PM
79f-250custom's Avatar
79f-250custom is starting off with a positive reputation.
OPPS and a driveshaft ?
haha, broke a U-joint in the high boy today. while i was taking off the driveshaft i noticed the guy had the front and back driveshaft were flipfloped. i didnt even notice this while i had the tranny out. so i was wondering if the guy had a reason for doing this. i gave him a ringer and he said that it had somthing to do with the rear axle???? here are some pics. both front and rear axles are 8 lugs. d-44 frong and a dana 70 rear i think?
here are some pics.
any one know any reason for doing this or did he not know he did this?
thanks
Mitch
__________________
________________________________
1995 Ford F-350 PSD quad cab dually.
2wd, 4:10LS, E4OD, 215K Truckin again!
kwiki filter,Edge evo chip and a dead cat/no muffler.
75 ford F-100 4X4 390 C-6 tranny on 33's
true dual's.
NEW 75 Ford Highboy 4x4 460CID NP435 4spd NP205 divorced T-case
sitting on 39's going to be my little plowin girl this winter
Mitch
Sponsored Links
To remove this ad, register today!
  #2 (permalink)
Old 07-17-2008, 10:17 PM
ech0sh4y's Avatar
Brand New =>
ech0sh4y is starting off with a positive reputation.
haha carnage!! wooo kinda sounds goofy to me.. maybe something with the u-joint size for the yoke on the rear axle?
  #3 (permalink)
Old 07-17-2008, 10:55 PM
thats fuel for tinken. ill have to check on that.
thanks
Mitch
__________________
true dual's.
Mitch
  #4 (permalink)
Old 07-18-2008, 03:09 AM
75F350 has a very good reputation on FTE.75F350 has a very good reputation on FTE.75F350 has a very good reputation on FTE.
I do not see a double cardon joint there, so it really should not matter which direction the shaft is installed.
However, I do see a problem with the length of the front shaft. I see that the front joint sheered at a point, or in a manner that is not typical. As a can see from the pic, I see that the front shaft has very little room to compress. From the dark area on the very base of the slines, it would appear that the shaft bottomed out. It looks like the shaft is too long, and the shaft does not have enough room to compress. When it bottomed out, it had no place to go, and it killed the joint.
I could be wrong, but it appears that this shaft is not correct, and your problem will occur again.
Normal suspension cycles will eat up at least that much driveshaft travel.
FWIW, all of my HB's had (stock) double cardan joints for both front and rear shafts.
  #5 (permalink)
Old 07-18-2008, 03:44 AM
NumberDummy's Avatar
Ford Parts Guru
NumberDummy has a brilliant futureNumberDummy has a brilliant futureNumberDummy has a brilliant futureNumberDummy has a brilliant futureNumberDummy has a brilliant futureNumberDummy has a brilliant futureNumberDummy has a brilliant futureNumberDummy has a brilliant futureNumberDummy has a brilliant futureNumberDummy has a brilliant futureNumberDummy has a brilliant future
As original:
1975 F250 4WD 133" Wheelbase (High Boy).
Front driveshaft length: 20 1/32" from center of eyelet to end.
__________________
Bill / Retired Ford Partsman ~ 1962/1997
Part Number Research available for the following: Trucks: 1928/2002 / Cars: 1928/2000
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Terms of Use - Privacy Policy - JOBS
Ford-Trucks.com and Internet Brands, Inc. is not affiliated with the Ford Motor Company.
© 1997-2007 Internet Brands, Inc., Please see our Terms of Use / Privacy Policy
