FORD F-350 2004 Rear axle seal replacement - Ford Truck Enthusiasts Forums
1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Old 07-16-2008, 07:30 PM
mikestoke's Avatar
mikestoke mikestoke is offline
mikestoke is starting off with a positive reputation.
Hello can any one help me on replacing the rear axle seals on my truck? I am going to do this myself but have not gotten into any yet. Are the rear axles "floating axles"? And is this a big job? What Seals do you Recommend putting back in? Also any torque specs? Any help will HELP alot..
Thanks Mike
Old 07-16-2008, 10:47 PM
highland61 highland61 is offline
highland61 is starting off with a positive reputation.
<TABLE width="95%"><TBODY><TR><TD>SECTION 205-02C: Wheel Hubs and Bearings Full Floating Axle Dana
</TD><TD align=right>2008 F-Super Duty 250-550 Workshop Manual
</TD></TR><TR><TD>REMOVAL AND INSTALLATION
</TD><TD align=right>Procedure revision date: 01/02/2007</TD></TR></TBODY></TABLE>
<HR>
Wheel Bearings, Wheel Hub Seal and Wheel Bearing Cups <SUP> Printable View (325 KB)</SUP>
<META content="Wheel Bearings, Wheel Hub Seal and Wheel Bearing Cups" name=tps_proctitle>
<TABLE cellSpacing=0 cellPadding=3 width="50%" border=1><CAPTION>Special Tool(s)</CAPTION><TBODY><TR vAlign=top><TD></TD><TD vAlign=top>Adapter for 303-224 (Handle)
205-153 (T80T-4000-W) </TD></TR><TR vAlign=top><TD></TD><TD vAlign=top>Drawbar, Rear Axle
205-098 (T75T-1176-A) (Dana 80) </TD></TR><TR vAlign=top><TD></TD><TD vAlign=top>Installer, Rear Wheel Hub Bearing Cup
205-278 (T88T-1175-C) (Dana 80) </TD></TR><TR vAlign=top><TD></TD><TD vAlign=top>Installer, Wheel Hub Inner Oil Seal
205-445 (Dana S110, S130) </TD></TR><TR vAlign=top><TD></TD><TD vAlign=top>Remover, Rear Wheel Hub Bearing Cup
205-275 (T88T-1175-A) (Dana 80) </TD></TR><TR vAlign=top><TD></TD><TD vAlign=top>Installer, Rear Wheel Hub Bearing Cup
205-100 (T75T-1225-B) (Dana 80) </TD></TR><TR vAlign=top><TD></TD><TD vAlign=top>Remover, Rear Wheel Hub Bearing Cup
205-277 (T88T-1175-B) (Dana 80)</TD></TR></TBODY></TABLE>
F-350
<TABLE cellSpacing=0 cellPadding=3 width="70%" border=1><TBODY><TR><TH vAlign=bottom>Item</TH><TH vAlign=bottom>Part Number</TH><TH vAlign=bottom>Description</TH><TR vAlign=top><TD>1 </TD><TD>4234 </TD><TD>Axle shaft</TD></TR><TR vAlign=top><TD>2 </TD><TD> </TD><TD>O-ring (part of 4234)</TD></TR><TR vAlign=top><TD>3 </TD><TD>1124 </TD><TD>Hub nut</TD></TR><TR vAlign=top><TD>4 </TD><TD>1240 </TD><TD>Outer rear wheel bearing</TD></TR><TR vAlign=top><TD>5 </TD><TD>1239 </TD><TD>Rear wheel bearing outer cup</TD></TR><TR vAlign=top><TD>6 </TD><TD>1109 </TD><TD>Rear hub and rotor assembly</TD></TR><TR vAlign=top><TD>7 </TD><TD>1243 </TD><TD>Rear wheel bearing inner cup</TD></TR><TR vAlign=top><TD>8 </TD><TD>1244 </TD><TD>Inner rear wheel bearing</TD></TR><TR vAlign=top><TD>9 </TD><TD>1175 </TD><TD>Rear hub seal</TD></TR></TBODY></TABLE>
F-450 and F-550
<TABLE cellSpacing=0 cellPadding=3 width="70%" border=1><TBODY><TR><TH vAlign=bottom>Item</TH><TH vAlign=bottom>Part Number</TH><TH vAlign=bottom>Description</TH><TR vAlign=top><TD>1 </TD><TD>4A140 </TD><TD>Axle shaft bolt</TD></TR><TR vAlign=top><TD>2 </TD><TD>1001 </TD><TD>Rear axle shaft gasket</TD></TR><TR vAlign=top><TD>3 </TD><TD>1012 </TD><TD>Wheel nut</TD></TR><TR vAlign=top><TD>4 </TD><TD>2C026 </TD><TD>Brake disc</TD></TR><TR vAlign=top><TD>5 </TD><TD>1244 </TD><TD>Inner rear wheel bearing</TD></TR><TR vAlign=top><TD>6 </TD><TD>1175 </TD><TD>Hub seal</TD></TR><TR vAlign=top><TD>7 </TD><TD>1109 </TD><TD>Rear hub (includes bearing cups)</TD></TR><TR vAlign=top><TD>8 </TD><TD>1240 </TD><TD>Outer rear wheel bearing</TD></TR><TR vAlign=top><TD>9 </TD><TD>1A124 </TD><TD>Hub nut</TD></TR><TR vAlign=top><TD>10 </TD><TD>4234 </TD><TD>Axle shaft</TD></TR></TBODY></TABLE>
