Have you registered for your free membership? If not, click here now to register!
Join Our Site - Its free, quick and easy!
Click Here to join.   Click Here for more information
Users Chatting None
Go Back   Ford Truck Enthusiasts Forums > Older, Classic and Antique Trucks > 1961 - 1966 F-100 And Larger F-Series Trucks
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
1961 - 1966 F-100 And Larger F-Series Trucks Discuss the Slick Sixties Ford Truck
Is F-150 Still King?
LinkBack Thread Tools
  #1 (permalink)
Old 07-17-2008, 08:15 PM
62-f100 is starting off with a positive reputation.
Trans Question... Quite Confused
I recently got a 62 F100 as payment for cutting firewood... Its a long bed, styleside with a chevy 292 I6 (originally 292 v8). The trans code on the data plate is FA... What trans is that? The current 4-speed has reverse left,rear... any ideas?
Thanks!
Sponsored Links
To remove this ad, register today!
  #2 (permalink)
Old 07-17-2008, 11:35 PM
garbz2 is gaining momentum as a positive member of FTE.garbz2 is gaining momentum as a positive member of FTE.
F is a 4 speed warner T98-A
A is a 3 speed standard.
But who knows a some one shoved a chevy plant i there.
Garbz
__________________
64 F100 "Christine" 472 EFI C6 and mean
63 F100 Uni Custom under construction 4" off the pavement and built to drive DOHC, EOD.
69 F250 Crew Hiboy 360 435. Driver.
05 Escape XLT
  #3 (permalink)
fordbubba8206 is starting off with a positive reputation.
If I'm not mistaken, it is a NP-435 transmission. Ive got one in my 1966 F-100 that I'm in the process of customizing to the brim.
  #4 (permalink)
Old 07-17-2008, 11:53 PM
85e150six4mtod has a good reputation on FTE.85e150six4mtod has a good reputation on FTE.
Pics, info on the NP435 and Muncie trans, the two likely suspects.
Domestic Truck Tranny Guide
  #5 (permalink)
Old 07-18-2008, 12:03 AM
NumberDummy's Avatar
Ford Parts Guru
NumberDummy has a brilliant futureNumberDummy has a brilliant futureNumberDummy has a brilliant futureNumberDummy has a brilliant futureNumberDummy has a brilliant futureNumberDummy has a brilliant futureNumberDummy has a brilliant futureNumberDummy has a brilliant futureNumberDummy has a brilliant futureNumberDummy has a brilliant futureNumberDummy has a brilliant future
The only 4 speed transmission choice for 1961/63 F100/250/350/500/600/700's: Warner T-98.
No New Process 435's in F Series trucks (or anything else) till 1964.
There were no double letter transmission codes till 1980.
The A is part of the AXLE code...there should be a number after the A. > >
1961/62 F100: A1 = Spicer 44 ~ 3.73-1 w/Limited Slip (LS) / A2 = Spicer 44 ~ 3.91-1 w/LS / A3 = Spicer 44 ~ 4.10-1 w/LS.
On Warranty Plates, Ford sometimes didn't stamp the AXLE code, which follows the TRANS code in the correct location.
As Garbz2 posted above: TRANS code F = Warner Model AS120-T-98A 4 Speed Transmission.
EZ way to ID Warner 4 speed transmissions: The cap (8MTH7220) that retains the shift lever into the shift tower screws on/off.
The NP 435 cap (B8T7220D) is retained by two pins that protrude from the shift tower. The cap is notched and twists on/off by a 1/4 turn.
Info sources: 1957/63 & 1964/72 Ford Truck Parts Catalogs
__________________
Bill / Retired Ford Partsman ~ 1962/1997
Part Number Research available for the following: Trucks: 1928/2002 / Cars: 1928/2000
  #6 (permalink)
Old 07-18-2008, 09:14 AM
Well, here is my data plate - If what you said is correct, the axle code would be A12, if you could please decode that I will be forever greatful.
Thanks again for all the great, rapid responses!
  #7 (permalink)
Old 07-18-2008, 10:08 AM
Is a four wheel drive.......F11.........
Need that info to do a decode...
Alxes for the 4x4s have a letter and number, the letter being the weight capacity of the front axle and the number being the type rear axle and ratio of each. Dont have my books in front so ND should be able to finish it.
