Go Back   Ford Truck Enthusiasts Forums > Older, Classic and Antique Trucks > 1948 - 1960 F1, F100 And Larger F-Series Trucks
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
1948 - 1960 F1, F100 And Larger F-Series Trucks Discuss The Fat Fendered Bonus Built, Classic and Box Style Ford Trucks
Is F-150 Still King?
LinkBack Thread Tools
  #1 (permalink)
Old 07-16-2008, 09:56 PM
james G. phillips is starting off with a positive reputation.
Where does the generator ground wire connect?
I have a question for any of you diehards out there who have retained the generator and voltage regulator for thier old Ford truck motor. Where can you connect the wire from the ground terminal on the Ford generator? I have heard it is just a ground and you can ground it anywhere bit is this true?The shop manual diagram kind of contradicts this. It shows this wire going to the battery terminal on the regulator and acouple of grounds running off that wire. Does it need to be connected to the regulator bsttery terminal or just grounded? If it just needs to be grounded where can I ground it? Can it be on the motor, frame, body sheetmetal or any of these? I know I'm showing my ignorance on electrics but I'm never too old to learn.
Sponsored Links
To remove this ad, register today!
  #2 (permalink)
Old 07-16-2008, 09:59 PM
LiftTech is starting off with a positive reputation.
What year of truck are we dealing with? I don't know if it makes a difference, but it might.
On my '56, the ground wire comes off the generator and attaches to one of the mounting screws for the voltage regulator, grounding to the inner fender. Thus, you can ground it to the body sheet metal, the frame, or even directly to the battery negative terminal.
__________________
1956 F-350, dually with a hydraulic dump Ford flatbed, daily driven.
"Measure your wealth not by the things you have but by the things for which you would not take money."
  #3 (permalink)
Old 07-16-2008, 11:49 PM
ALBUQ F-1's Avatar
ALBUQ F-1 is gaining momentum as a positive member of FTE.
If this is a Bonus Built truck, it's the same as Liftech described. The screw that holds the reg to the firewall is used as a ground. It is important that the reg be solidly grounded. But personally I'd run additional grounds from there to the block and to the ground terminal on the battery.
__________________
Ross
1952 F-1 Flat V8 3-on-the-tree
MSD dizzy, 2110 Holley, Red's Headers
  #4 (permalink)
Old 07-17-2008, 05:04 AM
It's a 53 flathead V8 I'm converting to 12 volt. So it should hook up like yours LiftTech.I'll take your advice Ross. Seems like I've heard that before; yhat you can't have too many grounds. Thank you both.
  #5 (permalink)
Old 07-17-2008, 05:56 AM
Brian_B's Avatar
Brian_B is gaining momentum as a positive member of FTE.
I guess you already have the answer.
I was going to say I can go look at mine in the daylight. Not necessary now. Too late.
__________________
Editorial removed from sig.
  #6 (permalink)
Old 07-17-2008, 06:16 PM
Thanks anyway Brian. Isaw on here you have been on the sick list. I hope you're doing better now.
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Ford-Trucks.com and Internet Brands, Inc. are not affiliated with the Ford Motor Company.