Removal
  1. Remove the rear wheel hub. For additional information, refer to Wheel Hub in this section.
  1. Remove the rear hub seal and the inner rear wheel bearing.
    • Discard the rear hub seal.
  1. If not done previously, remove the 8 bolts and separate the rear hub from the brake disc.
  1. Clean all the old grease and axle lubricant out of the rear hub.
  1. Remove the inner and outer bearing cups.
    1. For model 80, use special tools 205-277 and 205-153 to remove the inner bearing cup. For model S110 or S130, use a suitable brass drift.
    1. For model 80, use special tools 205-275 and 205-153 to remove the outer bearing cup. For model S110 or S130, use a suitable brass drift.
  1. Clean the following components:
    • The rear axle housing spindle.
    • All the old grease and axle lubricant from the rear hub.
    • The rear wheel bearings and cups.
  1. Inspect the bearing races and rollers for pitting, galling or erratic wear patterns. Check the rollers for end wear. Discard the bearings, if necessary.
    1. A typical new bearing roller.
    1. A worn bearing roller.
Installation
  1. For model 80, using the special tools 205-098, 205-100, and 205-278, install the inner and outer bearing cups. For model S110 or S130, use a suitable driver.
    • Check to see if a 0.038 mm (0.0015 in) feeler gauge can be inserted between the cups and the rear hub at any point around each cup. Reseat the bearing cups, if necessary.
  1. Install the inner rear wheel bearing in the rear hub.
  1. Install a new rear hub seal.
    • For model 80, use a suitable seal installer.
    • For model S110 or S130, use special tools 205-445 and 205-153.
  1. Position the rear brake disc on the rear hub and install the 8 bolts.
    • Tighten to 155 Nm (114 lb-ft).
  1. Install the rear wheel hub. For additional information, refer to Wheel Hub in this section.
Old 07-16-2008, 10:50 PM
OR,
<TABLE width="95%"><TBODY><TR><TD>SECTION 205-02E: Wheel Hubs and Bearings Full Floating Axle Ford
<HR>
Wheel Bearings, Wheel Hub Seal and Wheel Bearing Cups <SUP> Printable View (512 KB)</SUP>
205-153 (T80T-4000-W) </TD></TR><TR vAlign=top><TD></TD><TD vAlign=top>Installer, Axle Bearing
205-099 (T75T-1225-A) </TD></TR><TR vAlign=top><TD></TD><TD vAlign=top>Installer, Axle Bearing
205-100 (T75T-1225-B) </TD></TR><TR vAlign=top><TD></TD><TD vAlign=top>Installer, Differential Bearing Cup
308-163 (T88C-77000-FH) (use as Hub Inner Bearing and Seal Remover) </TD></TR><TR vAlign=top><TD></TD><TD vAlign=top>Installer, Wheel Hub Oil Seal (10 1/2 inch)
205-422 </TD></TR><TR vAlign=top><TD></TD><TD vAlign=top>Remover, Wheel Hub Inner Bearing Cup (10 1/2 inch)
205-421 </TD></TR><TR vAlign=top><TD></TD><TD vAlign=top>Remover, Wheel Hub Outer Bearing Cup (10 1/2 inch)
205-420</TD></TR></TBODY></TABLE>
<TABLE cellSpacing=0 cellPadding=3 width="50%" border=1><CAPTION>Material</CAPTION><TBODY><TR vAlign=top><TH>Item</TH><TH>Specification</TH></TR><TR vAlign=top><TD>Premium Long-Life Grease
XG-1-C or XG-1-K (US); CXG-1-C (Canada)</TD><TD align=middle>ESA-M1C75-B</TD></TR></TBODY></TABLE>