Garbz
__________________
05 Escape XLT
  #8 (permalink)
Old 07-18-2008, 11:44 AM
Yes, it is a 4WD
  #9 (permalink)
Old 07-18-2008, 03:07 PM
Ford Parts Guru
Garbz
That's not quite correct Dave.
A12 is the axle code...but when a letter * is the first digit of the code, that denotes Limited Slip, and when three digits are present, the third digit denotes the front axle code.
The third digit is used for either 4WD front axles, or if the weight capacity of the front axle is not the standard axle---this last part refers to F500 and larger trucks thru 1969. After 1969, all the big trucks have a three digit code, regardless if the front axle is heavier than standard or not.
A1 is the rear axle code: Spicer (Dana) 44 / 3.73-1 / Limited Slip / 3300 lbs. Rear Axle Capacity
2 is the front axle code: Spicer (Dana) 446F / 3.73-1 / non Limited Slip / 3000 lbs. Front Axle Capacity
* Letter code as the first digit denotes Limited Slip for all vehicles, car & truck from 1959 thru today. 1959 was the first year Ford offered Limited Slip.
__________________
  #10 (permalink)
Old 07-18-2008, 03:24 PM
Ford Parts Guru
The Big Dummy sez: This is very hard to read even after I expanded it. And...it can't be expanded when the post is quoted.
Unlike you young 'uns, the Dummy was born when FDR was Prez and my eyes aren't the greatest, even after cataract & lazik treatment!
See my profile for how ancient the Dummy is. If someone else wants to try, be my guest...I have errands to run, be back later with a magnifying glass!
__________________
  #11 (permalink)
Old 07-18-2008, 03:38 PM
I wll re check what my factory 62 63 shop manual supplement Sez....
For my Hight boy Crew the axle code is 24K for a 1969.....Dana 60 rear 4.10 and 44HD front 4.10
Garbz
Garbz
__________________
05 Escape XLT
  #12 (permalink)
Old 07-18-2008, 06:03 PM
Ford Parts Guru
For my High Boy Crew the axle code is 24K for a 1969.....Dana 60 rear 4.10 and 44HD front 4.10 Garbz
24: Dana 60 / 4.10-1 / non Limited Slip / 5200 lbs. Rear Axle Capacity
Rear Axle Decode: 1966/69 Rear Axle Code Chart / Section 40.1 / Page 13.
K (1968/69): Dana Model 446BF HD / 4.09-1 / 3500 lbs. Front Axle Capacity
Front Axle Decode: General Info Section / Front Axle Codes / Page 78.
Both decoded from the: 1964/72 Ford Truck Parts Catalog.
__________________
  #13 (permalink)
Old 07-18-2008, 06:45 PM
Ford Parts Guru
This puppy is hard to read even with a magnifying glass. Even "she, who must be obeyed" can barely read it and she's a young 'un like y'all are.
F11CK?22669 / 120 / B / F113 / Trans/Axle decoded elsewhere / 5600 / 155 / 3800 / 1372
F11 = F100 4WD
C = 292 2V
K = Kansas City Assembly Plant
?22669 (I can't make out the first digit). If the first digit is a 1, it's a 1961 assembled in December 1960 // If the first digit is a 2, it's a 1962 assembled in October 1961 // If the first digit is a 3, it's a 1962 assembled in August 1962 // If the first digit is a 4, it's a 1963 assembled in June 1963.
120" Wheelbase
B = Turquoise (1961) B = Caribbean Turquoise (1962/63)
F113 = F100 4WD / 5600 lbs. GVWR
155 HP @ 3800 RPM
1372: 13 = New York City Ford District Sales Zone Office, where the original selling dealer ordered the truck from. / 72 = Special Order Number
The truck was special ordered by the original purchaser.
__________________
  #14 (permalink)
Old 07-18-2008, 09:07 PM
Number: the VIN is F11CK222669
Is there any way to find out what options the original owner ordered?
Thanks so much for your help!!
Justin
  #15 (permalink)
Old 07-18-2008, 11:06 PM
Ford Parts Guru
The VIN is F11CK222669 = 1962, assembled October, 1961.
Justin
Everything that was decoded is RPO = Regular Production Order, so there's no way to discover what might have been special ordered...unless it's the "back of cab" equipment.
What type of bed does it have?
__________________
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Terms of Use - Privacy Policy - JOBS
Ford-Trucks.com and Internet Brands, Inc. is not affiliated with the Ford Motor Company.
© 1997-2007 Internet Brands, Inc., Please see our Terms of Use / Privacy Policy
