Go Back   Ford Truck Enthusiasts Forums > Diesel > 1999 - 2003 7.3L Power Stroke Diesel
Sign in using an external account
Register Forgot Password?
1999 - 2003 7.3L Power Stroke Diesel SPONSORED BY:
  #1 (permalink)
Old 07-17-2008, 01:03 AM
jtharvey's Avatar
jtharvey jtharvey is offline
Garage is empty, add now
jtharvey is a name known to alljtharvey is a name known to alljtharvey is a name known to alljtharvey is a name known to alljtharvey is a name known to alljtharvey is a name known to all
Cummins Conversion Update
Now that I'm back from vacation and most of the parts have shown up, I have been getting to work on the conversion a lot more. Mostly I've been working on it in the evenings after I get home from work.
So far, I've got the aftermarket valve springs installed, injectors pulled and sent off for and upgrade, installed a fuel bowl delete, and got the adapter plate & starter fitted up. I'm still waiting on headstuds, as they accidentally got shipped to the vendor instead of being drop shipped to me direct from ARP. They are on their way to me now.
Next up on the list is to get the new cam installed, which I'm going to try and have done by the weekend. An ATS exhaust manifold is on the way to me as well, and once it gets here I'll install it and the new turbo (which is here already, and it's really shiny). Hopefully by that time that's done, the headstuds will be here so I can get them installed and the injectors will not be far behind them. After injectors are in, I can finally start putting everything back together on the engine, like the rockers, valve cover, and a new intake horn.
Of course, there's still getting all the Ford sensors mounted on the engine so the dash gauges will work, hooking up the PCS controller for the trans, getting everything else wired up, and finalizing my fuel delivery. There's also the slight chance that I'll end up with dual CP3's before the engine goes in the truck as well.
Anyway, it's been pretty slow going but now I'm hitting it pretty hard. Here's the album where I'll be posting pictures as progress continues:
__________________
Jeremy
See My Webshots for pics.
  #2 (permalink)
Old 07-17-2008, 01:08 AM
TP83's Avatar
TP83 TP83 is offline
TP83 is starting off with a positive reputation.
lookin good, can't wait to see it in the truck.
__________________
Taylor
2002 F250 7.3 XLT Ext. Cab LB 4x4. 8" lift and 38" MTZs on 16s. 3 pillar with DiPricol Optix gauges, 4"turbo back exhaust and a 6"tip DP-Tuned:Stock/60T/80E/140agressive/Drive-thru( so i can sneak around)
http://i277.photobucket.com/albums/k...IMG_5207-1.jpg
  #3 (permalink)
Old 07-17-2008, 01:27 AM
dirty1 dirty1 is offline
dirty1 is starting off with a positive reputation.
Sounds awsome! I am happy to see that you can get more done now with all of the new parts. Good luck with the rest.
__________________
Matt
2002 F350 7.3PSD, 4" Pro-Comp lift, 35" Pro-Comp mud terrains, AFE stage 2 intake, ATS 4" dual exhaust, Autometer gauges in A-pillar mount, Garrett BB turbo, non-EBPV, High flow exhuast flange, SS HPX, CCV, DP F5, BTS VB and other stuff that I have forgot.
New England Chapter member!
  #4 (permalink)
Old 07-17-2008, 01:46 AM
Lead Head Lead Head is online now
Lead Head has a great reputation on FTE.Lead Head has a great reputation on FTE.Lead Head has a great reputation on FTE.Lead Head has a great reputation on FTE.
Curious why you decided to swap the cam? I thought the stock cam was good enough for most high HP purposes?
__________________
- Ian
1987 Ford Ranger XLT 4x4 2.9
Needs a lot of work, including some rot on the body, but shes getting there.
  #5 (permalink)
Old 07-17-2008, 01:57 AM
jtharvey's Avatar
Quote:
The cam swap is not about HP, it's more about driveability. The F1 Helix 2 cam that I'm putting in will give quicker spool, better throttle response, and lower EGT's. The stock cam is designed more for emissions, and I'm simply correcting that. However, with an increased lift and duration on both the intake and exhaust side, there will be some peak power gains, but that's just not the main reason I'm doing it.
