Go Back   Ford Truck Enthusiasts Forums > Misc. > Offroad and 4x4
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Offroad and 4x4 SPONSORED BY:
Is F-150 Still King?
  #1 (permalink)
Old 07-16-2008, 06:44 PM
oneofakind97's Avatar
oneofakind97 oneofakind97 is offline
oneofakind97 is starting off with a positive reputation.
hydro assist for dummies
i'm planning on taking the advice of some of you guys on here before i step up to 44" ground hawgs. i wanna run some hydro assist on my truck. i'd liek to find out if anyone is offering a direct bolt up kit (97 f350) or do i have to do alot of fab work. i now have a close friend that is helping me with alot of my fab work/expensive tool needs, so that part doesnt scare me as much as it used to.
i had found a kit by googling, but all it included was a ram, 2 lines, 4 mounting tabs and 2 bolts.
now do i use the ram to connect to the existing tie rods, or do i use the ram as a center and them connect 2 tie rod ends to it, running to the spindles? i havent gotten to measure it yet, but it looks like i have about 7-8" between my axle tube and me tie rod. if someone can break it down for me, i'd really appreciate it.
thanks.
  #2 (permalink)
Old 07-16-2008, 07:35 PM
uncle.stosh uncle.stosh is offline
uncle.stosh has a good reputation on FTE. uncle.stosh has a good reputation on FTE.
Not trying to be a jerk but if you are asking all of those questions, then you are not ready for a hydro setup.
Search, read, read some more, read even more until your brain hurts and then pay someone to do it for you.
It is not for the faint of heart and requires considerable fabrication skills and machining.
  #3 (permalink)
Old 07-16-2008, 07:58 PM
STGFordCrazy04's Avatar
STGFordCrazy04 STGFordCrazy04 is offline
STGFordCrazy04 is a splendid one to behold STGFordCrazy04 is a splendid one to behold STGFordCrazy04 is a splendid one to behold STGFordCrazy04 is a splendid one to behold STGFordCrazy04 is a splendid one to behold STGFordCrazy04 is a splendid one to behold
The one thing I cant help you with (no experience) is the steering box. You might contact redneck ram hydraulic steering assist for steering box info. They can sell you a complete set ready to go or tap your box for you.
You will want to beef your current tie rod and drag link to handle the stress. Im using 1.5 .250 DOM with chebby 1ton TREs. You will also need to buy a 1.5x8" stroke hydraulic ram and 2 mounts. Most use the weld on D ring mounts for a pretty easy setup. Ive seen several guys buy the thick 3/8 plate diff cover with the 1/2" center plate to weld the axle side mount to. I wouldnt weld the mount directly to the tie rod. Some companys sell clamp on style doo-hickeys (highly technical term used only by professionals) to weld the mounts to. This gives adjustability. Give me a few minutes and Ill post some links to the parts Im talking about.
__________________
Kris
Please do not PM me. My email is STGCountryboy312 at AOL dot COM
Quote:
Originally Posted by thorseshoeing
Yes you are the anti christ...
  #4 (permalink)
Old 07-16-2008, 08:01 PM
ibleedblue1385's Avatar
ibleedblue1385 ibleedblue1385 is offline
ibleedblue1385 has a very good reputation on FTE. ibleedblue1385 has a very good reputation on FTE. ibleedblue1385 has a very good reputation on FTE.
I think:
Search, read, read some more, read even more until your brain hurts and then DO IT YOURSELF... sounds better.
__________________
-Jesse ~Built Not Bought~
1986 F150 4x4/5.0/SAS/5.13's
1988 F150 4x4
1978 Bronco
Michigan Chapter Member
  #5 (permalink)
Old 07-16-2008, 08:17 PM
You can also search pirate. I said search not post but these links will help.
OD Tube Clamp
Heavy Duty Clevis / D-ring Tab
maybe this
http://www.diy4x.com/images/rammount.JPG
but Id prefer this. Get the one with the 1/2" plate center strip
Great Lake Offroad, LLC ~ extrme duty diff covers
__________________
Kris
  #6 (permalink)
Old 07-16-2008, 09:15 PM
mark a.'s Avatar
mark a. mark a. is offline
mark a. is gaining momentum as a positive member of FTE. mark a. is gaining momentum as a positive member of FTE.
1 1/2" doesn't do a hole lot of good with my 42's ( but it's better than nothing ) When I talked to Red Neck they said any bigger tire than 36's should use a 1 3/4" bore.
__________________
'79 F250 13" lift 42" Super Swampers
  #7 (permalink)
Old 07-16-2008, 09:37 PM
yeah but its sooooo slow around mall parking lots from what I understand.
__________________
Kris
  #8 (permalink)
Old 07-16-2008, 09:54 PM
quadzjr's Avatar
quadzjr quadzjr is offline
just another Rockwell looser
quadzjr has a great reputation on FTE. quadzjr has a great reputation on FTE. quadzjr has a great reputation on FTE. quadzjr has a great reputation on FTE. quadzjr has a great reputation on FTE.