<TABLE cellSpacing=0 cellPadding=3 width="70%" border=1><TBODY><TR><TH vAlign=bottom>Item</TH><TH vAlign=bottom>Part Number</TH><TH vAlign=bottom>Description</TH><TR vAlign=top><TD>1 </TD><TD>N811648-S100 </TD><TD>Axle shaft bolt (8 required)</TD></TR><TR vAlign=top><TD>2 </TD><TD>4234 </TD><TD>Axle shaft</TD></TR><TR vAlign=top><TD>3 </TD><TD>2C026 </TD><TD>Rotor (single rear wheel [SRW])</TD></TR><TR vAlign=top><TD>4 </TD><TD>2C026 </TD><TD>Hub and rotor (dual rear wheel [DRW])</TD></TR><TR vAlign=top><TD>5 </TD><TD>1A124 </TD><TD>Hub nut (RH)</TD></TR><TR vAlign=top><TD>6 </TD><TD>1A125 </TD><TD>Hub nut (LH)</TD></TR><TR vAlign=top><TD>7 </TD><TD>1239 </TD><TD>Outer bearing cup</TD></TR><TR vAlign=top><TD>8 </TD><TD>1240 </TD><TD>Outer cone and roller</TD></TR><TR vAlign=top><TD>9 </TD><TD>1243 </TD><TD>Inner bearing cup</TD></TR><TR vAlign=top><TD>10 </TD><TD>1244 </TD><TD>Inner bearing</TD></TR><TR vAlign=top><TD>11 </TD><TD>4670 </TD><TD>Slinger</TD></TR><TR vAlign=top><TD>12 </TD><TD>1177 </TD><TD>Hub seal</TD></TR><TR vAlign=top><TD>13 </TD><TD>1A034 </TD><TD>Rear hub assembly (with cups)</TD></TR><TR vAlign=top><TD>14 </TD><TD>1109 </TD><TD>Rear hub assembly (complete)</TD></TR><TR vAlign=top><TD>15 </TD><TD>2209 </TD><TD>Parking brake assembly</TD></TR><TR vAlign=top><TD>16 </TD><TD>390258-S </TD><TD>O-ring</TD></TR><TR vAlign=top><TD>17 </TD><TD>W704709-S428 </TD><TD>Wheel stud</TD></TR></TBODY></TABLE>
Removal
NOTE: The single rear wheel (SRW) hub and the dual rear wheel (DRW) hub are different in appearance, however, the tools and procedures are the same with one exception: the brake disc can remain attached to the DRW hub if the longer driver handle is used to remove and install the bearing cups and seals.
NOTE: A SRW hub cutaway is shown for clarity in this procedure. However, the procedure is the same for the DRW hub.
  1. Position the special tools on the inner bearing.
  1. Using the special tools and holding the Handle straight, drive the inner bearing, slinger and hub seal out of the hub as a unit.
    • Remove the tools, bearing, slinger and hub seal.
  1. Position the special tool into the hub cavity and onto the inner bearing cup.
  1. Using the special tools, drive the inner bearing cup from the hub.
  1. Reposition the hub facing downward. Position the special tools on the outer bearing cup.
  1. Using the special tools, drive the outer bearing cup from the hub.
Installation
  1. With the hub facing upward, position the outer bearing cup in the hub bore and place the special tools on the bearing cup.
  1. Using the special tools, drive the outer bearing cup into the fully seated position.
  1. Reposition the hub facing downward. Position the inner bearing cup in the hub bore and place the special tools on the bearing cup.
  1. Using the special tools, drive the inner bearing cup into the fully seated position.
  1. NOTE: The hub bearings must be prelubed with grease prior to installation. Pack each bearing with a bearing packing tool. Also apply grease to the thrust surface of the bearing. Use Premium Long-Life Grease.
    Position the greased inner bearing in the inner bearing cup.
