thanks for the quick reply
Thanks for the quick response. I guess what I need to do is degrease the truck and pressure wash it and then drive it a bit and look at the spin on filter adapter.
When I built the truck I broke in the cam but never put any miles on it. Then it sat for a long while- nearly 8 months maybe more. Got back to it got it running, and had a leaky rear main seal (my fault I forgot to put those two pins in). Put a new filter on it at that time. Got it on the road just to test it, jut going up and down the street by my shop, no more than a mile total over several months, but I would crank it at least once a week and let it run and would back it in and out of the shop.
This is the first time I actually got it on the road, and I drove it several miles over several days. On about day 3 or 4 is when this started. I'm out of town and was visiting some friends. On the way back to my hotel it drained 4 quarts out and zeroed the oil pressure gauge but I immediately shut it down, went back the next day put 4 qts in it (dipstick read nothing) and it cranked up and I loaded it on the trailer where it sits until I head home . I hope I didn't damage the motor. Didn't sound bad on the last start up.
So do you suppose the oil filter adapter could have worked its way bad? I did notice the pump was a little wet before i left the shop. also there is now a lot of oil on the trailer, but it could be just dripping off the truck itself. The suspension is wet, the transmission, it really bathed the thing in oil.
Also the oil is way high on the firewall, so it very well could be the valve cover gaskets. If that is the case then top end oiling is definitely not an issue!! At one point before getting it on the road I did pull the valve covers off just to check the top end and just put them back on without new gaskets. But usually a bad valve cover gasket is a long time slow leak, Ive never seen a severe case.
