Go Back   Ford Truck Enthusiasts Forums > Older, Classic and Antique Trucks > 1948 - 1960 F1, F100 And Larger F-Series Trucks
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
1948 - 1960 F1, F100 And Larger F-Series Trucks Discuss The Fat Fendered Bonus Built, Classic and Box Style Ford Trucks
Is F-150 Still King?
LinkBack Thread Tools
  #16 (permalink)
Old 07-18-2008, 09:18 PM
AXracer's Avatar
AXracer is gaining momentum as a positive member of FTE.AXracer is gaining momentum as a positive member of FTE.
The F100 regulators used a splined shaft rather than a square one. It has a necked down groove below the splines where a spring wire keeper in the handle snaps in to retain the handle. A square shaft would be too easy!
__________________
Passionate about autocross racing!
2003 GSL, 2005 HSL National Champion
1956 F100 Panel support/tow vehicle
2007 Solstice GXP
2002 Celica GT 2003 GSL National Champion
1999 Miata gone but not forgotten
Sponsored Links
To remove this ad, register today!
  #17 (permalink)
Old 07-18-2008, 10:15 PM
ghall is starting off with a positive reputation.
Many of the repop handles have a set screw (which in most cases is too small... drill/tap to larger size)...
I was able to 'hammer out' the escutcheons a bit to decrease their height with the door panels that existing in my 56... you can gain 'enough' right off the bat if you fold over the first 'bend' at the outer edges.
the thickness of your door panels may not let something like that work...
  #18 (permalink)
Old 07-20-2008, 10:09 PM
mytbtruck is starting off with a positive reputation.
Quote:
Sorry about that, I was thinking about the regulators on my 48. I know what you mean about simple. Most things are not simple anymore but we seem to find a way around that with somebodys help. Larry.
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Ford-Trucks.com and Internet Brands, Inc. are not affiliated with the Ford Motor Company.
