ADJUST VALVES on yblock? - Ford Truck Enthusiasts Forums
Old 07-16-2008, 01:45 PM
WALFORD'S 56 WALFORD'S 56 is offline
WALFORD'S 56 has a great reputation on FTE.WALFORD'S 56 has a great reputation on FTE.WALFORD'S 56 has a great reputation on FTE.WALFORD'S 56 has a great reputation on FTE.WALFORD'S 56 has a great reputation on FTE.WALFORD'S 56 has a great reputation on FTE.
Question ADJUST VALVES on yblock?
I need a few ideas on how to adjust my valves. I am not a mechanic--but more a painter. I need my yblock valves adjusted and do not have the tappet-tool and will need step-by-step instructions. 1 side is tapping and I need this fixed. Thanks ---Bill
Old 07-16-2008, 05:13 PM
Sam_Fear's Avatar
Sam_Fear Sam_Fear is offline
Sam_Fear has a good reputation on FTE.Sam_Fear has a good reputation on FTE.
From an old post:
"Well if you mean preliminary lash (COLD): Gap at .19 using a step feeler gauge is best. At TDC adjust Exhaust #1,4,5 Intake #1,2,7. Rotate crank 180 and adjust Ex 6,8 and In 4,5. Rotate crank 270 and adjust Ex 2,3,7 and In 3,6,8.
If you mean final lash (HOT): Use the step feeler gauge while the motor is warmed up and running at .18 gap. And remember to burn your arm at least once."
Old 07-16-2008, 07:46 PM
thanks Sam Fear---I will try to burn my arm at least once--LOL....Bill
Old 07-16-2008, 08:06 PM
46yblock's Avatar
46yblock 46yblock is offline
46yblock is gaining momentum as a positive member of FTE.
Quote:
Originally Posted by Sam_Fear View Post
From an old post:
Marking the outside of the crank pulley at 90, 180 and 270 degrees makes this very easy. Wild Bunch gave this tip quite a while back, and I have used it twice. Having the damper off, or motor out of truck simplifies the process more. Take a cloth type ruler like used in sewing. Put the end on the timing mark and wrap around damper to give the damper circumerence. Then divide the circumference by 4. That number will be the distance around the damper from the timing mark to 90 deg. Measure and make a mark at 90. Repeat multiplying by 2 for 180 and 3 for 270. I made marks using a yellow paint marker pen. Just dots but they show up well.
Old 07-17-2008, 11:52 AM
thanks---I am a dummy about engines anymore. I do mostly body and paint and always hope the engine stuff works out ok, but yblocks are a old school thing,and hard to find someone to do this. I know a guy in copley that could do it but won't. I wish he would just come over and do his magic on this good ole yblock--hint--hint!!!! Thanks guys--Bill
Old 07-18-2008, 01:38 PM
bigwin56f100's Avatar
bigwin56f100 bigwin56f100 is offline
bigwin56f100 has much to be proud ofbigwin56f100 has much to be proud ofbigwin56f100 has much to be proud ofbigwin56f100 has much to be proud ofbigwin56f100 has much to be proud ofbigwin56f100 has much to be proud ofbigwin56f100 has much to be proud ofbigwin56f100 has much to be proud ofbigwin56f100 has much to be proud of
Sorry, dont have time for trucks anymore. The bees are busy and so am I.
Kevin Bigwin
Old 07-20-2008, 07:35 PM
The bees do ALL the work--and you pull the honeycomb out--sounds like 1/2 hour of work and 3 hours getting the stickiness off--haha!!! Bill
272 Valve Adjustment Help Jag Red 54 Y-Block V8 (239, 272, 292, 312, 317, 341, 368) 8 08-31-2011 05:07 PM
Y-Block reborn in '58 F-100 Dave58 Y-Block V8 (239, 272, 292, 312, 317, 341, 368) 9 01-07-2008 04:03 AM
Y-block distributor pcmenten Y-Block V8 (239, 272, 292, 312, 317, 341, 368) 18 02-08-2006 01:06 PM
Tappet Adjustment on my 272. Help Jag Red 54 1948 - 1956 F1, F100 & Larger F-Series Trucks 8 04-06-2005 10:54 AM
272 Y-block Tappet Adjustment help Jag Red 54 Y-Block V8 (239, 272, 292, 312, 317, 341, 368) 3 04-06-2005 10:49 AM
Tags
1972, 292, 292yblockford, 312, 42, adjust, adjusting, block, bronco, cu, ford, truck, v8, valves, yblock
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