__________________
Jeremy
  #6 (permalink)
Old 07-17-2008, 03:40 AM
ron's power stroke's Avatar
ron's power stroke ron's power stroke is offline
ron's power stroke has much to be proud ofron's power stroke has much to be proud ofron's power stroke has much to be proud ofron's power stroke has much to be proud ofron's power stroke has much to be proud ofron's power stroke has much to be proud ofron's power stroke has much to be proud ofron's power stroke has much to be proud ofron's power stroke has much to be proud ofron's power stroke has much to be proud of
very nice Jaremy...glad to see she is going together good..should look sharp with all them shiny new parts..cant wait to hear her run...good luck to ya..looking forward to the updates as you go along......
__________________
Early 99 7.3 F350 auto,TN T-4 mount with a s467 for air,SRP 1.1 for oil,H-11 stud's,"NEW" alliant 315/200 hybrids, all supplied by unlimited diesel..shimmed 910's, DI push rod's, full fuel with a fuel lab 4202,TSD sump...tuned by Gearhead..i cant wait to drop her in the truck...
http://inlinethumb43.webshots.com/50...200x200Q85.jpg
  #7 (permalink)
Old 07-17-2008, 06:17 AM
greedy737 greedy737 is offline
greedy737 has a good reputation on FTE.greedy737 has a good reputation on FTE.greedy737 has a good reputation on FTE.
Nice work! Hope everything turns out Ok.. Is the truck ready for the motor yet, mounts ect.?
__________________
RONNIE
2001 F250 4x4 Turboback 3.5" straight pipe side exit, Superchips, Zoodad, 6637, WW, Bellowed Up Pipes http://www.powerstroke.org/forum/ima.../drinking4.gif
PAA Member# 42
  #8 (permalink)
Old 07-17-2008, 06:20 AM
F350-6's Avatar
F350-6 F350-6 is offline
F350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputation
Thanks for the update and the new pics. Is it me, or does that turbo look kind of small? I'm not up on the 5.9, but I figured you'd be going after some ugly HP numbers so you'd want plenty of air.
__________________
Chris
2002 F350 6-speed 444 CID. XLT, Heated Seat, 400,000 & counting.
RHN Mods & Maintenance
“Good judgment comes from experience, and a lot of that comes from bad judgment.” Will Rogers
  #9 (permalink)
Old 07-17-2008, 07:42 AM
03_PSD's Avatar
03_PSD 03_PSD is offline
2003 Ford F-250
03_PSD has a great reputation on FTE.03_PSD has a great reputation on FTE.03_PSD has a great reputation on FTE.03_PSD has a great reputation on FTE.
sweet Jeremy!! thanks for the update. sounds like you got all your ducks in a line, hope all goes well!
__________________
Glenn
03 F250 Lariat 4x4~6 Gears~ProComp Lift~PHP Phoenix~4 Gauges~Van Turbo~5" Exh~AFE BHAF~ITP OBA~RDP AIH Delete~SS HPX~CCV~CCK RR~DS Coolant Filter~Alum. Rear Diff~Smoke Cab Lights~IH Emblems~Fumoto Plug~UP-PIPES~08 Console~Harley Rims~Harley Eyes w/RS HID kit~05 Facelift
  #10 (permalink)
Old 07-17-2008, 10:32 AM
jtharvey's Avatar
Quote:
There's really not much to do to the actual truck. The motor mounts will bolt up to the engine, then set the engine in place and from underneath, I'll drill through the steel plates of the custom mounts and bolt it in place. Those steel plates sit on the front crossmember and you use the stock motor mounting holes in the crossmember.
Quote:
The turbos on the 5.9's are definately smaller than what the 7.3 can spin. What you're used to seeing as a moderately sized single charger on a 7.3 is pretty easily the larger charger on a 5.9's compound system.
I'm going after 600+ HP for the moment, and the charger I've got should do it. It won't like it at 600 HP, it's happier at 500-550, but it'll lay down 600 if I ask it to.
__________________
Jeremy
  #11 (permalink)
Old 07-17-2008, 10:41 AM
PaysonPSD's Avatar
PaysonPSD PaysonPSD is offline
Support FTE
1999 Ford F-250
PaysonPSD has a spectacular reputation.PaysonPSD has a spectacular reputation.PaysonPSD has a spectacular reputation.PaysonPSD has a spectacular reputation.PaysonPSD has a spectacular reputation.PaysonPSD has a spectacular reputation.PaysonPSD has a spectacular reputation.PaysonPSD has a spectacular reputation.PaysonPSD has a spectacular reputation.PaysonPSD has a spectacular reputation.PaysonPSD has a spectacular reputation.
