Lube for 6spd stick
I looked around, trying find what the stick shift drivers use in the transmission. I have changed it out to AMSOIL ATF. However it still shifts tight as well as having problems getting in the gate. Just not a smooth slick shift
The best I can find is Royal Purple Synchomax
Recommendations
I also saw a post about a short shift linkage shifter setup - cannot find it again.
Thanks
__________________
2005 RED F350 6.0 C&C, 6spd,4x4,SC,4:10LS, DRW, Alum Flat bed, Trailer Brake Control, Prodigy Brake control-backup, Post turbo Temp ISSPRO, IEQUUS Water Temp,Oil Press Gauges, Dieselsite water filter, DS-DAHL Fuel Filter, Straight piped, Up-pipe EGR fix, EGRv dummy spool,CCV re-route, SCT 5Startuning STK+20, 40 tow, 60 tow Del 5/19, Build 2/28/05,
