2005 F250 FX4 - AC Blowing through Defrost only
I have a 05' F250 6.0L, The Ac blows thru the defrost... It must be the the vacuum pump or vacuum lines, How do I check for leaks in the lines? I checked the fuses they all seem fine. its going to be very hot this week now I want it fixed.. Any help with this would be great thanks.. My truck has manual hubs and 4x4 selector.. Not a leak there...
Vacuum Pump bad and also Vaccum leak.
I had Defrost only too, although the hot/cold air still worked. I pulled the connector and there was power to the connector. My vacuum pump motor was bad. I found one at ROCKAUTO.COM for ~ $65, Dorman brand. Replaced it and the pump would not stop running. It made lots of noise. Fortunately, the leak was in one of the hoses in front of the pump. I got lucky and one of the hoses I pushed on caused the motor to stop. I still need to do a vacuum leak down check just to make sure something else isnt bleeding off the vac.
The failure was caused by the vacuum line leak which caused my motor to always be running and trying to pull vaccum. Eventually it failed.
2003 6.0 Diesel F-350 Crew Cab, Long Bed, FX4 Long Bed Sacramento, Calif.
big79bronco
1983 - 2012 Ranger & B-Series
07-28-2023 07:44 PM
eodtek32
06-07-2014 08:04 AM