  1. NOTE: The grease on the bearing and slinger holds the slinger in position during seal installation.
    Position the slinger on the greased bearing with the tangs facing the bearing.
  1. With the slinger in place, position the hub seal in the hub bore and place the special tools on the hub seal.
  1. Using the special tools and holding the handle straight, drive the hub seal into position so that the seal flange bottoms out in the hub.
Old 07-16-2008, 10:57 PM
AND,
Material Item Specification Fill Capacity
XG-1-C or XG-1-K (US); CXG-1-C (Canada) ESA-M1C75-B —
Torque Specifications Description Nm lb-ft
Axle shaft bolts 133 98
Rear hub bolts 155 114
Rear hub nut
(To set bearings, back off the hub nut 90 degrees, retighten.) 95
24a 70
18
a Maximum torque to rotate the hub is 2.3 Nm (20 lb-in) when the end play is zero.
__________________________________________________ ________________________
Motorcraft SAE 75W-140 Synthetic Rear Axle Lubricant
XY-75W140-QL (US); CXY-75W140-1L (Canada) (vehicles with the trailer towing option or 4:10 ratio) WSL-M2C192-A —
Stud and Bearing Mount
TA-27 WSK-M2G349-A1 —
Axle shaft bolts 109 80
Hub nuta — —
a Refer to the procedure in this section.
Old 07-16-2008, 11:18 PM
thedaddycat thedaddycat is offline
thedaddycat is gaining momentum as a positive member of FTE.
I changed the inner seals on my truck last fall. One thing is if the inner part of the seal stays on the truck, just hit it with the rounded end of a ball peen hammer. It will cause the thin metal to spread out and give you enough growth in the diameter to slide it right off...
The bearings looked fine so I just repacked them, I had around 80K on it at the time.
Old 07-17-2008, 07:46 AM
F350-6's Avatar
F350-6 F350-6 is offline
F350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputation
Great job with the instructions highland61.
Here's a link with some pics of the seal change. http://www.ford-trucks.com/forums/74...ake-shoes.html
Old 07-17-2008, 12:16 PM
rob460 rob460 is offline
rob460 is starting off with a positive reputation.
that is real helpful .getting ready to do mine.
Old 07-17-2008, 09:13 PM
mikestoke's Avatar
Thanks for the detailed information. Are the specialty tools expensive or can i rent them some where?
Old 07-17-2008, 09:32 PM
Quote:
I didn't bother pricing the special tools, however, I hunted for a whole day trying to locate substitues based on the dimensions. Couldn't find them anywhere, checked with grainger and a few others online, nada. Wasn't going to sell my kids to even think about snap-on or mac.
You do need a good size hammer and use your old parts with some brass stock to set.
or
take the hubs and parts into a heavy truck shop....they have the right stuff.
Old 07-17-2008, 10:34 PM
mikestoke's Avatar
Ok thanks I'll let you know how it goes..
Old 07-18-2008, 12:02 PM
mikestoke's Avatar
Is this a Kit that i will be buying or will i have to buy it all seperate
Old 07-23-2008, 08:19 PM
mikestoke's Avatar
Does any one know what size the Hub nut is so i can buy the hub nut wrench? I've called the autoparts store and they dont have a clue!! 2004 F-350 SDD DWR 6.0
Thanks Mike
Old 07-24-2008, 06:29 AM
lisle ratcheting lock nut tool #28000
Old 08-07-2008, 09:06 PM
mikestoke's Avatar
Thanks again for the detailed info. Got everything changed today, Took about 2 hours. I couldnt of done it without you all!!
Mike
Need help, trying to replace axle seals. Dillabough54 1987 - 1996 F150 & Larger F-Series Trucks 4 08-12-2016 09:17 PM
Rear Axle Seal Replacement rmacinc Clutch, Transmission, Differential, Axle & Transfer Case 14 02-10-2016 07:05 PM
Noisy rear axle Magnus E Excursion - King of SUVs 60 12-31-2014 03:47 PM
REAR AXLE SEAL WEAR RING pacrewchief 1987 - 1996 F150 & Larger F-Series Trucks 3 06-09-2012 10:12 AM
Rear Axle Seal Leaking MauleOne 1999 to 2016 Super Duty 4 03-10-2012 06:59 PM
Tags
05, assembly, axle, bearings, f350, f550, ford, hub, rear, removing, rotors, seal, seals, tighten, wheel
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
