Quote:
Originally Posted by superduty4x4
I'm familiar with the Pete Jackson and similar gear drives, but I've never heard or seen of a direct gear drive (both gears in mesh with eachother like the photo) on a car before.
The cam on a small block is designed to rotate in the same direction as the crank. With a chain it does naturally. When you use a gear drive the cam would rotate in the opposite direction, as in the picture, without the counter gears. i'm assuming the the cam in the pic is ground to rotate opposing the crank.
__________________
Ray
2000 F-250 SC/SB DP tuner, 4" straight pipe, gauges, Hutched/Harpooned, ITP intank, 6637,HPX, 20" wheels, DIY regulated return fuel system
'93 Lightning 393
and a bunch o motorcycles...