Quote:
What the hell?
NO IT DOESN'T.........weld two tabs too your axle, the other two go to the tie rod, drill and tap your steering box, run the hydro lines and your done.........
__________________
Nick
STG's Minions: Sergeant at Arms
The Rockwell/4-link/anything Badass Specialist!
Dont be a puss, RUN ROCKS!!!!
Quote:
Originally Posted by Ebay Assjack View Post
The truck was lifted with the custom frame as seen in pix. (the best way to lift a truck!!!)
My Build: 96' f150 4link 2.5 tons etc etc etc....
  #9 (permalink)
Old 07-16-2008, 10:16 PM
RawPower's Avatar
RawPower RawPower is offline
RawPower has a very good reputation on FTE. RawPower has a very good reputation on FTE. RawPower has a very good reputation on FTE. RawPower has a very good reputation on FTE.
Umm... haha I STRONGLY disagree. This is one of the easiest projects I've done to my truck, other than swapping leaf springs or something stupid like that.
Dude, you can do this yourself- and easily too. Read this:
Tapping Steering Gear Box for Hydraulic Assist Lines (PICS) + ram/hose install - FSB Forums
Edit:
West Texas Offroad sells complete kits if you don't want to do it yourself.
  #10 (permalink)
Old 07-16-2008, 10:26 PM
Thanks for that link RawPower. It could come in useful.
__________________
1988 F150 4x4
1978 Bronco
  #11 (permalink)
Old 07-16-2008, 10:34 PM
RawPower's Avatar
Quote:
Yeah, its a great link. It's the best hydro-assist write-up I've ever seen.
  #12 (permalink)
Old 07-18-2008, 12:24 AM
Ronin4x4 Ronin4x4 is offline
Ronin4x4 is gaining momentum as a positive member of FTE. Ronin4x4 is gaining momentum as a positive member of FTE.
What!?! This is a very easy mod to do
__________________
Ford-man Forever!
  #13 (permalink)
Old 07-18-2008, 01:02 AM
my79f's Avatar
my79f my79f is offline
my79f is gaining momentum as a positive member of FTE.
last time i was out at katemacy here in texas i talked to the guy who owns redneck ram, and iirc he said send your box in to get rebuilt/tapped, pay $500 and you also get the proper ram, and hoses sent back to you to complete the setup. this is not a very hard project to take on. if you have a friend that can weld, and you know how to bolt on a PS box, then its cake.
also you could piece together your own system with a tractor supply ram, and and tap your own box. then you could go to a parts shop and have some hydro lines made up, that would probably run you around$200-$250.
__________________
The name's Austin, and i live in Austin, tx
MODS:
BTS transmission
Cales tunes
Kwik air filter mod
4 inch exhaust back to 6inch miters
Trans, pyro, boost gauges
Van turbo
T.E. SD Hpop
and a permagrin
all on a 1999.5, f350, 4x4
R.I.P #17
  #14 (permalink)
Old 07-18-2008, 03:56 PM
fishmanndotcom's Avatar
fishmanndotcom fishmanndotcom is offline
fishmanndotcom has a great reputation on FTE. fishmanndotcom has a great reputation on FTE. fishmanndotcom has a great reputation on FTE. fishmanndotcom has a great reputation on FTE. fishmanndotcom has a great reputation on FTE. fishmanndotcom has a great reputation on FTE.
its cake man... anyone can do it. i've done it to several trucks (including 2 of my own) and will be happy to answer more specific questions.
if i were you i would buy 1.5" or 1.75" ram from Burden Sales Surplus Center - Hydraulics, Engines, Electrical and More and then get your lines made from a local hydro shop. i went one step further on a couple of builds and bought the reuasble fittings and hose compatible with them so if i needed to repair something on the trail i could. drilling and tapping ford boxes is so easy i am surprised more people havent tried it! if you can slide the piston out without losing all the ball bearings you can do this pretty easy.
one note on the size of the lines just from exeperience, go with at least 3/8". repsonse time is much faster with large hoses and fittings (although one fitting on the box cannot be larger than 1/4"!)
-cutts-
__________________
My Google Photo Gallery
-96 F350 4x4 ZF5 CC/LB, 37" SSR's, D66 turbo, Stage-1's, Banks IC, 5" stacks, York OBA
-72 Bronco 302/NP435/D20/D60/10.25 welded F/R, full hydro, hydroboost, 39"iroks
  #15 (permalink)
Old 07-18-2008, 05:18 PM
mark a.'s Avatar
I'm getting rid of the AN fittings & hoses & getting regular hydraulic hoses made up. The AN fittings seep a little.
Fish, I'm wondering if going 3/8" would do any good for me cause my ram has 1/4" fittings welded on so it's still necked down at the fittings. Any thoughts ?
__________________
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