Jeremy,
Thanks for the update and pics. Like all I am looking forward to seeing it under the hood and hearing it run. Let's hope "Murphy's Law" stays clear of this project. Good luck, but I sure hope you don't need it.
That turbo is beautiful. When you said "shiny" you meant "SHINY"
  #12 (permalink)
Old 07-17-2008, 01:47 PM
jeffthralls's Avatar
jeffthralls jeffthralls is offline
jeffthralls is starting off with a positive reputation.
Thanks for the update. It's great to hear, I've been following your posts to see how things are going. Good luck and keep the pics coming!!
__________________
2001 F250 excab LB, 6637(w/ homemade pre-filter), 285/75/16 Cooper Discoverer ATR's on stock wheels, Bilstiens on all four, Bushwacker O.E flares ,grill inserts ,marineco block heater cord end mod, more mods to come!!
1990 5.0L LX vert(7-Up Edition), 5spd, hurst shrt thrw, 5lug, 245/45/17s on '99 Cobras, cold air intk, 70mm thrtl bdy, long tube-off road H, Taylor's, performer rpm.
1999 Cobra lots of mods
  #13 (permalink)
Old 07-17-2008, 02:01 PM
Kwikkordead's Avatar
Kwikkordead Kwikkordead is offline
1999 Ford F-550
Kwikkordead has a superb reputationKwikkordead has a superb reputationKwikkordead has a superb reputationKwikkordead has a superb reputationKwikkordead has a superb reputationKwikkordead has a superb reputationKwikkordead has a superb reputationKwikkordead has a superb reputationKwikkordead has a superb reputationKwikkordead has a superb reputationKwikkordead has a superb reputation
http://www.facebook.com/http://facebook.com/Kwikkordead#!/Kwikkordead
__________________
Dan
1999 F550 4x4 ZF6 pulling a Cedar Creek 36RLTS. Lotta mods.
1999 VW Jetta TDI 5speed stick, Titan 520's, CCV, EGR, CAT.
2000 VW Passat 1.8t Tiptronic. ZZOOOOOMMMM!!!
1996 Audi A4 Quattro. Unstoppable in the snow and ice.
You cannot explain or explain away the power of God.
  #14 (permalink)
Old 07-17-2008, 02:54 PM
Ponyboychris's Avatar
Ponyboychris Ponyboychris is offline
Hit it!
2002 Ford F-350
Ponyboychris has much to be proud ofPonyboychris has much to be proud ofPonyboychris has much to be proud ofPonyboychris has much to be proud ofPonyboychris has much to be proud ofPonyboychris has much to be proud ofPonyboychris has much to be proud ofPonyboychris has much to be proud of
ChrisMPorras
Nice pics. Too bad I ain't closer, would love to see how this goes in. Typical of a gearhead, eh?
__________________
Chris
2002 F350 XLT, 7.3L CC 4x4, SRW, Autometer Ultralites, DP TUNER, BTS Trans, 6.0 tranny cooler, F650 dash, AIS w/zoodad, Warn Hubs, 4" MBRP exhaust, '08 rear end cover, Foil Delete, Heated Tow Mirrors, AIH Delete, Homemade CCV mod., Bilsteins.
The Silver Bullitt PAA# 24
  #15 (permalink)
Old 07-17-2008, 04:59 PM
PowerstrokeJunkie's Avatar
PowerstrokeJunkie PowerstrokeJunkie is offline
2002 Ford F-350
PowerstrokeJunkie is a splendid one to beholdPowerstrokeJunkie is a splendid one to beholdPowerstrokeJunkie is a splendid one to beholdPowerstrokeJunkie is a splendid one to beholdPowerstrokeJunkie is a splendid one to beholdPowerstrokeJunkie is a splendid one to beholdPowerstrokeJunkie is a splendid one to beholdPowerstrokeJunkie is a splendid one to behold
__________________
7.3 fully built longblock for sale PM me
Tags
1999, 2008, 450, 5r100, 73, conversion, cummings, cummins, f450, fod, ford, forums, reviews, transplant, truck, trucks
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
