07-16-2008, 08:29 PM
Headlight switch and Wiper control question
This is a two parter.
A couple of things that have been messed up on my truck for a long time and up to this point, I just let them go...am I the only one?
First, the headlight switch has a bad potentiometer. The headlights work, but sometimes the dash lights go out. If I rotate the headlight switch left and right a few times, the dash lights turn back on. I can't control the brightness, just on or off...until I hit a bump, then they may go off again.
How does that switch come out? Do I just pry off the front where the switch is mounted?
The second is the wiper control. When I turn on the wipers (intermittent, anywhere between lowest and highest setting) I hear chattering from under the glove box and I get a swipe, but they won't swipe again unless I move the switch forward or backward a click. They work on regular and high. You see, I think somebody spilled a soft drink on the turn signal stalk. I sprayed stuff in there sort of, but the poor connection won't go away.
How do I replace the wiper control assembly? Does it unscrew from the turn signal stalk or what?
Thanks for any and all help!!!!!
